Render blocks with PropertyFor
I have a custom block with two properties - an image url and an alternative text
 [ContentType(
        GUID = "387A029C-F193-403C-89C9-375A2A6BF028",
        AvailableInEditMode = false,
        DisplayName = "Image"
    public class ImageBlock : EPiServer.Core.BlockData
        [UIHint(UIHint.Image)]
        [Display(
            Name = "Image Url",
            Description = "",
            Order = 10)]
        public virtual Url ImageUrl { get; set; }
        [Display(
            Name = "Alternative text",
            Order = 20)]
        [CultureSpecific]
        public virtual string AlternativeText { get; set; }
I have created a partial view in shared directory /shared/ImageBlock/index.cshtml as
@model ImageBlock
<img src="@Model.ImageUrl" />
So I am hoping when I call something like
@Html.PropertyFor(p=>p.CurrentPage.TestProperty)
My partial view should get called, but the partial view never gets called.
- TestProperty is a property of type ImageBlock
Can any body please help me
#73643
Aug 02, 2013 17:57
Does it say it can't find a renderer for the property? If I recall correctly, the correct path to the ImageBlock partial should be "Views/Shared/ImageBlock.cshtml", unless you are pushing the block through a controller.
#73644
Aug 02, 2013 18:58
Hi, Tahir,
I have not placed my ImageBlock (that I am using as local block and rendering with PropertyFor) inside Views/Shared/ImageBlock.cshtml.
Instead, I have placed it inside Views/Shared/DisplayTemplates/ImageBlock.cshtml
#73670
Aug 05, 2013 14:59
i'm facing a similar dilema to Tahir, I have tried putting into DisplayTemplates although still get the message their is no render for this block.
For now I am using seperate controllers although dont think this is the tidiest thing to do.
#73693
Aug 06, 2013 9:58
