Language specific error message for the Range attribute
I have declared a property that has an allowed range from 1 to 15. I would like to have a language specific error message but it fails the way I have done it... (I have declared the "/errormessages/invalidrange" in EditorHints.xml where I have also declared other error messages for the RegularExpression attribute which are working fine):
    [Range(1, 15, ErrorMessage = "/errormessages/invalidrange")]
    [Display(
        Order = 110)]
    public virtual int NumberOfArticles { get; set; }
Any suggestions?
#73144
Jul 08, 2013 14:19
I'm not sure and haven't investigated further why message localization of MVC model attributes didn't work at all locally but I came up with a solution where a message is looked up at runtime, + added support for unobtrusive client-side validation (probably a bit overkill as built-in support has to work..).
More details here: http://www.tech-fellow.lv/2013/05/localized-episerver-model-validation-attributes/
I haven't had chance to dig into - but if you resolve - please give a hint :)
#73157
Jul 08, 2013 20:29
