using DisplayChannels in hybrid MVC Webforms solution
Is it possible to use display channels in a solution that has webforms and MVC templates?
For a certain display channel A we would like to use an MVC view and for display channel B we would like to use Webfroms.
I tested displaychannels in webforms and that works just fine.
When i add an MVC view in the same solution and use a template descriptor on the controller then it does not work.
Has anyome used DisplayChannels in a mixed Webforms / MVC solution?
Resources used:
http://world.episerver.com/Documentation/Items/Developers-Guide/EPiServer-CMS/7/Content/Display-Channels/
http://world.episerver.com/Code/dannymurphy/Mobile-Channel-amp-Display-Mode/
#112626
Nov 02, 2014 8:25
You cannot mix MVC and Webforms for the same content type.
#112634
Nov 03, 2014 0:47
