Html.EditAttributes triggers autosave
I've got a block called QuickFacts, it's not used as a regular block but instead used as a composite property (AvailableInEditMode=false) on a page. The block has two strings, a few ints and a DateTime as properties.
In my view I display it using a paragraph and Html.EditAttributes so it's easy for the publisher to update the information.
    <p @Html.EditAttributes(m => m.CurrentPage.QuickFacts)>
                    @if (Html.HasValue(Model.CurrentPage.QuickFacts.ConstructionStart))
                        @Html.TranslateSafe("/views/pdprojectpage/quickfacts/constructionstart")<text>:</text>
                        @Html.PropertyFor(m => m.CurrentPage.QuickFacts.ConstructionStart)<br />
.... </p>
But for some reason as soon as I'm in edit mode and click the area to edit my properties, EPiServer thinks I changed some value and auto saves the page and says there is "Changes to be published". I'm sure no values has been changed.
Anyone know why EPiServer thinks that I changed the page?
#71349
May 16, 2013 10:30
Is it 7.0 or 7.1? As far as I remember, there was a problem with DateTimePicker widget which triggers change event on initializing. I believe that it was fixed on 7.1.
#71483
May 20, 2013 22:13
It's 7.1. So I guess it's not fixed.
Do you remember if you've seen any information about this, Duong?
#71789
May 29, 2013 10:51
