Mobile Channel is not installed on my website
Hi frdz,
i start working on this episerver site, but i didn't found how to display the page in mobile view (i.e channel) , Please give a example to understand to do it, since i try to use Mobile Pack but it is not working .Please provide e-bbok to work with episerver
#72722
Jun 27, 2013 9:25
If you don't see a mobile channel in edit mode you can double check is display mode "installed".
1. Check do you have class derived from DisplayChannel somewhere in your codebase:
public class MobileChannel : DisplayChannel
    public const string Name = "mobile";
    public override string ChannelName
        get
            return Name;
    public override string ResolutionId
        get
            return typeof(IphoneVerticalResolution).FullName;
    public override bool IsActive(HttpContextBase context)
        return context.GetOverriddenBrowser().IsMobileDevice;
2. Also if you would like to provide various screen sizes for editors you can do in code as well:
public class IpadHorizontalResolution : DisplayResolutionBase
    public IpadHorizontalResolution() : base("/resolutions/ipadhorizontal", 1024, 768)
public class IpadVerticalResolution : DisplayResolutionBase
    public IpadVerticalResolution() : base("/resolutions/ipadvertical", 768, 1024)
#72764
Jun 28, 2013 7:19
Thanks for giving code. But i didn't understood under which hive this file is existing to modify the class .
#72861
Jul 02, 2013 9:37
Just add those classes to the project (if you don't have already) and compile the solution. Location and namespace of the files are not important.
#72868
Jul 02, 2013 10:11
I sugest you download and install the demo templates for episerver and have a look. They have implemented channels in that project.
For MVC http://world.episerver.com/Download/Items/EPiServer-CMS/EPiServer-7---CMS/EPiServer-7-MVC-Templates/
For WebForms they will be able to install from Deployment Center as a website. You will be able to open both template packages with VS2012 or 2010
Also have a look in this section on world: http://world.episerver.com/Documentation/CMS/
#72869
Jul 02, 2013 10:14
