Error when using ContentRepository.DeleteChildren
Hello,
A little background info first: We have a utlility that is going to be used to populate a bunch of pages programatically into episerver once we launch (basically a migration from our old cms and content) - I have developed a small tool to delete all the pages under our start page, so we can keep re-testing our import functionality.  I am getting a weird error when trying to delete, note that there are a LOT of pages being imported (in a heirarchy) - each branch may contain about 50-100 pages (heirarchichly) each, and about 116 "branches" under our start page.
When finding our start page reference and then issuing a
ContentRepository.DeleteChildren(ContentReference.StartPage)
or even when iterating through each of the children and deleting them individually like
ContentRepository.Delete(page.ContentLink, true, AccessLevel.NoAccess)
I am receiving an error after about 5-8 min of runtime that is the following (mind that this error is coming back from my ajax routine that runs this):
"{"Message":"This SqlTransaction has completed; it is no longer usable.","StackTrace":" at System.Data.SqlClient.SqlTransaction.ZombieCheck()\r\n at System.Data.SqlClient.SqlTransaction.Rollback()\r\n at EPiServer.Data.Providers.ConnectionContext.RollbackTransaction()\r\n at EPiServer.Data.Providers.ConnectionScope.Dispose()\r\n at EPiServer.Data.Providers.SqlDatabaseHandler.\u003c\u003ec__DisplayClass7`1.\u003cExecuteTransaction\u003eb__6()\r\n at EPiServer.Data.Providers.SqlDeadlockRetryPolicy.Execute[TResult](Boolean isInTransaction, Func`1 method)\r\n at EPiServer.DataFactory.DeleteChildren(ContentReference contentLink, Boolean forceDelete, AccessLevel access)\r\n at PhoenixWeb.Util.Scaffold.ScaffoldUtil.DeleteAllLocalSites() in C:\\Sites\\PhoenixCMS\\PhoenixWeb\\Util\\Scaffold\\ScaffoldUtil.cs:line 116\r\n at PhoenixWeb.WebServices.ScaffoldUtility.DeleteAllPagesBelowSplashPage() in C:\\Sites\\PhoenixCMS\\PhoenixWeb\\WebServices\\ScaffoldUtility.asmx.cs:line 62","ExceptionType":"System.InvalidOperationException"}"
Anyone have any clue?  Also an unrelated but possibly related? issue that is also occuring is that on my local instance most of the time it takes quite awhile for the edit mode to start up.  Meaning, that if i build, and then go to CMS -> Edit - it takes about 2-3 min to actually load the edit mode - I know that it is probably compiling for the first time, but it never used to take this long.  Could it be the amount of pages?
#71255
May 14, 2013 23:40
I also might add, that after testing more with the iterating through each page under the start page and issuing a Delete on it (which in turn deletes the children), this seems to not throw the sql transaction error above.  But, it does take an extraordinary amount of time - I'm sure there's lots going on with the Delete routine, but is this a limitation of episerver api? I'm not sure any other way i could speed up the delete process... Let's say the site has a total of about 10,000 -15,000 pages, it takes about 3+ hours to delete it all... IF the delete actually works
#71256
May 14, 2013 23:46
The excpetion indicates the operation has taken long time to operate and the connection is closed during dispose, I'm going to report a bug for it. But the DeleteChildren operatoin should be fast. If you are familiar with sql DB you can run [editDeleteChilds] with params startpage and 1 in the sql script with execution plan to find out why it takes long time.
#71316
May 15, 2013 13:59
Im re-bumping this, because I'm having issues programatically deleting a big branch of pages.  I have one parent page, and it has a small amount of children, but one of the children has like 200+ pages (archived stuff) and I keep receiving this error... I can't even remove it from the recycle bin.
I ran exec editDeleteChilds 2, 1 in SQL (2 is the ID of the recycle bin) so i could delete the children of the recycle bin, the stored proc runs very fast, and the execution plan looks ok... however, it appears nothing actually happened.  pages are still showing in my recycle bin and nothing was removed.
#72491
Jun 18, 2013 19:03
I think you need restart the web app (it is cached data). (run iisreset or touch the web config).
#72500
Jun 19, 2013 7:44
So i ran exec editDeleteChilds 2, 1 again (THIS time on the right Epi DB) - and it removed all trash bin content in 2m09s - mind that there was at least 4000+ pages in the trash.  I've included the execution plan below (xml format) in case you were interested.  I'm not sure why running this from the DB takes 2 min, which for that amount of pages is probably acceptable.... but running ContentRepository.DeleteChildren(ContentReference.WasteBasket) from the API gives me that Zombie error... any ideas?
