Addon store gone
in my episerver 7 project the Addon store is gone. when i go to /Episerver/CMS/AddOns the page is blank, and there is no errors in my log file or in event viewer. i know this is not much to go on but i have no idea where the problem could be so i dont know what settings to report here. if anyone have an idea where is should look please report then i can start there.
#74664
Sep 04, 2013 11:11
Can you see "Add-ons" item in the global navigation menu?
Do you have any JavaScript errors when you go to Add-ons? Could you enable FireBug, Chrome Developer Tools or similar browser plug-in and check JavaScript console? Are there any failed requests on Network tab?
#74669
Sep 04, 2013 14:14
i do not see the "Add-ons" item in the global navigation menu, it seems like the page is not there at all, when i go to /Episerver/CMS/AddOns it behaves like the page is not there. so no javascript errors or failed requests
#74691
Sep 05, 2013 7:36
I think it has something to do with access rights. Make sure that your user belongs to one of the roles that is part of the virtual role PackagingAdmins. You will find it in our EPiServerFramework.config file.
#74692
Sep 05, 2013 7:53
Do you have those DLL in your site modulesbin folder:
EPiServer.Packaging.dll
EPiServer.Packaging.UI.dll
#74696
Sep 05, 2013 8:46
it was access rights that was the problem, i will try to give my user the right role
#74702
Sep 05, 2013 9:24
hm, when i login i can see the admin view which as far as i can see means that i have the role webadmin or administrator (see http://webhelp.episerver.com/CMS/7.1/EN/Default.htm#Authorization/Admin_IN_WorkingWithAuthorization.htm)
in my episerverframework i have this line
<add roles="WebAdmins, Administrators" mode="Any" name="PackagingAdmins" type="EPiServer.Security.MappedRole, EPiServer.Framework" />
so now as far as i can see it is the same rights i need to see addon store as admin view.
i assume the problem is the claims membership provider i use, but how come i can se the admin view and not the addon store?
when i try to login as administrator using EPiServerLogin i can see the addon store, but i need to be able to use my claims membership provider
#74720
Sep 05, 2013 14:22
I also have this same issue however I'm logging in with admin who is part of Administrators/WebAdmins, modulesbin contains the correct DLL's and episerverframework.config contains
So really not sure what else I can check?  Are there any settings stored in the DB? Any files I can check for that could be missing?
Thanks in advance
#82323
Mar 11, 2014 4:14
I've stumbled across this issue too - I'm logging in with a windows membership who is part of "Administrators/WebAdmins", the DLL's all exist and episerverframework.config contains:
<add name="PackagingAdmins" type="EPiServer.Security.MappedRole, EPiServer.Framework" roles="WebAdmins, Administrators" mode="Any" />
It works when I log in on my dev environment using my windows membership, but our testing environment isn't showing up.
Any progress/hints with this?
Dean
#87004
Jun 06, 2014 12:33
Are you loggin in with Administrator or user that belongs to Administrators group on target environment?
#87007
Jun 06, 2014 13:24
Thanks for the reply, logged in with an Administrator using a Windows Membership, the users are all part of the Administrators Group, which has a WindowsRoleProvider.
The users are created using WindowsMembershipProvider - made as admins on the machine host.
Only using a Windows Role Provider and Windows Membership Provider - we have no need for SQL or any others.
From Web.config:
<roleManager enabled="true" defaultProvider="WindowsRoleProvider">
<providers>
<clear />
<add name="WindowsRoleProvider" applicationName="EPiServerSample" type="EPiServer.Security.WindowsRoleProvider, EPiServer" />
</providers>
</roleManager>
<membership defaultProvider="WindowsMembershipProvider" hashAlgorithmType="HMACSHA512" userIsOnlineTimeWindow="10">
<providers>
<clear />
<add name="WindowsMembershipProvider" type="EPiServer.Security.WindowsMembershipProvider, EPiServer" deletePrefix="BUILTIN\" />
</providers>
</membership>
From EPiServerFramework.config:
Thanks again, really appreciate it - the store is visible on both our production and developer systems, it's just the test environment we can't see it.
#87009
Jun 06, 2014 14:13
Note, since this answer ranks quite high in Google for this particular problem, I'm adding another answer that is worth checking out.
When you upgrade to the new packaging system in EPiServer.Packaging (3.2.0 or newer), make sure you also have EPiServer.Packaging.UI installed as a nuget package.
For some reason I've yet to understand, a site that I upgraded lost this package during upgrade (or it never had it in the first place). I was able to run the Move-EPiServerProtectedModule command though.
Running: "install-package EPiServer.Packaging.UI" brought back the Add-on menu.
#114255
Dec 08, 2014 16:35
