Edit panel plugin using MVC
I am trying to build a EditPanel plugin for CMS7 build with MVC. I'm using this example http://world.episerver.com/Blogs/Paul-Smith/Dates1/2011/8/Creating-EPiServer-AdminEdit-Plug-ins-using-MVC/ as a beginning for the plugin.
My first question, where will the EditPanel be placed in the new edit interface?
My second question is, is it possible to build a EditPanel plugin at all? Instead of the new inteface I try to use the "old style" interface (/episerver/cms/edit) If I sets the GuiPluginArea to AdminMenu in my controller it works fine but is I set it as EditPanel I got the error "Only UserControls are supported on a tabstrip". Is there anyone that have any idea how to solve this or have a nice code example to help me?
// Andreas
#71177
May 13, 2013 11:57
Hi, Andreas, we have used an IFrameComponent to create a plugin in edit mode.
It appears where the blocks tree is placed. I can't test it on MVC now, but perhaps this will help you:
    [IFrameComponent(Url = "modules/xx/yy.aspx",
        ReloadOnContextChange = true,
        PlugInAreas = "/episerver/cms/assets",
        Categories = "cms",
        MinHeight = 400,
        MaxHeight = 650,
        SortOrder = 201,
        Title = "Title",
        Description = "Description",
        IsAvailableForUserSelection = true
    public partial class UrlTab : SystemPageBase
Perhaps you can decorate the controller with this class instead.
#71232
May 14, 2013 16:29
Thanks, it works without any changes.
// Andreas
#71320
May 15, 2013 14:28