<?xml version="1.0" encoding="utf-16"?>
<ShowPlanXML xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Version="1.1.1" Build="10.0.5512.0" xmlns="http://schemas.microsoft.com/sqlserver/2004/07/showplan">
  <BatchSequence>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="6" StatementEstRows="7283.08" StatementId="1" StatementOptmLevel="TRIVIAL" StatementSubTreeCost="0.107725" StatementText="INSERT INTO #pages (pkID)
	SELECT
		fkChildID
	FROM
		tblTree
	WHERE fkParentID=@PageID
" StatementType="INSERT" QueryHash="0x781D88A29EB37498" QueryPlanHash="0x979D69AAC039FEE3">
          <StatementSetOptions ANSI_NULLS="true" ANSI_PADDING="true" ANSI_WARNINGS="true" ARITHABORT="true" CONCAT_NULL_YIELDS_NULL="true" NUMERIC_ROUNDABORT="false" QUOTED_IDENTIFIER="true" />
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="16" CompileTime="2" CompileCPU="2" CompileMemory="128">
            <RelOp AvgRowSize="9" EstimateCPU="0.00728308" EstimateIO="0.0693211" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7283.08" LogicalOp="Insert" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Insert" EstimatedTotalSubtreeCost="0.107725">
              <OutputList />
              <RunTimeInformation>
                <RunTimeCountersPerThread Thread="0" ActualRows="7770" ActualEndOfScans="1" ActualExecutions="1" />
              </RunTimeInformation>
              <Update DMLRequestSort="true">
                <Object Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Index="[PK__#pages____40A359E36921665A]" />
                <SetPredicate>
                  <ScalarOperator ScalarString="[#pages].[pkID] = [PhoenixCMS_RC].[dbo].[tblTree].[fkChildID],[#pages].[PageGUID] = NULL">
                    <ScalarExpressionList>
                      <ScalarOperator>
                        <MultipleAssign>
                          <Assign>
                            <ColumnReference Table="[#pages]" Column="pkID" />
                            <ScalarOperator>
                              <Identifier>
                                <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblTree]" Column="fkChildID" />
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                          <Assign>
                            <ColumnReference Table="[#pages]" Column="PageGUID" />
                            <ScalarOperator>
                              <Const ConstValue="NULL" />
                            </ScalarOperator>
                          </Assign>
                        </MultipleAssign>
                      </ScalarOperator>
                    </ScalarExpressionList>
                  </ScalarOperator>
                </SetPredicate>
                <RelOp AvgRowSize="11" EstimateCPU="0.000728308" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7283.08" LogicalOp="Top" NodeId="1" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.031121">
                  <OutputList>
                  </OutputList>
                  <Top RowCount="true" IsPercent="false" WithTies="false">
                    <TopExpression>
                      <ScalarOperator ScalarString="(0)">
                        <Const ConstValue="(0)" />
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="11" EstimateCPU="0.00816839" EstimateIO="0.0222243" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7283.08" LogicalOp="Clustered Index Seek" NodeId="2" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0303927" TableCardinality="505496">
                      <OutputList>
                      </OutputList>
                      <IndexScan Ordered="true" ScanDirection="FORWARD" ForcedIndex="false" ForceSeek="false" NoExpandHint="false">
                        <DefinedValues>
                          <DefinedValue>
                          </DefinedValue>
                        </DefinedValues>
                        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblTree]" Index="[PK_tblTree]" IndexKind="Clustered" />
                        <SeekPredicates>
                          <SeekPredicateNew>
                            <SeekKeys>
                              <Prefix ScanType="EQ">
                                <RangeColumns>
                                  <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblTree]" Column="fkParentID" />
                                </RangeColumns>
                                <RangeExpressions>
                                  <ScalarOperator ScalarString="[@PageID]">
                                    <Identifier>
                                      <ColumnReference Column="@PageID" />
                                    </Identifier>
                                  </ScalarOperator>
                                </RangeExpressions>
                              </Prefix>
                            </SeekKeys>
                          </SeekPredicateNew>
                        </SeekPredicates>
                      </IndexScan>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
            <ParameterList>
              <ColumnReference Column="@PageID" ParameterCompiledValue="(2)" ParameterRuntimeValue="(2)" />
            </ParameterList>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="7" StatementEstRows="7770" StatementId="2" StatementOptmLevel="FULL" StatementSubTreeCost="0.944053" StatementText="UPDATE #pages
		SET PageGUID = tblPage.PageGUID
	FROM tblPage INNER JOIN #pages ON #pages.pkID=tblPage.pkID
" StatementType="UPDATE" QueryHash="0x27ECAFB9E60E8295" QueryPlanHash="0x698011D90C8CE69E">
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="3112" CachedPlanSize="40" CompileTime="29" CompileCPU="29" CompileMemory="304">
            <RelOp AvgRowSize="9" EstimateCPU="0.00777" EstimateIO="0.192432" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Update" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="0.944053">
              <OutputList />
              <Update DMLRequestSort="false">
                <SetPredicate>
                  <ScalarOperator ScalarString="[#pages].[PageGUID] = [PhoenixCMS_RC].[dbo].[tblContent].[ContentGUID]">
                      <ScalarOperator>
                        <MultipleAssign>
                          <Assign>
                            <ScalarOperator>
                              <Identifier>
                                <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="ContentGUID" />
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                        </MultipleAssign>
                      </ScalarOperator>
                  </ScalarOperator>
                </SetPredicate>
                <RelOp AvgRowSize="27" EstimateCPU="0.000777" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Top" NodeId="1" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.743851">
                  <OutputList>
                  </OutputList>
                    <TopExpression>
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="27" EstimateCPU="0.407878" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Inner Join" NodeId="2" Parallel="false" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="0.743074">
                      <OutputList>
                      </OutputList>
                      <MemoryFractions Input="1" Output="1" />
                      <Hash>
                        <DefinedValues />
                        <HashKeysBuild>
                        </HashKeysBuild>
                        <HashKeysProbe>
                          <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="pkID" />
                        </HashKeysProbe>
                        <RelOp AvgRowSize="11" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="3" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                          <OutputList>
                          </OutputList>
                          <IndexScan Ordered="true" ForcedIndex="false" NoExpandHint="false">
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                          </IndexScan>
                        </RelOp>
                        <RelOp AvgRowSize="27" EstimateCPU="0.0743124" EstimateIO="0.229051" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Index Scan" NodeId="4" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.303363" TableCardinality="67414">
                          <OutputList>
                          </OutputList>
                            <RunTimeCountersPerThread Thread="0" ActualRows="67414" ActualEndOfScans="1" ActualExecutions="1" />
                          <IndexScan Ordered="false" ForcedIndex="false" ForceSeek="false" NoExpandHint="false">
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ContentGUID]" IndexKind="NonClustered" />
                          </IndexScan>
                        </RelOp>
                      </Hash>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="14" StatementEstRows="7942.77" StatementId="3" StatementOptmLevel="FULL" StatementSubTreeCost="3.45219" StatementText="UPDATE
	    tblPage
	SET
	    fkParentID = NULL,
	    ArchivePageGUID=NULL
	WHERE
	    pkID IN ( SELECT pkID FROM #pages )
" StatementType="UPDATE" QueryHash="0x5A4ACC6AA0B007E9" QueryPlanHash="0xA3C647E1EA5036D5">
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="48" CompileTime="26" CompileCPU="26" CompileMemory="872">
            <RelOp AvgRowSize="9" EstimateCPU="0.0317711" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="15885.5" LogicalOp="Sequence" NodeId="1" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="3.45219">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="15540" ActualEndOfScans="1" ActualExecutions="1" />
              <Sequence>
                <RelOp AvgRowSize="9" EstimateCPU="0.000844694" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="15885.5" LogicalOp="Eager Spool" NodeId="2" Parallel="false" PhysicalOp="Row Count Spool" EstimatedTotalSubtreeCost="1.71021">
                  <OutputList />
                    <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="15540" ActualEndOfScans="1" ActualExecutions="1" />
                  <RowCountSpool>
                    <RelOp AvgRowSize="9" EstimateCPU="0.0119142" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="15885.5" LogicalOp="Split" NodeId="3" Parallel="false" PhysicalOp="Split" EstimatedTotalSubtreeCost="3.41705">
                      <OutputList />
                      <Split>
                        <DefinedValues>
