Error when creating EPiServer 7 prodject using EPiServer vs Extension in Visual Studio 2012
Hi, I'm trying to create a new EPiServer 7 prodject from Visual Studio 2012 but I get the following error message. Any idés?
"Error - The WriteObject and WriteError methods cannot be called from outside the overrides of the BeginProcessing, ProcessRecord, and EndProcessing methods, and only from that same thread. Validate that the cmdlet makes these calls correctly, or please contact Microsoft Support Services."
Additional Information:
"Started a transacted install
Copied connectionStrings.config
Copied default.htm
Copied episerver.config
Copied EPiServerLog.config
Copied FileSummary.config
Copied global.asax
Copied Web.Config
Copied AdapterMappings.browser
Copied IE6.browser
Copied Castle.Core.dll
Copied Castle.Windsor.dll
Copied EPiServer.BaseLibrary.dll
Copied EPiServer.Blog.dll
Copied EPiServer.Configuration.dll
Copied EPiServer.dll
Copied EPiServer.Enterprise.dll
Copied EPiServer.ImageLibrary.dll
Copied EPiServer.Implementation.dll
Copied EPiServer.LinkAnalyzer.dll
Copied EPiServer.Scheduler.dll
Copied EPiServer.Scheduler.WKTL.dll
Copied EPiServer.UI.dll
Copied EPiServer.Web.WebControls.dll
Copied EPiServer.WebDav.dll
Copied EPiServer.WebParts.dll
Copied EPiServer.WorkflowFoundation.dll
Copied EPiServer.XForms.dll
Copied EPiServer.XmlRpc.dll
Copied log4net.dll
An unhandled error has occured:
The path is not of a legal form.
When executing
At C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\Install\System Scripts\Instal
l Site (No Database).ps1:217 char:21
+ Set-EPiXmlAttribute <<<< -TargetFilePath $targetWebConfigPath -ElementXPath
"/configuration/epi:episerver/epi:sites/epi:site[1]/epi:siteSettings" -Attribu
teName "siteUrl" -AttributeValue $wizard.EPiSiteUrl
True
Get-EPiIsBulkInstalling
When executing
l Site (No Database).ps1:16 char:26
+ Rollback-EPiBulkInstall <<<<
At C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\Install\System Scripts\Install VS Baseline.ps1:16 char:26
System.Management.Automation.PSInvalidOperationException: The WriteObject and WriteError methods cannot be called from outside the overrides of the BeginProcessing, ProcessRecord, and EndProcessing methods, and only from that same thread. Validate that the cmdlet makes these calls correctly, or please contact Microsoft Support Services.
at System.Management.Automation.MshCommandRuntime.ThrowIfWriteNotPermitted(Boolean needsToWriteToPipeline)
at System.Management.Automation.MshCommandRuntime.WriteHelper_ShouldWrite(ActionPreference preference, ContinueStatus lastContinueStatus)
at System.Management.Automation.MshCommandRuntime.WriteWarning(WarningRecord record)
at System.Management.Automation.MshCommandRuntime.WriteWarning(String text)
at System.Management.Automation.Cmdlet.WriteWarning(String text)
at EPiServer.Install.UI.CmdletProgressHelper.WriteWarning(String message)
at EPiServer.Install.UI.CmdletProgressHelper.Progress_Updated(Object sender, ProgressEventArgs e)
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at EPiServer.Install.InstallationManager.WriteProgress(Exception ex, String message)
at EPiServer.Install.InstallationManager.RollbackBulkInstall()
at EPiServer.Install.Common.Cmdlets.RollbackBulkInstallCmdlet.ProcessRecord()
at System.Management.Automation.Cmdlet.DoProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()"
#74059
Aug 20, 2013 10:24
do you have sql express installed? also try to do the same when running vs in administrator mode?
#74071
Aug 20, 2013 13:14
SQL EXPRESS 2012 is installed and I'm running as admin.
#74075
Aug 20, 2013 13:36
Can you successfully run action "Install site without database" in Deployment Center using the same user?
#74079
Aug 20, 2013 13:55
There is no problem creating a site with "Install site without database" using Deployment Center. I run booth applications as admin.
#74082
Aug 20, 2013 14:19
another stupid question: can you install a site with databse and templates via deployment center? I would guess you have some problem with the access to the db. Enable sql browser etc in the sql configuration manager?
#74084
Aug 20, 2013 15:05
I can booth create a site with a SQL Server database and add a SQL Server database to a site created with out database from EPiServer deployment center. Booth SQL Server 2008 R2 and SQL Server 2012 ar running an I have no problem connecting to them from sites created with EPiServer deployment center.
#74085
Aug 20, 2013 15:58
Problem solved. I was using the deffault directory in VS 2012 for the project which was a refference to My Documents/Visual Studio 2012/.../Site, changing it to C:/.../Site solved the problem.
#74090
Aug 20, 2013 16:13
