Using blocks as containers
Is it possible in EPiServer 7 to use blocks as containers? As in a a block that has no renderer just like a normal page container.
I have created a block in my site which inherits directly from EPiServer.Core.BlockData. There are no renderes at all for this block in my site.
To make sure of this, I have also changed my block preview page to be a rendered for a class above BlockData so that it should not be used for my 'container' block.
public partial class BlockPreview : PreviewPage, IRenderTemplate<SiteBlockBase>
Now in theory, there are no renders at all available for my block, however when viewing the block in EPiServer, the "Toggle preview" button is still available and on previewing, a error is thrown
Content with id '97_345' is of type 'Castle.Proxies.NewsBlockProxy' which does not inherit required type 'EPiServer.Core.PageData'
Is it possible to use blocks like this in EPiServer or should I continue using page containers to implement this type of functionality?
Adam
#71176
May 13, 2013 11:39
Hi Adam,
Can what you're trying to achieve be achieved using a block which has a property of type ContentArea? Allowing you to place other blocks within the block and render them as you choose. Or perhaps the Block Folder more what you're going for?
I may be missing something but I think one or other of those solutions would suit your needs.
Cheers,
Kev
#71200
May 13, 2013 17:33