                          <DefinedValue>
                            <ColumnReference Column="Act1024" />
                          </DefinedValue>
                        </DefinedValues>
                        <ActionColumn>
                        </ActionColumn>
                        <RelOp AvgRowSize="9" EstimateCPU="0.0238283" EstimateIO="1.80013" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7942.77" LogicalOp="Update" NodeId="4" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="3.40513">
                          <OutputList />
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[PK_tblContent]" IndexKind="Clustered" />
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_fkParentID]" IndexKind="NonClustered" />
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ArchiveContentGUID]" IndexKind="NonClustered" />
                            <SetPredicate>
                              <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContent].[fkParentID] = [Expr1006],[PhoenixCMS_RC].[dbo].[tblContent].[ArchiveContentGUID] = [Expr1007]">
                                  <ScalarOperator>
                                    <MultipleAssign>
                                      <Assign>
                                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="fkParentID" />
                                        <ScalarOperator>
                                          <Identifier>
                                            <ColumnReference Column="Expr1006" />
                                          </Identifier>
                                        </ScalarOperator>
                                      </Assign>
                                      <Assign>
                                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="ArchiveContentGUID" />
                                        <ScalarOperator>
                                          <Identifier>
                                            <ColumnReference Column="Expr1007" />
                                          </Identifier>
                                        </ScalarOperator>
                                      </Assign>
                                    </MultipleAssign>
                                  </ScalarOperator>
                              </ScalarOperator>
                            </SetPredicate>
                            <RelOp AvgRowSize="39" EstimateCPU="0.000794277" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7942.77" LogicalOp="Compute Scalar" NodeId="5" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="1.58118">
                              <OutputList>
                                <ColumnReference Column="Expr1020" />
                                <ColumnReference Column="Expr1021" />
                              </OutputList>
                              <ComputeScalar>
                                <DefinedValues>
                                  <DefinedValue>
                                    <ScalarOperator ScalarString="[Expr1020]">
                                      <Identifier>
                                      </Identifier>
                                    </ScalarOperator>
                                  </DefinedValue>
                                  <DefinedValue>
                                    <ScalarOperator ScalarString="[Expr1021]">
                                      <Identifier>
                                      </Identifier>
                                    </ScalarOperator>
                                  </DefinedValue>
                                </DefinedValues>
                                <RelOp AvgRowSize="39" EstimateCPU="0.000794277" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7942.77" LogicalOp="Compute Scalar" NodeId="6" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="1.58118">
                                  <OutputList>
                                  </OutputList>
                                  <ComputeScalar>
                                    <DefinedValues>
                                      <DefinedValue>
                                        <ScalarOperator ScalarString="CASE WHEN [Expr1014] THEN (0) ELSE (1) END">
                                          <IF>
                                            <Condition>
                                              <ScalarOperator>
                                                <Identifier>
                                                  <ColumnReference Column="Expr1014" />
                                                </Identifier>
                                              </ScalarOperator>
                                            </Condition>
                                            <Then>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Then>
                                            <Else>
                                              <ScalarOperator>
                                                <Const ConstValue="(1)" />
                                              </ScalarOperator>
                                            </Else>
                                          </IF>
                                        </ScalarOperator>
                                      </DefinedValue>
                                      <DefinedValue>
                                        <ScalarOperator ScalarString="CASE WHEN [Expr1015] THEN (0) ELSE (1) END">
                                          <IF>
                                            <Condition>
                                              <ScalarOperator>
                                                <Identifier>
                                                  <ColumnReference Column="Expr1015" />
                                                </Identifier>
                                              </ScalarOperator>
                                            </Condition>
                                            <Then>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Then>
                                            <Else>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Else>
                                          </IF>
                                        </ScalarOperator>
                                      </DefinedValue>
                                    </DefinedValues>
                                    <RelOp AvgRowSize="32" EstimateCPU="0.000794277" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7942.77" LogicalOp="Compute Scalar" NodeId="7" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="1.58038">
                                      <OutputList>
                                      </OutputList>
                                      <ComputeScalar>
                                        <DefinedValues>
                                          <DefinedValue>
                                            <ScalarOperator ScalarString="NULL">
                                            </ScalarOperator>
                                          </DefinedValue>
                                          <DefinedValue>
                                            </ScalarOperator>
                                          </DefinedValue>
                                        </DefinedValues>
                                        <RelOp AvgRowSize="12" EstimateCPU="0.000794277" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7942.77" LogicalOp="Top" NodeId="8" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="1.57959">
                                          <OutputList>
                                          </OutputList>
                                            <TopExpression>
                                              </ScalarOperator>
                                            </TopExpression>
                                            <RelOp AvgRowSize="12" EstimateCPU="0.164263" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Inner Join" NodeId="10" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="1.57879">
                                              <OutputList>
                                              </OutputList>
                                              <Merge ManyToMany="false">
                                                <InnerSideJoinColumns>
                                                </InnerSideJoinColumns>
                                                <OuterSideJoinColumns>
                                                  <ColumnReference Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Column="pkID" />
                                                </OuterSideJoinColumns>
                                                <Residual>
                                                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContent].[pkID]=[tempdb].[dbo].[#pages].[pkID]">
                                                    <Compare CompareOp="EQ">
                                                      <ScalarOperator>
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                      <ScalarOperator>
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                    </Compare>
                                                  </ScalarOperator>
                                                </Residual>
                                                <RelOp AvgRowSize="11" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="11" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                                                  <OutputList>
                                                  </OutputList>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                    <Object Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Index="[PK__#pages____40A359E36921665A]" IndexKind="Clustered" />
                                                  </IndexScan>
                                                </RelOp>
                                                <RelOp AvgRowSize="12" EstimateCPU="0.0067414" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Compute Scalar" NodeId="12" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="1.3827">
                                                  <OutputList>
                                                  </OutputList>
