Move block - problem
Posted about this problem in July, see thread:
http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=73384
It's about a problem moving blocks between folder. I got promted with a message box that tells me about a problem moving the block, but the block itself actually is moved. I use the cut and paste option since drag and drop does not work here.
Our customer is having the same problem and I need to know if this is a bug.
#75276
Sep 24, 2013 10:56
Hey, I can't help much, except that I can confirm that I have the same problem.
I see here that the problem was SiteSeeker (although I don't see how, but I do have SiteSeeker installed - do you?).
I don't have any js errors in the console and my permissions are set correctly.
Perhaps this should be reported as bug to EPi?
#75288
Sep 24, 2013 12:25
We don't have siteseeker, and no js errors. We do get IsSuccess: false from the server, but the block is still moved.
Do you know how to report bugs?
#75290
Sep 24, 2013 12:37
As far as I can see, it's here http://world.episerver.com/Support/Register-Support-Incident/. Does anyone know if this is the correct place?
Will you report this or do you want me to?
#75292
Edited, Sep 24, 2013 12:58
Sorry for late answer. I have just now reported the issue. I'll update this thread if they give me any new information.
#75713
Oct 04, 2013 9:30
