Name/PageName for shared block
I would like to use a shared blocks Name as well as date in the renderd block. Just as you would do with a regular PageData object.
Rendering is easy, (CurrentBlock as IContent).Name but how to make on page edit work?
#114791
Dec 22, 2014 13:46
Joel showed how to render properties without using PropertyFor if you are using MVC that is:
http://joelabrahamsson.com/how-episervers-html-helper-propertyfor-works/
If you are using Webforms check out the documentation on how to add edit hints for proeprties:
http://world.episerver.com/documentation/Items/Developers-Guide/EPiServer-CMS/75/Rendering/Adding-edit-hints-without-using-Property-web-control/
Regards,
Tobias
#114802
Edited, Dec 22, 2014 18:50
Thanks for the reply Toni. I did not get on page edit to work with block name. Unfortunate I dont think this is possible either, atleast not at the moment.
#115721
Jan 16, 2015 14:35