                                                  <ComputeScalar>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                        <ScalarOperator ScalarString="CASE WHEN [PhoenixCMS_RC].[dbo].[tblContent].[fkParentID] IS NULL THEN (1) ELSE (0) END">
                                                          <IF>
                                                            <Condition>
                                                              <ScalarOperator>
        <Compare CompareOp="BINARY IS">
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Compare>
                                                              </ScalarOperator>
                                                            </Condition>
                                                            <Then>
                                                              <ScalarOperator>
                                                              </ScalarOperator>
                                                            </Then>
                                                            <Else>
                                                              <ScalarOperator>
                                                              </ScalarOperator>
                                                            </Else>
                                                          </IF>
                                                        </ScalarOperator>
                                                      </DefinedValue>
                                                      <DefinedValue>
                                                        <ScalarOperator ScalarString="CASE WHEN [PhoenixCMS_RC].[dbo].[tblContent].[ArchiveContentGUID] IS NULL THEN (1) ELSE (0) END">
                                                          <IF>
                                                            <Condition>
                                                              <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Compare>
                                                              </ScalarOperator>
                                                            </Condition>
                                                            <Then>
                                                              <ScalarOperator>
                                                              </ScalarOperator>
                                                            </Then>
                                                            <Else>
                                                              <ScalarOperator>
                                                              </ScalarOperator>
                                                            </Else>
                                                          </IF>
                                                        </ScalarOperator>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                    <RelOp AvgRowSize="31" EstimateCPU="0.0743124" EstimateIO="1.30164" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Clustered Index Scan" NodeId="13" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="1.37596" TableCardinality="67414">
                                                      <OutputList>
                                                      </OutputList>
                                                        <RunTimeCountersPerThread Thread="0" ActualRows="67199" ActualEndOfScans="0" ActualExecutions="1" />
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                      </IndexScan>
                                                    </RelOp>
                                                  </ComputeScalar>
                                                </RelOp>
                                              </Merge>
                                            </RelOp>
                                          </Top>
                                        </RelOp>
                                      </ComputeScalar>
                                    </RelOp>
                                  </ComputeScalar>
                                </RelOp>
                              </ComputeScalar>
                            </RelOp>
                          </Update>
                        </RelOp>
                      </Split>
                    </RelOp>
                  </RowCountSpool>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.000844694" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="15885.5" LogicalOp="Eager Spool" NodeId="37" Parallel="false" PhysicalOp="Row Count Spool" EstimatedTotalSubtreeCost="1.71021">
                  <OutputList />
                  <RowCountSpool PrimaryNodeId="2" />
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="15" StatementEstRows="12374.5" StatementId="4" StatementOptmLevel="FULL" StatementSubTreeCost="12.2009" StatementText="UPDATE
	    tblWorkPage
	SET
	    fkMasterVersionID=NULL,
	    PageLinkGUID=NULL,
	WHERE
	    fkPageID IN ( SELECT pkID FROM #pages )
-- VERSION DATA
	-- Delete page links, archiving and fetch data pointing to us from external pages
" StatementType="UPDATE" QueryHash="0xFF8B731D205B9C1A" QueryPlanHash="0x124D958EBA3EA3C4">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="8800" CachedPlanSize="88" CompileTime="67" CompileCPU="67" CompileMemory="1096">
            <RelOp AvgRowSize="9" EstimateCPU="0.049498" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="24749" LogicalOp="Sequence" NodeId="1" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="12.2009">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="27100" ActualEndOfScans="1" ActualExecutions="1" />
              <Sequence>
                <RelOp AvgRowSize="9" EstimateCPU="0.00128772" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="24749" LogicalOp="Eager Spool" NodeId="2" Parallel="false" PhysicalOp="Row Count Spool" EstimatedTotalSubtreeCost="6.0757">
                  <OutputList />
                    <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="27100" ActualEndOfScans="1" ActualExecutions="1" />
                  <RowCountSpool>
                    <RelOp AvgRowSize="9" EstimateCPU="0.0185618" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="24749" LogicalOp="Split" NodeId="3" Parallel="false" PhysicalOp="Split" EstimatedTotalSubtreeCost="12.1463">
                      <OutputList />
                      <Split>
                        <DefinedValues>
                          <DefinedValue>
                            <ColumnReference Column="Act1030" />
                          </DefinedValue>
                        </DefinedValues>
                        <ActionColumn>
                        </ActionColumn>
                        <RelOp AvgRowSize="9" EstimateCPU="0.049498" EstimateIO="6.97853" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.5" LogicalOp="Update" NodeId="4" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="12.1277">
                          <OutputList />
                            <RunTimeCountersPerThread Thread="0" ActualRows="13550" ActualEndOfScans="1" ActualExecutions="1" />
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[PK_tblWorkContent]" IndexKind="Clustered" />
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_ArchiveContentGUID]" IndexKind="NonClustered" />
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_ContentLinkGUID]" IndexKind="NonClustered" />
                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_fkMasterVersionID]" IndexKind="NonClustered" />
                            <SetPredicate>
                              <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[fkMasterVersionID] = [Expr1006],[PhoenixCMS_RC].[dbo].[tblWorkContent].[ContentLinkGUID] = [Expr1007],[PhoenixCMS_RC].[dbo].[tblWorkContent].[ArchiveContentGUID] = [Expr1008]">
                                  <ScalarOperator>
                                    <MultipleAssign>
                                      <Assign>
                                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="fkMasterVersionID" />
                                        <ScalarOperator>
                                          <Identifier>
                                          </Identifier>
                                        </ScalarOperator>
                                      </Assign>
                                      <Assign>
                                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="ContentLinkGUID" />
                                        <ScalarOperator>
                                          <Identifier>
                                          </Identifier>
                                        </ScalarOperator>
                                      </Assign>
                                      <Assign>
                                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="ArchiveContentGUID" />
                                        <ScalarOperator>
                                          <Identifier>
                                            <ColumnReference Column="Expr1008" />
                                          </Identifier>
                                        </ScalarOperator>
                                      </Assign>
                                    </MultipleAssign>
                                  </ScalarOperator>
                              </ScalarOperator>
                            </SetPredicate>
                            <RelOp AvgRowSize="59" EstimateCPU="0.00123745" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.5" LogicalOp="Compute Scalar" NodeId="5" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="5.09967">
                              <OutputList>
                                <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="pkID" />
                                <ColumnReference Column="Expr1024" />
                                <ColumnReference Column="Expr1025" />
                                <ColumnReference Column="Expr1026" />
                              </OutputList>
                              <ComputeScalar>
                                <DefinedValues>
                                  <DefinedValue>
                                    <ScalarOperator ScalarString="[Expr1024]">
                                      <Identifier>
