CancelReason in MovingPage
I want to controll the deletion of blocks and send a message to the user. So I setup the event Instance_MovingPage in EPiServer.DataFactory.Instance. In the event I set a message for the user in e.CancelReason and e.CancelAction = true. The move is canceled but my reason message is not displayed. There is a standard message displayed instead.
Isn´t this supposed to work?
/Raymond
#73083
Jul 05, 2013 10:34
Hi Raymond,
Have you resolved the issue? Seems that I have faced the same..
#147721
Apr 22, 2016 9:05
Works in EPiServer 9 at least...tried this:
    public class EventsInitialization : IInitializableModule
        private IContentEvents _contentEvents;
            if (_contentEvents == null)
                _contentEvents = ServiceLocator.Current.GetInstance<IContentEvents>();
            _contentEvents.MovingContent += Moving;
 private void Moving(object sender, ContentEventArgs e)
            var args = e as MoveContentEventArgs;
            if (args != null)
                args.CancelAction = true;
                args.CancelReason = "this didn't work out at all";
            _contentEvents.MovingContent -= Moving;
Works like a charm!
#147726
Edited, Apr 22, 2016 10:47
