Modifying XForms Markup
I need to modify the markup for an Xform in my site to remove all of the table layouts. I have done some reading and everyone says to override the ControllsCreated event. A good article about it here:
http://www.frederikvig.com/2010/11/semantic-markup-with-episerver-xforms/
This solution and all of the others I have looked at are for version 6 and mention about updating the ControlsCreated method in the Global.asax file. This no longer exists on a version 7 MVC site. Does anyone know how to implement this for 7?
Many thanks
Dave
#74004
Aug 16, 2013 13:36
Hi Dave
Under Views -> Shared -> DisplayTemplates I have XForms.cshtml with some custom code for this:
@using EPiServer.HtmlParsing
@using EPiServer.Web.Mvc.Html
@model EPiServer.XForms.XForm
@if (ViewData["XFormActionResult"] is EPiServer.Web.Mvc.XForms.XFormSuccessActionResult)
    <strong>Form posted.</strong>
else
    using (Html.BeginXForm(Model, htmlAttributes: new {@class = "form xform"}))
        if (Model != null)
            foreach (HtmlFragment fragment in (IEnumerable<HtmlFragment>)ViewData["XFormFragments"] ?? Model.CreateHtmlFragments())
                @Html.Fragment(XFormHelper.CleanupXFormHtmlMarkup(fragment))
And the CleanupXFormHtmlMarkup method looks like this:
public static class XFormHelper
        public static HtmlFragment CleanupXFormHtmlMarkup(HtmlFragment htmlFragment)
            if (htmlFragment.Name == "table" || htmlFragment.Name == "tr" || htmlFragment.Name == "td" || htmlFragment.Name == "tbody" || htmlFragment.Name == "thead")
                htmlFragment.Name = "div";
                if (htmlFragment is ElementFragment && ((ElementFragment)(htmlFragment)).HasAttributes &&
                ((ElementFragment)(htmlFragment)).Attributes["valign"] != null)
                    ((ElementFragment)(htmlFragment)).Attributes.Remove("valign");
            return htmlFragment;
Note that this is just some basic example code to get you started.
Hope this helps.
Frederik
#74007
Aug 16, 2013 17:45
Hi Frederik
Thank you so much for your response. That worked great with one tiny tweak, for me the DisplayTemplate needed to be called XForm.cshtml.
Thanks very much
Dave
#74169
Aug 21, 2013 17:25
Frederiks post should be a sticky!  Thanks!
#74201
Aug 22, 2013 12:50
If you create your own XForm Block with your own Model how can I use CreateHtmlFragments to change the HTML mark up to Divs?
#131745
Aug 04, 2015 16:34
How do I add an asterix against all Required fields?
#174266
Jan 23, 2017 18:15