                                      </Identifier>
                                    </ScalarOperator>
                                  </DefinedValue>
                                  <DefinedValue>
                                    <ScalarOperator ScalarString="[Expr1025]">
                                      <Identifier>
                                      </Identifier>
                                    </ScalarOperator>
                                  </DefinedValue>
                                  <DefinedValue>
                                    <ScalarOperator ScalarString="[Expr1026]">
                                      <Identifier>
                                      </Identifier>
                                    </ScalarOperator>
                                  </DefinedValue>
                                </DefinedValues>
                                <RelOp AvgRowSize="59" EstimateCPU="0.00123745" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.5" LogicalOp="Compute Scalar" NodeId="6" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="5.09967">
                                  <OutputList>
                                  </OutputList>
                                  <ComputeScalar>
                                    <DefinedValues>
                                      <DefinedValue>
                                        <ScalarOperator ScalarString="CASE WHEN [Expr1017] THEN (0) ELSE (1) END">
                                          <IF>
                                            <Condition>
                                              <ScalarOperator>
                                                <Identifier>
                                                  <ColumnReference Column="Expr1017" />
                                                </Identifier>
                                              </ScalarOperator>
                                            </Condition>
                                            <Then>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Then>
                                            <Else>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Else>
                                          </IF>
                                        </ScalarOperator>
                                      </DefinedValue>
                                      <DefinedValue>
                                        <ScalarOperator ScalarString="CASE WHEN [Expr1016] THEN (0) ELSE (1) END">
                                          <IF>
                                            <Condition>
                                              <ScalarOperator>
                                                <Identifier>
                                                  <ColumnReference Column="Expr1016" />
                                                </Identifier>
                                              </ScalarOperator>
                                            </Condition>
                                            <Then>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Then>
                                            <Else>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Else>
                                          </IF>
                                        </ScalarOperator>
                                      </DefinedValue>
                                      <DefinedValue>
                                          <IF>
                                            <Condition>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                            </Condition>
                                            <Then>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Then>
                                            <Else>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Else>
                                          </IF>
                                        </ScalarOperator>
                                      </DefinedValue>
                                    </DefinedValues>
                                    <RelOp AvgRowSize="48" EstimateCPU="0.00123745" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.5" LogicalOp="Compute Scalar" NodeId="7" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="5.09843">
                                      <OutputList>
                                      </OutputList>
                                      <ComputeScalar>
                                        <DefinedValues>
                                          <DefinedValue>
                                            </ScalarOperator>
                                          </DefinedValue>
                                          <DefinedValue>
                                            </ScalarOperator>
                                          </DefinedValue>
                                          <DefinedValue>
                                            </ScalarOperator>
                                          </DefinedValue>
                                        </DefinedValues>
                                        <RelOp AvgRowSize="12" EstimateCPU="0.00123745" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.5" LogicalOp="Top" NodeId="8" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="5.0972">
                                          <OutputList>
                                          </OutputList>
                                            <TopExpression>
                                              </ScalarOperator>
                                            </TopExpression>
                                            <RelOp AvgRowSize="12" EstimateCPU="0.111355" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Gather Streams" NodeId="10" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="5.09596">
                                              <OutputList>
                                              </OutputList>
                                              <Parallelism>
                                                <OrderBy>
                                                  <OrderByColumn Ascending="true">
                                                  </OrderByColumn>
                                                </OrderBy>
                                                <RelOp AvgRowSize="12" EstimateCPU="0.386136" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Sort" NodeId="11" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="4.9846">
                                                  <OutputList>
                                                  </OutputList>
                                                  <MemoryFractions Input="0.350109" Output="1" />
                                                    <RunTimeCountersPerThread Thread="4" ActualRebinds="1" ActualRewinds="0" ActualRows="3371" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="2" ActualRebinds="1" ActualRewinds="0" ActualRows="3366" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="1" ActualRebinds="1" ActualRewinds="0" ActualRows="3390" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="3" ActualRebinds="1" ActualRewinds="0" ActualRows="3423" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="0" ActualRebinds="0" ActualRewinds="0" ActualRows="0" ActualEndOfScans="0" ActualExecutions="0" />
                                                  <Sort Distinct="false">
                                                    <OrderBy>
                                                      </OrderByColumn>
                                                    </OrderBy>
                                                    <RelOp AvgRowSize="12" EstimateCPU="0.234113" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Inner Join" NodeId="12" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="4.59284">
                                                      <OutputList>
                                                      </OutputList>
                                                      <MemoryFractions Input="1" Output="0.649891" />
                                                        <RunTimeCountersPerThread Thread="4" ActualRows="3371" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="2" ActualRows="3366" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="1" ActualRows="3390" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="3" ActualRows="3423" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="0" ActualExecutions="0" />
                                                      <Hash>
                                                        <DefinedValues />
                                                        <HashKeysBuild>
                                                        </HashKeysBuild>
                                                        <HashKeysProbe>
                                                          <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="fkContentID" />
                                                        </HashKeysProbe>
                                                        <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Bitmap Create" NodeId="13" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.0652864">
                                                          <OutputList>
                                                          </OutputList>
                                                            <RunTimeCountersPerThread Thread="4" ActualRows="1929" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="2" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="1" ActualRows="1941" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="3" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                                          <Bitmap>
                                                            <DefinedValues>
                                                              <DefinedValue>
        <ColumnReference Column="Bitmap1031" />
                                                              </DefinedValue>
                                                            </DefinedValues>
                                                            <HashKeys>
                                                            </HashKeys>
