I think you've run into this bug:
MVC Xforms: Rendering <input> inside <label> is not optimal
The fix for that issue doesn't touch the legend element, but it fixes the problem with the nested labels. And I think that is the cause of the strange behavior.
Regards
Per Gunsarfs
I'm not sure if the fix is available somehow, the support team could better answer that.However, it shouldn't be that hard to make a workaround for it.
The MVC rendering for radio buttons in an XForm is done by an editor template called Select1tAsDropdownListFragment.ascx. The default one can be located in the installed application, under "/UI/Util/Views/Shared/EditorTemplates". You should be able to override that by dropping a custom one under "/Views/Shared/EditorTemplates" of your site root.
This is how the template looks after the bugfix(but you could of course change it to anything you'd like):
<%@ Import Namespace="EPiServer.XForms.Parsing" %>
<%@ Control Language="C#" Inherits="System.Web.Mvc.ViewUserControl<Select1Fragment>" %>
<fieldset class="<%: Model.Class %> orientation<%: Model.Orientation %>">
<legend>
<%: Model.Label %>
</legend>
<div title="<%: Model.Title %>">
<% foreach (SelectOption selectoption in Model.Options)
<label for="<%: selectoption.Id %>">
<%: Html.RadioButton(Model.Reference, Server.HtmlDecode(selectoption.Value) ?? string.Empty, selectoption.SelectedItem, new { id = selectoption.Id })%>
<%: Html.Raw(selectoption.Text) %>
</label>
<%: Html.ValidationMessage(Model.Reference)%>
</div>
</fieldset>
Ah, I see.
Btw, It should be Select1AsRadiobuttonFragment.ascx, not Select1tAsDropdownListFragment.ascx
Anyway I've tried adding the .ascx under "/Views/Shared/EditorTemplates" but it is not being picked up by the rendering. Still using EPiServer built in one. Any tips?
I've had the same problem earlier, we ended up with changing EPiServer templates inside program files :(
This is the old post:
http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=65108
Yes, Select1AsRadiobuttonFragment.ascx is the right one. The other is for drop down lists.
Had a chat with a colleague, and it should be possible to replace built in views that way. If it doesn't, I would consider it a bug. We'll do some controlled testing over here, and then get back with some more info.
We tested this in a default alloy tech installation, and noticed the same problem there. So, it is a bug, and now it's registered as:
#105779: MVC: Not possible to override XForm fragments in EditorTemplates
Regards
Per Gunsarfs
Ok, I'll change the EPiServer view in order to fix this. Thanks for the feedback!
A customer is reporting issues with selecting a radio button option when using Firefox. Clicking the label works, but it does not work clicking the input itself.
After doing some research I have concluded that it is the html produced by the xforms control that is the problem. A radio button list with two options, returns the following html:
I'm running latest version of EPiServer 7 including all AddOnStore patches and is the following code to render the xform control
By testing using dummy html I can see that the radiobuttons works well if I remove the following tags from the html:
Is this an EPiServer bug?
