Change content in On_Load of local block
In Page_Load of an EPiServer page, I am replacing some [[content]] with some data from a database using this code:
if (!PageEditing.PageIsInEditMode)
if (property.InnerProperty != null)
var prop = property.InnerProperty.CreateWritableClone();
string webFieldContent = contentData.GetWebFieldContent(propertyName);
prop.Value = webFieldContent;
property.InnerProperty = prop;
This works fine on the page itself, but not on local blocks. When debugging, i can see the data replacement being done as expected, but hwen the page has loaded, the [[content]] has not been replaced after all. Does anyone have an idea why this happens - or even better - what I can do to make it work?
#74053
Aug 20, 2013 7:52
