Get current page from block
Hi all,
My block:
    public class MyBlock : BlockData
        [EditorDescriptor(EditorDescriptorType = typeof(MyBlockPageEditorDescriptor))]
        public virtual string Test { get; set; }
    [EditorDescriptorRegistration(TargetType = typeof(int), UIHint = "TestPageMultiple")]
    public class MyPageEditorDescriptor : EditorDescriptor
            SelectionFactoryType = typeof(MyPageSelectionFactory);
            ClientEditingClass = "epi.cms.contentediting.editors.SelectionEditor";
    public class MyPageSelectionFactory : ISelectionFactory
        public IEnumerable<ISelectItem> GetSelections(ExtendedMetadata metadata)
            ///TODO
How I can get current page which call myblock (In TODO)?I need it because I want to set different information in dropdown property.
#72677
Jun 26, 2013 14:48
I try to use
 var pageBase = HttpContext.Current.Handler as EPiServer.PageBase;
(In TODO) but it return null.
#72679
Edited, Jun 26, 2013 15:16
Are you using MVC or WebForms?
In MVC it does not work with HttpContext.Current.Handler as EPiServer.PageBase
#72681
Jun 26, 2013 15:53
I using WebForms.
#72699
Jun 26, 2013 16:33
Then Andrey's answer should be quite good:
if(pageBase != null) {
    var currentPage = pageBase.CurrentPage;
#72700
Jun 26, 2013 16:35
        var pageBase = HttpContext.Current.Handler as EPiServer.PageBase; // it return null
Any idea how to get page which load myblock at moment ?
#72701
Jun 26, 2013 16:41
Sorry I missed that part that you wanted to find it in your SelectionFactory.
I don't think you're supposed to base your selection on surroundings like that.
Specially if it's a Shared Block since they can be placed on any Page and multiple Pages.
What are you trying to accomplish?
#72703
Edited, Jun 26, 2013 16:48
So my task is:
1. Create block with dynamic dropdown property.
I found how to create dropdown property http://world.episerver.com/Blogs/Linus-Ekstrom/Dates/2012/9/EPiServer-7-Configuring-editors-for-your-properties/
now I need to implement next functionality:
I use this block on two page (for example: on Article page and on News page)
When I go in edit view on article page I need that dropdown property has some value.
When I go in edit view on news page I need that dropdown property use another value (different that in article)
As you see dropdown property values has depends which page it use.
I thought it would be good to do it when the data is generated for that dropdown property.
So I in edit view on article page - generate data which need for article page
if I in edit view on news page - generate data which needs for news page. (generate data - values for dropdown property).
that's my goal.
#72783
Edited, Jun 28, 2013 16:59
You mean that the data should be different depending on which Page Type the Page is? Not depending on any value on the Page itself?
#72784
Jun 28, 2013 17:02
yes, but in my case, I have category property in article page and category property in news page, They also play a role in generate data for dropdown property in block.
there is also a dependence on values of the page
#72787
Edited, Jun 28, 2013 17:46
For example How I thought about implementation it:
                var pageType = typeof (page.CurrentPage);
                if (page == ArticlePage.GetType())
                    var property = ((ArticlePage) page.CurrentPage).SomeProperty;
                    // generate data for dropdown
                if (page == NewsPage.GetType())
                    var property = ((NewsPage) page.CurrentPage).SomeProperty;
#72788
Edited, Jun 28, 2013 17:56
That would work when you are visiting a page, not when you are in Edit Mode.
The HttpHandler something else in edit mode.
Try to find some inspiration on http://joelabrahamsson.com/limiting-content-and-page-reference-properties-to-values-of-a-specific-type-in-episerver-cms/
the tricky part would be to add information from the page to the block which in turn can tell the attribute.
#72789
Jun 28, 2013 18:06
Thanks Alf. I found this article http://joelabrahamsson.com/hiding-episervers-standard-category-property/.
So I use this code in
        dynamic contentMetadata = metadata;
        var ownerContent = contentMetadata.OwnerContent as IContent;
        var ownerType = ownerContent.GetType().BaseType;
It works in edit mode.
#72800
Edited, Jun 30, 2013 16:14
