Copy full URL of file
Hello! The editors on our CMS 7 site want to copy the full path to the documents in the file explorer in EPiServer and paste it in another application. Can this be done somehow (without inserting it on a page and then copy the URL used)? I can't find a button or right-click option to "copy full path" or similar, and if I open the file I can't copy the URL in the browser since the file dialog is modal.
It's not good enough to manually create the adress from the path visible in the file explorer and adding the filename, so I was thinking of making a gadget where the editors can browse the files and see the full path but it seems a bit overkill to me. Any ideas?
#75125
Sep 18, 2013 13:04
Hello.
You can add a link to the file in the "Show file summary" view by editing a template located in c:\Program Files\EPiServer\CMS\7.0.586.1\Application\UI\CMS\Hosting\ViewFile.ascx
You can add something like this inside the first <table> tag:
<tr>
	<td>
		<a href='<%=SelectedFile.VirtualPath %>'><%=SelectedFile.VirtualPath %></a>
	</td>
</tr>
#75149
Sep 18, 2013 16:06
Thanks, excellent solution!
#75166
Sep 19, 2013 9:29
