css and js are returning 404
Hello!
Something is crazy with css and js files for the CMS in Episerver 7. They are not reachable and I just get 404 not found when trying to reach them from my browser.
In EpiserverFramework.config, I have this code:
<add virtualPath="~/UI/edit/CMS/" physicalPath="C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\application\UI\CMS\"
      customFileSummary="~/FileSummary.config" name="UI" type="EPiServer.Web.Hosting.VirtualPathNonUnifiedProvider,EPiServer" />
In web.config:
<location path="ui/edit">
    <system.web>
      <httpHandlers>
        <clear/>
        <!-- This section is copied from root web.config -->
        <add path="WebResource.axd" verb="GET" type="System.Web.Handlers.AssemblyResourceLoader" validate="true"/>
        <add path="*.aspx" verb="*" type="System.Web.UI.PageHandlerFactory" validate="true"/>
        <add path="*.ashx" verb="*" type="System.Web.UI.SimpleHandlerFactory" validate="true"/>
        <add path="*.asmx" verb="*" type="System.Web.Services.Protocols.WebServiceHandlerFactory, System.Web.Services, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" validate="false"/>
        <add path="*.ascx" verb="*" type="System.Web.HttpForbiddenHandler" validate="true"/>
        <add path="*" verb="*" type="EPiServer.Web.StaticFileHandler, EPiServer" validate="true"/>
      </httpHandlers>
    </system.web>
  </location>
    The files are at their location on the disk. The strange thing is that .aspx-files at the same location are returned but not css, js or txt-files.
For example:
<script src="/UI/edit/CMS/Javascript/system.aspx" type="text/javascript"></script>
<script src="/UI/edit/CMS/javascript/editmodeshellintegration.js" type="text/javascript"></script>
I can browse the file system.aspx
I can't browse editmodeshellintegration.js.
I really need help, I have no clue about what I can do. Thx!!
Regards.
#81861
Feb 27, 2014 21:58
By the way, I've read related posts (but not exactly identical) and I have the following setting too:
<scanAssembly forceBinFolderScan="true" />
#81862
Feb 27, 2014 22:07
The problem is only in the CMS. On the website, there is no problem to get css and js-files.
#81866
Feb 27, 2014 22:40
What is your system.webServer element content for that location? I would try to enable failed request tracing in IIS and see maybe something interesting there..
#81879
Feb 27, 2014 23:48
Tracing gives the following summary:
Site 2
Process 3340
Failure Reason STATUS_CODE
Trigger Status 404
Final Status 404
Time Taken 0 msec
Url http://191.238.53.61:17000/UI/edit/CMS/javascript/editmodeshellintegration.js
App Pool xxxxSiteAppPool_v4.0
Authentication anonymous
User from token NT AUTHORITY\IUSR
Activity ID {00000000-0000-0000-A801-0080000000F5}
Error & warning
ModuleName
IIS Web Core
Notification
16
HttpStatus
404
HttpReason
Not Found
HttpSubStatus
0
ErrorCode
2147942402
ConfigExceptionInfo
Notification
MAP_REQUEST_HANDLER
ErrorCode
The system cannot find the file specified. (0x80070002)
#81893
Edited, Feb 28, 2014 9:40
Try to add following section to your location element:
    <system.webServer>
      <handlers>
        <clear />
        <add name="AssemblyResourceLoader-Integrated-4.0" path="WebResource.axd" verb="GET,DEBUG" type="System.Web.Handlers.AssemblyResourceLoader" preCondition="integratedMode,runtimeVersionv4.0" />
        <add name="WebServiceHandlerFactory-Integrated-4.0" path="*.asmx" verb="GET,HEAD,POST,DEBUG" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" preCondition="integratedMode,runtimeVersionv4.0" />
        <add name="svc-Integrated-4.0" path="*.svc" verb="*" type="System.ServiceModel.Activation.ServiceHttpHandlerFactory, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" preCondition="integratedMode,runtimeVersionv4.0" />
        <add name="wildcard" path="*" verb="*" type="EPiServer.Web.StaticFileHandler, EPiServer.Framework" />
      </handlers>
    </system.webServer>
#82034
Mar 04, 2014 15:04
