You do not need a custom property for this, just do like this:
[Display(
Name = "StringLenghAttribute",
Description = "StringLenghAttribute.",
GroupName = "Validation tests",
Order = 101)]
[StringLength(10)]
public virtual string StringLenghAttribute { get; set; }
David explains the validation attributes here:
http://www.david-tec.com/2012/06/EPiServer-7-Preview---Using-validation-attributes/
Hi all,
I am facing problem when creaing custom String property which MaxLength should only be 10. Even i run the project and Adding a property to template i could enter more than 10 characters. What may be the problem? Please look into the below code and tell me whether it is correct way or not. I have added the CustomControl in Models Folder.
TextPropertyCustom.cs
TextPropertyCustomControl.cs
using System;
using System.Text;
using EPiServer;
using EPiServer.Core;
using EPiServer.DataAbstraction;
using EPiServer.Web.PropertyControls;
using EPiServer.Web.WebControls;
namespace MyDemo1.Models
/// <summary>
/// PropertyControl implementation used for rendering TextPropertyCustom data.
/// </summary>
public class TextPropertyCustomControl : EPiServer.Web.PropertyControls.PropertyStringControl
public TextPropertyCustom TextPropertyCustom
get
return PropertyData as TextPropertyCustom;
And one more query, Where i can exactly create this custom controls? Whether in Models folder or Models - Pages Folder?
