Change uiurl
After creating a new EPiServer project in Visual Studio, what needs to be changed in order to change the uiUrl from the default "~/episerver" to something else and having it work?
#75123
Sep 18, 2013 11:48
Hello Johan,
You can find this information here (Step 1.1-1.4)
#75135
Sep 18, 2013 14:12
Thanks Sergii but I've already followed that and it doesn't work or I'm doing it wrong (likely the latter). Things started breaking.
So I was hoping someone could tell it in a better way which parts of the .config files should be changed and how?
#75136
Sep 18, 2013 14:19
Yes, you right. The document is a bit obsolete and it is not enough to follow the steps described in it. Here is the updated list of steps:
In episerver.config:
  • find siteSettings node and change uiUrl attribute (note that if default value is ~/episerver/CMS, the new value should be ~/newUiUrl/CMS)
In EPiServerFramework.config find virtualPathProvider node and change virtualPath attribute of:
  • provider with name “ProtectedAddons”
  • provider with name “UI” (note that virtual path of UI virtual path provider should also look like ~/newUiUrl/CMS)
In web.config:
  • find location node that has path attribute “episerver” and  change it to “newUiUrl”
  • find location node that has path attribute “episerver/CMS/admin” and change it to  “newUiUrl/CMS/admin”
  • find episerver.shell/protectedModules node and replace rootPath attribute with new value ~/newUiUrl/
  • find episerver.packaging node and replace protectedVirtualPath attribute with new value ~/newUiUrl/
#75140
Sep 18, 2013 15:03
Thank you Sergii, that worked splendidly!
#75165
Sep 19, 2013 9:21
