DDS error : Invalid column name
I have been having trouble recently with an error related to the DDS. I have a class stored in the dds and marked to auto map, with several values already stored.
When I added an extra bool property to this class, the application fails with a message saying that the column name does not exist.
Is this a bug or am I missing something?
Jon
#71061
May 08, 2013 10:42
P.S. This error does not occur straight away - the site can run for quite a while before it suddenly happens accross all servers
#71062
May 08, 2013 10:46
Can you check time by time DB records for that store:
select * from tblBigTableStoreInfo i inner join tblBigTableStoreConfig c on c.pkId = i.fkStoreId where c.storename = '{STORE NAME}'
Are all servers running with the same DDS entity structure (I mean are all servers running the same version of app)? If entity is marked as auto remapping - maybe some app version is syncing old version?
#71100
May 09, 2013 22:26
