Override readonly property and save new value
Ìs it possible to override a readonly property and save it's new value using c# code?
I have an old custom property on my page that I need to be able to override and save new values to since the old code dosen't seem to work longer and save to.
#80942
Feb 05, 2014 14:33
This is my code that I am using:
var fileList = this.SliderPages;
                string serializedString = string.Empty;
                if (fileList.Count > 0)
                    using (MemoryStream tempMemory = new MemoryStream())
                        BinaryFormatter binaryFormatter = new BinaryFormatter();
                        binaryFormatter.Serialize(tempMemory, fileList);
                        serializedString = System.Convert.ToBase64String(tempMemory.ToArray());
                DataFactory factory = EPiServer.DataFactory.Instance;
                var data = factory.GetPage(this.CurrentPage.PageLink);
                data.SetValue(this.PropertyName, serializedString);
                factory.Save(data, EPiServer.DataAccess.SaveAction.Save);
This is the error I get:
Message = "The property SliderBox is read-only."
#80943
Feb 05, 2014 14:36
Before you can set new value. you need a writeable clone of the page data object:
var writablePage = data.CreateWritableClone();
#80949
Feb 05, 2014 15:23
