Restart site after addon upgrade/install is not sufficient
When I upgraded EPiServer UI to 7.1 on an empty site, a simple click on the "Restart site" was not enough. It gave me YSOD screen. When I restarted the apppool, the application went up again.
Is this the recommended procedure?
The Restart Site button is still there after I press it and the page reloads so it seems that it doesn't have any effect.
Ps. I had the same issue when installing the ImageVault.AddOn.EPiCMS7 addon. It adds/removes item in the navigation toolbar and those changes aren't effective until a apppool restart. Ds.
#71582
May 23, 2013 11:38
Hmmm... Restart site will actually touch web.config and that in turn will recycle the app pool. If you're in a dev env you need to make sure you have web.config checked out. But I think you will get an error unless it is writable... Strange.
#71585
May 23, 2013 15:42
Restart button should restart the site (obviously) and it should be enough.
Could you provide more details from your YSOD screen?
In addition you can enable Debug logging for add-on system by adding following logger and appender in your EPiServerLog.config:
<log4net>
  <appender name="debugPackagingFileLogAppender" type="log4net.Appender.RollingFileAppender" >
    <file value="App_Data\EPiServer.Packaging.Debug.log" />
    <encoding value="utf-8" />
    <staticLogFileName value="true"/>
    <datePattern value=".yyyyMMdd.'log'" />
    <rollingStyle value="Date" />
    <threshold value="Debug" />
    <lockingModel type="log4net.Appender.FileAppender+MinimalLock" />
    <appendToFile value="true" />
    <layout type="log4net.Layout.PatternLayout">
      <conversionPattern value="%date [%thread] %level %logger: %message%n" />
    </layout>
  </appender>
  <logger name="EPiServer.Packaging" additivity="false">
    <level value="Debug" />
    <appender-ref ref="debugPackagingFileLogAppender" />
  </logger>
</log4net>
Also you can use Firebug/Chrome dev tools to inspect network calls and get more information about failed requests if any.
#71625
May 24, 2013 11:57
Ah, found the cause of the problem. The modify rights for the IIS_IUSRS group had been removed. Added Modify rights to the web.config file and it worked like a charm again.
Thanks for the hint :)
#71645
May 24, 2013 22:38
