ChangeDate in tblChangeLog always -2h
Hi, guys,
Is this a known bug and is there a fix somewhere for it I can't find?
When I open tblChangeLog after deleting/moving/creating a page, the date written to ChangeDate is always 2h less than it should be. For example, at 10:37, it's written 8:37. Other tables use the correct date, so my guess is that this has nothing to do with system time or so.
Is there a stored procedure EPi uses I could change or I should adjust my code using this table to add 2h (which I don't like, as this might be fixed and than nothing would work)?
BR,
Marija
#73575
Jul 30, 2013 10:39
Sounds like it could be that it saves the UTC time
http://www.timetemperature.com/europe/sweden_time_zone.shtml
Best regards,
Magnus
#73576
Edited, Jul 30, 2013 10:57
