Never mind... I didn't realize that SWF actually meant flash. It works after I installed Flash, but that means that it's impossible to upload files through iPad? Or is there a workaround?
/Peter
I have had the same problem lately with our client that mostly use IE9 internally... They couldent drag and drop files, which turned out to be "working as intended" according to EPiServer.
The obvious workaround would be to just use the file upload dialog but that dosent seems to work without flash installed ...
I got an answer from EPiServer regarding this btw. It was "working as intended" but they updated the systems requirements to say that flash is needed for uploads in IE9.
I'm having trouble getting the file upload in episerver file manager to work in IE9. I get two script errors in the console when hitting the plus-sign in the file manager:
SCRIPT5007: Unable to get value of the property 'focus': object is null or undefined
Cms, line 1 character 1
SCRIPT5022: Building SWF failed.
And then the plus sign to add files doesn't respond.
Any ideas?
/Peter
