One of the fastest solution (avoiding to learn EPi edit UI internals) would to be to provide Type and Value fields. And then implement logic where based on selected value in Type field Value field is used respectively. Could be the case when this is not possible but at least - maybe can give quick workaround. If however implementing full solution keep in mind that Value1 and Value2 also should be hidden from OnPage Edit mode if those fields are exposed in template.
Might be too late now, but this is a nice blogpost on dependant properties, if someone stumbles upon this thread: http://world.episerver.com/blogs/Duong-Nguyen/Dates/2014/1/Country-Region-drop-down-lists-in-All-properties-mode/
@Gaurav Gupta Did you come up with a solution for this? I want to implement the exact same thing.
I am using EPIServer 7 CMS. I have a requirement in block setup and its properties assignment in Edit mode for which I am trying to find the solution.
Scenario :
- Created a Block Type which have 3 properties - Type, Input1, Input2
- Type is a dropdown. Values are pupulated from enum. Values are Value1 and Value2
Requirement :
- From Type when I select value "Value1" then I only need property "Input1" to be visible.
- And from Type when I select value "Value2" then I need both properties "Input1" and "Input2" to be visible.
Is this requirement feasible and if yes, then please provide suggestions on above problem as soon as possible.
Gaurav
