Translate categories
Is it possible to translate the names or descriptions of categories? I've found a blog post on how to do it in EPi 6 by putting the translations in a language file but I can't get the same thing to work in EPiServer 7. Is there a new better way to work with categories and globalization?
#73165
Jul 09, 2013 12:01
Hi Oskar,
Dit you use this format?
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<languages>
  <language name="dutch" id="nl">
    <categories>
      <category name="CategoryName">
        <description>CategoryName translated</description>
      </category>
    </categories>
  </language>
</languages>
To do some shameless self promotion: You could also install a NuGet package I created, that allows you to create your translations within the content tree, also for categories.
http://nuget.episerver.com/en/OtherPages/Package/?packageId=EPiServer.Libraries.Localization
http://jstemerdink.wordpress.com/2013/06/20/a-custom-localization-provider-for-episerver-7-2/
Hope this helps.
#73168
Jul 09, 2013 13:12
Yes, that was the xml I tried earlier and I still can't get it to work.
In view mode I use the code below but it only lists the names of the categories.
@Html.PropertyFor(m=>m.Category)
And when I edit the page in forms mode the category descriptions are used but they are not translated.
I have translations of page types and properties so I know the language file works.
#73170
Jul 09, 2013 14:11
The property for displaying translated categories is LocalizedDescription, so maybe it should be: m.Category.LocalizedDescription ?
#73171
Jul 09, 2013 14:32
PagaData.Category don't seem to have LocalizedDescription. And view mode isn't really the problem because there I can translate them myself. I was hoping I would be able to translate them in edit mode as well, but maybe that's not possible?
#73179
Jul 09, 2013 15:39
Ah, must have been sleeping. PageData.Category is CategoryList, so it contains the categories, if any are selected. The LocalizedDescription is a property of a category not of the CategoryList (a.k.a. Category)
#73180
Jul 09, 2013 15:53
Thank you for all the help, I can get the translated descriptions from the language file by doing something like this:
Model.Category.Select(x=> Category.Find(x).LocalizedDescription)
But the translations are still not shown in edit mode though.
#73184
Jul 09, 2013 16:38
No prob. I think to show them in EditMode, you will need to switch the UI language.
#73185
Jul 09, 2013 16:44
Both the language file and the UI culture are "en". And property names are translated correctly in edit mode. I'm starting to think that this is a bug in episerver.
#73187
Jul 09, 2013 17:17
No, i don't think that is the same bug. My site language is english.
#73197
Jul 10, 2013 10:00
I have started working on Localizing the EPiServer Categories, and Category.Find(x).LocalizedDescription works like a charm. Thank you for the suggestion. However while displaying the category description on an Html page , I had to do HttpUtility.HtmlDecode(Category.Find(@tag.Key).LocalizedDescription) as it was displaying & as &amp;
#138912
Sep 23, 2015 13:21