                                                            <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Repartition Streams" NodeId="14" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.0652864">
                                                              <OutputList>
                                                              </OutputList>
                                                              <Parallelism PartitioningType="Hash">
        <PartitionColumns>
        </PartitionColumns>
        <RelOp AvgRowSize="11" EstimateCPU="0.004352" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="15" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.027477" TableCardinality="7770">
        <OutputList>
        </OutputList>
        <RunTimeCountersPerThread Thread="4" ActualRows="1674" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="1" ActualRows="1953" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="2" ActualRows="1910" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="3" ActualRows="2233" ActualEndOfScans="1" ActualExecutions="1" />
        <IndexScan Ordered="false" ForcedIndex="false" NoExpandHint="false">
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
        </IndexScan>
        </RelOp>
                                                              </Parallelism>
                                                            </RelOp>
                                                          </Bitmap>
                                                        </RelOp>
                                                        <RelOp AvgRowSize="16" EstimateCPU="0.0036941" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Compute Scalar" NodeId="16" Parallel="true" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="4.29344">
                                                          <OutputList>
                                                          </OutputList>
                                                          <ComputeScalar>
                                                            <DefinedValues>
                                                              <DefinedValue>
        <ScalarOperator ScalarString="CASE WHEN [PhoenixCMS_RC].[dbo].[tblWorkContent].[fkMasterVersionID] IS NULL THEN (1) ELSE (0) END">
        <IF>
        <Condition>
        <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Compare>
        </ScalarOperator>
        </Condition>
        <Then>
        <ScalarOperator>
        </ScalarOperator>
        </Then>
        <Else>
        <ScalarOperator>
        </ScalarOperator>
        </Else>
        </IF>
        </ScalarOperator>
                                                              </DefinedValue>
                                                              <DefinedValue>
        <ScalarOperator ScalarString="CASE WHEN [PhoenixCMS_RC].[dbo].[tblWorkContent].[ContentLinkGUID] IS NULL THEN (1) ELSE (0) END">
        <IF>
        <Condition>
        <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Compare>
        </ScalarOperator>
        </Condition>
        <Then>
        <ScalarOperator>
        </ScalarOperator>
        </Then>
        <Else>
        <ScalarOperator>
        </ScalarOperator>
        </Else>
        </IF>
        </ScalarOperator>
                                                              </DefinedValue>
                                                              <DefinedValue>
        <ScalarOperator ScalarString="CASE WHEN [PhoenixCMS_RC].[dbo].[tblWorkContent].[ArchiveContentGUID] IS NULL THEN (1) ELSE (0) END">
        <IF>
        <Condition>
        <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Compare>
        </ScalarOperator>
        </Condition>
        <Then>
        <ScalarOperator>
        </ScalarOperator>
        </Then>
        <Else>
        <ScalarOperator>
        </ScalarOperator>
        </Else>
        </IF>
        </ScalarOperator>
                                                              </DefinedValue>
                                                            </DefinedValues>
                                                            <RelOp AvgRowSize="51" EstimateCPU="0.290347" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Repartition Streams" NodeId="17" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="4.28974">
                                                              <OutputList>
                                                              </OutputList>
        <RunTimeCountersPerThread Thread="4" ActualRows="3374" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="2" ActualRows="3369" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="1" ActualRows="3397" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="3" ActualRows="3428" ActualEndOfScans="1" ActualExecutions="1" />
        <PartitionColumns>
        </PartitionColumns>
        <RelOp AvgRowSize="51" EstimateCPU="0.0407136" EstimateIO="3.95868" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Clustered Index Scan" NodeId="18" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="3.99939" TableCardinality="73882">
        <OutputList>
        </OutputList>
        <RunTimeCountersPerThread Thread="2" ActualRows="3475" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="4" ActualRows="3046" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="1" ActualRows="3265" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="3" ActualRows="3782" ActualEndOfScans="1" ActualExecutions="1" />
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        <DefinedValue>
        </DefinedValue>
        <DefinedValue>
        </DefinedValue>
        <DefinedValue>
        </DefinedValue>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
        <Predicate>
        <ScalarOperator ScalarString="PROBE([Bitmap1031],[PhoenixCMS_RC].[dbo].[tblWorkContent].[fkContentID],N'[IN ROW]')">
        <Intrinsic FunctionName="PROBE">
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        <Const ConstValue="N'[IN ROW]'" />
        </ScalarOperator>
        </Intrinsic>
        </ScalarOperator>
        </Predicate>
        </IndexScan>
        </RelOp>
                                                              </Parallelism>
                                                            </RelOp>
                                                          </ComputeScalar>
                                                        </RelOp>
                                                      </Hash>
                                                    </RelOp>
                                                  </Sort>
                                                </RelOp>
                                              </Parallelism>
                                            </RelOp>
                                          </Top>
                                        </RelOp>
                                      </ComputeScalar>
                                    </RelOp>
                                  </ComputeScalar>
                                </RelOp>
                              </ComputeScalar>
                            </RelOp>
                          </Update>
                        </RelOp>
                      </Split>
                    </RelOp>
                  </RowCountSpool>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00128772" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="24749" LogicalOp="Eager Spool" NodeId="50" Parallel="false" PhysicalOp="Row Count Spool" EstimatedTotalSubtreeCost="6.0757">
                  <OutputList />
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="16" StatementEstRows="3412.02" StatementId="5" StatementOptmLevel="FULL" StatementSubTreeCost="2.55584" StatementText="DELETE FROM
	    tblWorkProperty
	WHERE
	    PageLink IN ( SELECT pkID FROM #pages )
" StatementType="DELETE" QueryHash="0x486A60087ADD7991" QueryPlanHash="0x0EAE8214F3FDBA26">
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="4000" CachedPlanSize="88" CompileTime="16" CompileCPU="16" CompileMemory="632">
            <RelOp AvgRowSize="9" EstimateCPU="0.0170601" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Sequence" NodeId="0" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="2.55584">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="33" ActualEndOfScans="1" ActualExecutions="1" />
              <Sequence>
                <RelOp AvgRowSize="9" EstimateCPU="0.00341202" EstimateIO="0.0459259" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Delete" NodeId="1" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.510899">
                  <OutputList />
                  <Update WithOrderedPrefetch="true" DMLRequestSort="true">
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Index="[IDX_tblWorkContentProperty_ContentLink]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="15" EstimateCPU="0.06257" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Sort" NodeId="3" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.461561">
                      <OutputList>
                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Column="pkID" />
                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Column="ContentLink" />
                      </OutputList>
                        <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="33" ActualEndOfScans="1" ActualExecutions="1" />
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.000266097" EstimateIO="0.00262887" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Eager Spool" NodeId="4" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.38773">
                          <OutputList>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Column="fkPropertyDefinitionID" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Column="fkWorkContentID" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Column="ScopeName" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Column="ContentType" />
                          </OutputList>
                          <Spool>
                            <RelOp AvgRowSize="481" EstimateCPU="0.00341202" EstimateIO="0.583095" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Delete" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="1.92134">
                              <OutputList>
                              </OutputList>
                              <Update WithUnorderedPrefetch="true" DMLRequestSort="false">
