Execute
select * from [dbo].[tblBigTable] where storename = 'InUseNotifications'
Most probably `ContentGuid' property will be mapped against `Indexed_Guid01' column.
And if you want to manage the in use notifications through the API instead of changing directly in database you can use an implementation of IInUseNotificationRepository.
Regards
Per Gunsarfs
Thank you both! I have used the query, it was only a matter of one page with the no longer existing user.
Hey guys, I keep having "Administrator redigerar" message on start page of the English version of the web site in edit mode. I have taken a peak at the DB and I can't see anything that is different than on other pages. I don't have the password of Administrator, so I can't simply log in and publish the changes.
Does anyone know exactly which flag I should delete in the DB?
