'Page shown after the form has been sent' is on each Xform Editor and I just want to do manual sending another mail after the Xform mail has been sent and then after I sent manual mail, it redirect to the page which I have setted.
I really need your help.
I researched a lot, but cannot find any useful information. Then I reflector the source and according to episerver 7 codes, finally solve the problem.
Would be nice if you could share some code fragments for reference. Thanks!
In EPiServer.dll the following code exists in the class-file XFormSuccessACtionResult.cs that contributes to the problem.
If the editor have an confirmation page, the Success method isn't invoked.
public override void ExecuteResult(ControllerContext context)
if (base.XForm.PageGuidAfterPost != System.Guid.Empty)
string mappedUrl = this.GetMappedUrl(base.XForm);
if (!string.IsNullOrEmpty(mappedUrl))
context.HttpContext.Response.Redirect(mappedUrl);
else
base.InvokeAction(context.Controller as Controller, context.HttpContext.Request.Params.get_Item("successAction"));
There is a work around. After I did some decompiling of the EPiServer.dll I came up with this solution (assuming that you use DoSubmit as PostAction and Success as the SuccessAction)
[AcceptVerbs(HttpVerbs.Post)]
public virtual ActionResult Success(BasePageData currentPage, XFormPostedData xFormpostedData)
//you custom code here ...
//Return to the right page..
if(xFormpostedData.XForm.PageGuidAfterPost != Guid.Empty)
return Redirect(UrlResolver.GetUrl(ContentRepository
.Get<PageData>(xFormpostedData.XForm.PageGuidAfterPost)
.ContentLink));
//default, return to index.
return View(currentPage);
public virtual ActionResult DoSubmit(BasePageData currentPage, XFormPostedData xFormpostedData)
if (ModelState.IsValid && ProcessXFormAction(xFormpostedData))
return Success(currentPage, xFormpostedData);
return ServiceLocator.Current
.GetInstance<XFormPageUnknownActionHandler>()
.HandleAction(this);
protected bool ProcessXFormAction(XFormPostedData post)
var xformData = new XFormPageHelper().GetXFormData(this, post);
try
return XFormActionHelper.DoAction(xformData, post, true);
catch (Exception ex)
this.ModelState.AddModelError("ProcessXFormAction", ex.Message);
return false;
Hi ,
I am now using Episerver 7 MVC to create some Xform for sending mail or redirect to other page much more convenient.
But after research in the internet and forums as well, I found a solution to let the form work. But there still a question cannot to solve. If I not choose the brower 'Page shown after the form has been sent', the Success Action could be triggered, but if I choose a page for the brower option, Success action could not be fired and just redirect to the page which I have chosen in Episerver CMS.
I want to know how to deal with it and if I want to use AfterSubmitPostedData event in Episerver 7 MVC, how can I do?
Just the same as in global.asax or just do not have to do it and use other action instead.
