Generate Demo License
I'm trying to generate a demo license for EPiServer 7 CMS (https://license.episerver.com/public/GenerateDemoLicense.aspx)
and I'd like to know what "Bound Input" is and what I need to enter?
I apolgize if this is not the correct forum for this question.
#73917
Aug 14, 2013 11:53
The license file must be generated for the server you intend to use it on. You can bind the license to either the servers IP address or the mac address. I would advise using IP address for this purpose.
#73919
Aug 14, 2013 12:35
So basically the IP of my computer since I'll be trying it out on it.
Thanks Thomas.
#73920
Aug 14, 2013 12:40
Yes. :) If you are working for an EPiServer Partner, you should go for a developer license instead of a demo license.
#73921
Aug 14, 2013 12:45
Bound input:
Use MAC if it's your development computer normally
Use IP if it's a test / stage / productionserver since it will then be possible to change server hardware without ordering a new license. The IP is the internal IP of the server.
ipconfig /all gives you nice info about both MAC and IP
#73925
Aug 14, 2013 14:41
Daniel has a very good point. I keep forgetting that not everyone else has a fixed IP on their dev machine.... :)
#73926
Aug 14, 2013 14:42
Alright, thanks Daniel!
#73928
Aug 14, 2013 14:47
