Block dissapearing
Has anyone experienced the case where a block suddenly vanishes from a page? We have seen it a few times but can't seem to find what is causing it. The pages where the block was added to have not been modified but the block needs to be readded to the page and then it works again.
#71338
May 16, 2013 8:44
I have seen it a few times too, and don't know what causes it either.
#71347
May 16, 2013 10:23
that is great news :) It is happening a lot right now.
#71361
May 16, 2013 12:49
Do you have an environment where multiple developers use the same EPiServer SQL database?
#71415
May 17, 2013 10:51
We did initially but not anymore. However, the test server is a clean install with no content (everything has been built up from scratch). There is only one IIS instance of the site.
#71424
May 17, 2013 13:15
Ok, we do have such an environment (multiple developers, same database) so i hoped that could have been it, but i guess it isn't. Also, we only have seen this issue a few times (less then 10 times), so i can't be 100% sure we have exactly the same problem.
I hope you can find a solution for this!
Good luck
#71426
May 17, 2013 13:49
There is a known bug that was fixed in Patch 1 for EPiServer 7:
93633 Blocks in ContentAreas are removed from the content area when the block is changed in code
#71434
May 17, 2013 16:12
Thanks Per Bjurnstrom, it just happened again and indeed after changing the block-code.
#71436
May 17, 2013 16:25
hmm could be that. But it happened in our test server. it happened latest time quite right after we updated to the latest version. First time i dont believe we changed any code but I can check it out, we just updated to 7.2.
Thanks Per, I was going to check the buglist, honest ;)
#71451
May 19, 2013 9:52
