Cannot empty trash
Im working in a project wich are upgrade from EPiServer 6 R2 to EPiServer 7.1. I've noticed now after the upgrade that I cannot empty the trash. I get this error message after a while:
"Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding"
Anyone knows how to fix this or manually empty the trash?
#81243
Feb 12, 2014 13:14
I don't have access to an EPi7 db for the moment but in EPi6 there is a stored procedure called editDeleteChilds which may be useful; I believe it is used by the empty wastebasket function under the hood. See if you can find it and write a script running it on all pages with the wastebasket as parent. Might work :)
Cheers!
//Mathias
#81271
Feb 13, 2014 9:21
