Partial Route instead of querystring in Web Forms project
I have a page type with a web form template that displays different integrated data based on two querystring int parameters.
The int's have a registry of URL friendly names.
I've looked at Joel's http://joelabrahamsson.com/custom-routing-for-episerver-content/ and created a RoutePartial method to be able to have a URL such as /createinquiry/mycategory-in-myregion/ instead of /createinquiry/?categoryid=666&regionid=888.
public object RoutePartial(CreateInquiryPage content, SegmentContext segmentContext)
            if (!content.ContentLink.CompareToIgnoreWorkID(Site.Settings.Instance.CreateInquiryPageLink))
                return null;
            var nextSegment = segmentContext.GetNextValue(segmentContext.RemainingPath);
            var urlSegment = nextSegment.Next;
            if (string.IsNullOrEmpty(urlSegment))
                return null;
            Log.DebugFormat("CreateInquiryRouter urlSegment {0}", urlSegment);
            segmentContext.RemainingPath = nextSegment.Remaining;
            segmentContext.RoutedContentLink = Site.Settings.Instance.CreateInquiryPageLink;
            segmentContext.SetCustomRouteData("categoryid", 666);
            segmentContext.SetCustomRouteData("regionid", 888);
            return null;
urlSegment above contains "testparam" extracted from the full URL /createinquiry/testparam/ which is exactly what I want. I will of course later resolve the correct ID's but for now I just use segmentContext.SetCustomRouteData() to attach hard coded int's to the request.
I don't need GetPartialVirtualPath() so I just return an empty object. Maybe it's better to return a NotImplementedException()?
In the web form I fetch the values using Request.RequestContext.GetCustomRouteData<int>("categoryid").
Is this a good approach and/or what other options do I have?
Is it possible to rewrite the request in RoutePartial so that my web form works just using Reqeust.QueryString["categoryid"] both routed and unrouted?
#73822
Aug 12, 2013 10:24
