Display warning message in edit mode
Hello,
How can  display a wrning message on some PageData?
I had found this:
protected void Application_Start(object sender, EventArgs e)
EditPanel.LoadedPage += EditPanel_LoadedPage;
void EditPanel_LoadedPage(EditPanel sender, LoadedPageEventArgs e)
if (e.Page != null && (e.Page is DatasheetSAPReportTypeItem || e.Page is DatasheetSAPGenerationVariantItem))
sender.Validators.Add(new StaticValidator("Publishing this page will reindex all the products in background you can contnue your work during this time."));
But my event is never triggered
REgards,
Benjamin
#80609
Jan 28, 2014 6:26
Sounds that the validation attribute functionality is what you are looking for.
Check this out: http://www.david-tec.com/2012/06/EPiServer-7-Preview---IValidator-interface/
#80610
Jan 28, 2014 6:46
Yes it will do the trick thanks a lot!
#80630
Jan 28, 2014 10:21
