Simple Tab question
This is probably a very trivial question but I can't find out how to change the order of tabs under Forms Editing. When you use
[Display(
Order = 200,
GroupName = "foo")
on some property the order basically says where that property should be displayed under the "foo"-tab. But lets say I have three tabs right now  that is displayed from left to right like this:
Content        Foo          Boo
And I would like them to be ordered like this:
Content        Boo         Foo
How do I accomplish that?
#70926
May 03, 2013 14:58
Hey,
In Episerver Admin mode go to: Config -> Edit Tabs.
Here you can change the order of tabs.
You can also do this programmatically, see the following post: http://world.episerver.com/Modules/Forum/Pages/thread.aspx?id=62513
H
owever, this method is buggy if you don't use Episerver 7.1 i believe (Sort index won't be updated if you change it in your codebase)
Greetings, Martijn
#70927
May 03, 2013 15:22
Thanks Martijn, worked like a charm.
#70928
May 03, 2013 15:25
