+1 the same here. What I found so far is that by adding Glimpse it augments all routes and replaces with it's own proxy classes for intercepting calls to routing. EPiServer (and UrlResolver in particular) seems that don't like this case. The root cause for this exception is following method:
UrlResolver.GetVirtualPath(ContentReference contentLink, string language, RouteValueDictionary routeValues, RequestContext requestContext)
What it doesn't like is fact that there is no route of type ContentRoute in the routing table:
foreach (RouteBase base2 in from r in this._routes
where (bool) (r is ContentRoute)
select r)
if(...)
return virtualPath;
return null;
And after returning null to the caller NullReferenceExpcetion occours in:
UrlExtensions.MapUrlFromRoute(RequestContext requestContext, RouteCollection routeCollection, string url)
Seems like patch from EPiServer should be awaited.
Just forwarding if somebody will look for a solution here:
A workaround (thanks to @avanderhoorn!) is to add this to the "glimpse" section of web.config:
<glimpse defaultRuntimePolicy="On" endpointBaseUri="~/Glimpse.axd">
<tabs>
<ignoredTypes>
<add type="Glimpse.AspNet.Tab.Routes, Glimpse.AspNet"/>
</ignoredTypes>
</tabs>
<inspectors>
<ignoredTypes>
<add type="Glimpse.AspNet.Inspector.RoutesInspector, Glimpse.AspNet"/>
<add type="Glimpse.Mvc.Inspector.ModelBinderInspector, Glimpse.Mvc4"/>
</ignoredTypes>
</inspectors>
</glimpse>
This disables the two parts of Glimpse that break with EPiServer. As far as I can see, you still get the most useful parts available!
Just realized that EpiServer CMS Find plugin does not function correctly as well.
[InvalidCastException: Unable to cast object of type 'Castle.Proxies.IViewProxy_1' to type 'System.Web.Mvc.WebFormView'.] ASP.episerverfindembeddedresources_episerver_find_framework_dll_episerver_find_framework_ui_views_shared_index_master.__Render__control6(HtmlTextWriter __w, Control parameterContainer) in C:\Projects\Kolumbus\Main\Kolumbus.Web\EPiServerFindEmbeddedResources\EPiServer.Find.Framework.dll\EPiServer.Find.Framework.UI.Views.Shared.Index.Master:29 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +131 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +150 ASP.episerverfindembeddedresources_episerver_find_framework_dll_episerver_find_framework_ui_views_shared_module_master.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in C:\Projects\Kolumbus\Main\Kolumbus.Web\EPiServerFindEmbeddedResources\EPiServer.Find.Framework.dll\EPiServer.Find.Framework.UI.Views.Shared.Module.Master:46 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +131 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +150 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +249 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +150 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +249 System.Web.UI.Page.Render(HtmlTextWriter writer) +40 System.Web.Mvc.ViewPage.Render(HtmlTextWriter writer) +65 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +150 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5363
It works again when you turn Glimpse off in /glimpse.axd though so you can still use glimpse on your site. Just not on the Find admin views.
I just had a chat with Anthony and he pointed out that actually there is a workaround for Find admin module:
<runtimePolicies>
<uris>
<add regex=".*/find.*"/>
</uris>
</runtimePolicies>
</glimpse>
This will backlisting everything under "find" location. More info under "URIs":
https://github.com/Glimpse/Glimpse/wiki/Configuration
We are trying to use Glimpse (http://getglimpse.com) with our EPiServer 7 CMS, but it consistently fails with a NullReferenceException in the PageUrl method inside the UrlExtensions class. With some help from .NET Reflector, I think I understand why:
This is a real showstopper, since we depend heavily on PageUrl. Is there any way we can work around this?