                                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Index="[PK_tblWorkProperty]" IndexKind="Clustered" />
                                <RelOp AvgRowSize="11" EstimateCPU="0.000341202" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Top" NodeId="7" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="1.33483">
                                  <OutputList>
                                  </OutputList>
                                    <TopExpression>
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="11" EstimateCPU="0.0324786" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3133.97" LogicalOp="Inner Join" NodeId="9" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="1.33449">
                                      <OutputList>
                                      </OutputList>
                                      <NestedLoops Optimized="false" WithUnorderedPrefetch="true">
                                        <OuterReferences>
                                          <ColumnReference Column="Expr1009" />
                                        </OuterReferences>
                                          <OutputList>
                                          </OutputList>
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                          </IndexScan>
                                        </RelOp>
                                        <RelOp AvgRowSize="11" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="7769" EstimateRewinds="0" EstimateRows="1" LogicalOp="Index Seek" NodeId="12" Parallel="false" PhysicalOp="Index Seek" EstimatedTotalSubtreeCost="1.27018" TableCardinality="1610670">
                                          <OutputList>
                                          </OutputList>
                                            <RunTimeCountersPerThread Thread="0" ActualRows="33" ActualEndOfScans="7770" ActualExecutions="7770" />
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                            <SeekPredicates>
                                              <SeekPredicateNew>
                                                <SeekKeys>
                                                    <RangeColumns>
                                                    </RangeColumns>
                                                    <RangeExpressions>
                                                      <ScalarOperator ScalarString="[tempdb].[dbo].[#pages].[pkID]">
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                    </RangeExpressions>
                                                  </Prefix>
                                                </SeekKeys>
                                              </SeekPredicateNew>
                                            </SeekPredicates>
                                          </IndexScan>
                                        </RelOp>
                                      </NestedLoops>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                              </Update>
                            </RelOp>
                          </Spool>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00341202" EstimateIO="0.0357061" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Delete" NodeId="15" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.50068">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Index="[IDX_tblWorkContentProperty_ScopeName]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="465" EstimateCPU="0.0625704" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Sort" NodeId="17" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.461561">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.000266097" EstimateIO="0.00262887" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Eager Spool" NodeId="18" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.38773">
                          <OutputList>
                          </OutputList>
                          <Spool PrimaryNodeId="4" />
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00341202" EstimateIO="0.0477866" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Delete" NodeId="19" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.51276">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Index="[IDX_tblWorkContentProperty_ContentTypeID]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="15" EstimateCPU="0.06257" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Sort" NodeId="21" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.461561">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.000266097" EstimateIO="0.00262887" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Eager Spool" NodeId="22" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.38773">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00341202" EstimateIO="0.0458686" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Delete" NodeId="23" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.510842">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Index="[IDX_tblWorkContentProperty_fkPropertyDefinitionID]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="15" EstimateCPU="0.06257" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Sort" NodeId="25" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.461561">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.000266097" EstimateIO="0.00262887" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Eager Spool" NodeId="26" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.38773">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00341202" EstimateIO="0.038626" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Delete" NodeId="27" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.503599">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Index="[IX_tblWorkContentProperty_fkWorkContentID]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="15" EstimateCPU="0.06257" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Sort" NodeId="29" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.461561">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.000266097" EstimateIO="0.00262887" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3412.02" LogicalOp="Eager Spool" NodeId="30" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.38773">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="17" StatementEstRows="1" StatementId="6" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.892678" StatementText="UPDATE
	    tblWorkPage
	SET
	    ArchivePageGUID = NULL
	WHERE
	    ArchivePageGUID IN ( SELECT PageGUID FROM #pages )
" StatementType="UPDATE" QueryHash="0xCCA1432383526ECC" QueryPlanHash="0xF4D64A208F19D5CB">
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="2032" CachedPlanSize="48" CompileTime="214" CompileCPU="165" CompileMemory="552">
            <RelOp AvgRowSize="9" EstimateCPU="2E-06" EstimateIO="0.02" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Update" NodeId="1" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="0.892678">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                <SetPredicate>
                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[ArchiveContentGUID] = [Expr1006]">
                      <ScalarOperator>
                        <MultipleAssign>
                          <Assign>
                            <ScalarOperator>
                              <Identifier>
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                        </MultipleAssign>
                      </ScalarOperator>
                  </ScalarOperator>
                </SetPredicate>
                <RelOp AvgRowSize="31" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="2" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.872676">
                  <OutputList>
                    <ColumnReference Column="Expr1013" />
                  </OutputList>
                  <ComputeScalar>
                    <DefinedValues>
                      <DefinedValue>
                        <ScalarOperator ScalarString="[Expr1013]">
                          <Identifier>
                          </Identifier>
                        </ScalarOperator>
                      </DefinedValue>
                    </DefinedValues>
                    <RelOp AvgRowSize="31" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="3" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.872676">
                      <OutputList>
                      </OutputList>
                      <ComputeScalar>
                        <DefinedValues>
                          <DefinedValue>
                            <ScalarOperator ScalarString="CASE WHEN [Expr1010] THEN (0) ELSE (1) END">
                              <IF>
                                <Condition>
                                  <ScalarOperator>
                                    <Identifier>
                                      <ColumnReference Column="Expr1010" />
                                    </Identifier>
                                  </ScalarOperator>
                                </Condition>
                                <Then>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Then>
                                <Else>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Else>
                              </IF>
                            </ScalarOperator>
                          </DefinedValue>
                        </DefinedValues>
                        <RelOp AvgRowSize="28" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="4" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.872676">
                          <OutputList>
                          </OutputList>
                          <ComputeScalar>
                            <DefinedValues>
                              <DefinedValue>
                                </ScalarOperator>
                              </DefinedValue>
                            </DefinedValues>
                            <RelOp AvgRowSize="12" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="5" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.872676">
                              <OutputList>
                              </OutputList>
                                <TopExpression>
                                  </ScalarOperator>
                                </TopExpression>
