Dynamic Dropdown properties
Hi.
I need to create drop down property in my pagetype but items in dropdown property generated dynamically.
How impl that functionality?
#71325
May 15, 2013 17:03
Take a look at this example: EPiServer 7: Configuring editors for your properties.
Frederik
#71326
May 15, 2013 17:15
Thanks, nice functionality .
Thanks for answer.
#71329
May 15, 2013 23:40
Frederik Vig after creating that functionality I cant open my page in edit mode ? In What a problem?
Thanks advance.
#71381
May 16, 2013 16:36
Open up the browser console and see if you see any JavaScript errors that might explain it.
Frederik
#71382
May 16, 2013 16:38
#71387
May 16, 2013 16:55
when I comment code, this error is disappeared
#71390
May 16, 2013 17:06
Could you try in Firefox using Firebug? I think there are some more errors that'll show up there.
Frederik
#71391
May 16, 2013 17:06
No errors in firefox but cms shows that we still go to edit mode http://screencast.com/t/DLBNmrmcU
#71392
May 16, 2013 17:11
Console shows only this info http://screencast.com/t/yb6lCnw4y
#71393
May 16, 2013 17:12
And any exception in Visual Studio in debug mode
#71394
May 16, 2013 17:24
Per Nergård (MVP)
I think I got some wierd error when I didn't have strings for both value and text properties on the selectitems.
#71408
May 17, 2013 9:18
I copied the example.
    public class LanguageSelectionFactory : ISelectionFactory
        public IEnumerable<ISelectItem> GetSelections(ExtendedMetadata metadata)
            var languages = new List<SelectItem>();
            languages.Add(new SelectItem() { Value = "EN", Text = "English" });
            languages.Add(new SelectItem() { Value = "SW", Text = "Swahili" });
            languages.Add(new SelectItem() { Value = "PF", Text = "French Polynesia" });
            return languages;
#71450
May 18, 2013 23:41
I have a hard time seing how setting up a selection list would cause cross site scripting issues. Have you investigating the code that accesses the remote site (http://ct1.addthis.com)? Is this something in your templates, content or UI an extension?
#71455
May 20, 2013 9:13
I found the problem. In examples
ClientEditingClass = "epi.cms.contentediting.editors.CheckBoxListEditor";
replace with
      ClientEditingClass = "epi.cms.contentediting.editors.SelectionEditor";
and it work..
#71536
May 22, 2013 10:33
