Installation problems
I'm looking to install Episerver 7 on Windows 8.  I've launched setup.exe as an administrator and selected to install just the CMS.  I then get to the screen "Installing 'EPiServerShared.msi'... where it gets stuck.  After 20 minutes or so, I get an "Installer is not responding" message.
Checking the log file the last point it gets to is: "Launching EPiServerShared.msi /i....", which is as expected, but there's no error messages.
Appreciate if anyone has any suggestions on getting past this point.
I should note I have EPiServer 6.1 already installed, but would like to have both as have projects targetting both versions.
Many thanks
Andy
#79917
Jan 09, 2014 16:42
Do you execute directory from .zip file or extracted archive?
#79926
Jan 10, 2014 10:12
From the extracted archive.
#79928
Jan 10, 2014 10:26
Have you tried to "unblock" the downloaded .zip file before extracting it?
I have seen some issues where the extrated files are blocked after extracting. The issue will then be that even if the setup.exe is executing as an administrator other files like EPiServerShared.msi will be blocked and hence they might not execute properly.
#79952
Jan 10, 2014 14:30
Maybe that was it - thanks.  I've actually since discovered I can just copy the files from another developers c:\program files... folder and that's all I needed to get the system up and running for local development.  So I'll stick with that for now.
#79954
Jan 10, 2014 14:40
