Child page URL worked without language-ID in EPi6 - doesn't seem to work in EPi7?
In EPiServer CMS 6 we could enter the following URL and end up on the Swedish page:
http://www.elmia.se/automation
If we enter the "same" URL in EPiServer CMS 7 we end up with a 404:
http://www3.elmia.se/automation
(the only thing that's different is 'www3' compared to 'www')
However, if we enter (notice the extra 'sv')
http://www3.elmia.se/sv/automation
it works like a charm.
Can anyone explain why this is? Is it tied somehow to routing? As I see it, if it worked in EPi6 it should work in EPi7 as well.
#81454
Feb 17, 2014 16:38
Which version of CMS are you running? In some later patches a more rigid routing with respect to language where introduced (more information under http://world.episerver.com/Documentation/Items/Installation-Instructions/Installing-EPiServer-updates/Multilingual-Sites-and-Patch-2/)
You can get more tolerant behaviour as in CMS6 by setting attibute strictLanguageRouting=false on element siteSettings in CMS7 or applicationSettings in CMS 7.5
#81477
Feb 18, 2014 10:57
Thank you for your answer, Johan!
We're running EPiServer 7.1.
I'll set strictLanguageRouting=false to see if that helps.
#81480
Feb 18, 2014 11:18
Another thing that sould be of interest for you is to setup language mappings for your hosts. You do that in admin mode under Manage WebSites. E.g. can you add a mapping for "www3.elmia.se" to "se"
#81481
Feb 18, 2014 11:21
Johan: I added the attribute strictLanguageRouting=false and added a mapping for www3.elmia.se to se, and now it seems to work.
Thank you!
#81586
Feb 20, 2014 8:47