                                <RelOp AvgRowSize="12" EstimateCPU="0.000100012" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Distinct Sort" NodeId="7" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.872676">
                                  <OutputList>
                                  </OutputList>
                                  <MemoryFractions Input="0.031746" Output="1" />
                                    <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                                  <Sort Distinct="true">
                                    <OrderBy>
                                      </OrderByColumn>
                                    </OrderBy>
                                    <RelOp AvgRowSize="12" EstimateCPU="0.177114" EstimateIO="0.000313" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="8" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="0.861314">
                                      <OutputList>
                                      </OutputList>
                                      <Merge ManyToMany="true">
                                          <ColumnReference Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Column="PageGUID" />
                                        <Residual>
                                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[ArchiveContentGUID]=[tempdb].[dbo].[#pages].[PageGUID]">
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                            </Compare>
                                          </ScalarOperator>
                                        </Residual>
                                        <RelOp AvgRowSize="28" EstimateCPU="0.0073882" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Compute Scalar" NodeId="9" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.319348">
                                          <OutputList>
                                          </OutputList>
                                          <ComputeScalar>
                                            <DefinedValues>
                                              <DefinedValue>
                                                  <IF>
                                                    <Condition>
                                                      <ScalarOperator>
                                                          <ScalarOperator>
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                          <ScalarOperator>
                                                          </ScalarOperator>
                                                        </Compare>
                                                      </ScalarOperator>
                                                    </Condition>
                                                    <Then>
                                                      <ScalarOperator>
                                                      </ScalarOperator>
                                                    </Then>
                                                    <Else>
                                                      <ScalarOperator>
                                                      </ScalarOperator>
                                                    </Else>
                                                  </IF>
                                                </ScalarOperator>
                                              </DefinedValue>
                                            </DefinedValues>
                                            <RelOp AvgRowSize="27" EstimateCPU="0.0814272" EstimateIO="0.230532" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Index Scan" NodeId="10" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.31196" TableCardinality="73882">
                                              <OutputList>
                                              </OutputList>
                                                <RunTimeCountersPerThread Thread="0" ActualRows="73882" ActualEndOfScans="1" ActualExecutions="1" />
                                                <DefinedValues>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                </DefinedValues>
                                              </IndexScan>
                                            </RelOp>
                                          </ComputeScalar>
                                        </RelOp>
                                        <RelOp AvgRowSize="23" EstimateCPU="0.321446" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Sort" NodeId="14" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.364536">
                                          <OutputList>
                                          </OutputList>
                                          <MemoryFractions Input="0.968254" Output="0.968254" />
                                            <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="1" ActualEndOfScans="0" ActualExecutions="1" />
                                            <OrderBy>
                                              </OrderByColumn>
                                            </OrderBy>
                                            <RelOp AvgRowSize="23" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="15" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                                              <OutputList>
                                              </OutputList>
                                                <DefinedValues>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                </DefinedValues>
                                              </IndexScan>
                                            </RelOp>
                                          </Sort>
                                        </RelOp>
                                      </Merge>
                                    </RelOp>
                                  </Sort>
                                </RelOp>
                              </Top>
                            </RelOp>
                          </ComputeScalar>
                        </RelOp>
                      </ComputeScalar>
                    </RelOp>
                  </ComputeScalar>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="18" StatementEstRows="1" StatementId="7" StatementOptmLevel="FULL" StatementSubTreeCost="2.29647" StatementText="UPDATE
	    tblWorkPage
	SET
	    PageLinkGUID = NULL,
	    LinkType=0,
	    LinkURL=
			SELECT TOP 1
			      '~/link/' + CONVERT(NVARCHAR(32),REPLACE((select top 1 PageGUID FROM tblPage where tblPage.pkID = tblWorkPage.fkPageID),'-','')) + '.aspx'
			FROM
			    tblPageType
			WHERE
			    tblPageType.pkID=(SELECT fkPageTypeID FROM tblPage WHERE tblPage.pkID=tblWorkPage.fkPageID)
	 WHERE
	    PageLinkGUID IN ( SELECT PageGUID FROM #pages )
	-- Remove workproperties,workcategories and finally the work versions themselves
" StatementType="UPDATE" QueryHash="0x4AD1EA1CED12DD5D" QueryPlanHash="0x0C72EA1D47225C89">
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="1024" CachedPlanSize="72" CompileTime="849" CompileCPU="177" CompileMemory="1176">
            <RelOp AvgRowSize="9" EstimateCPU="2E-06" EstimateIO="0.02" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Update" NodeId="1" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="2.29647">
              <OutputList />
                <SetPredicate>
                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[ContentLinkGUID] = [Expr1006],[PhoenixCMS_RC].[dbo].[tblWorkContent].[LinkType] = [Expr1007],[PhoenixCMS_RC].[dbo].[tblWorkContent].[LinkURL] = [Expr1020]">
                      <ScalarOperator>
                        <MultipleAssign>
                          <Assign>
                            <ScalarOperator>
                              <Identifier>
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                          <Assign>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="LinkType" />
                            <ScalarOperator>
                              <Identifier>
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                          <Assign>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="LinkURL" />
                            <ScalarOperator>
                              <Identifier>
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                        </MultipleAssign>
                      </ScalarOperator>
                  </ScalarOperator>
                </SetPredicate>
                <RelOp AvgRowSize="294" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="2" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="2.27647">
                  <OutputList>
                    <ColumnReference Column="Expr1036" />
                  </OutputList>
                  <ComputeScalar>
                    <DefinedValues>
                      <DefinedValue>
                        <ScalarOperator ScalarString="[Expr1036]">
                          <Identifier>
                          </Identifier>
                        </ScalarOperator>
                      </DefinedValue>
                    </DefinedValues>
                    <RelOp AvgRowSize="294" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="3" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="2.27647">
                      <OutputList>
                      </OutputList>
                      <ComputeScalar>
                        <DefinedValues>
                          <DefinedValue>
                            <ScalarOperator ScalarString="CASE WHEN [Expr1024] THEN (0) ELSE (1) END">
                              <IF>
                                <Condition>
                                  <ScalarOperator>
                                    <Identifier>
                                    </Identifier>
                                  </ScalarOperator>
                                </Condition>
                                <Then>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Then>
                                <Else>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Else>
                              </IF>
                            </ScalarOperator>
                          </DefinedValue>
                        </DefinedValues>
                        <RelOp AvgRowSize="291" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="4" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="2.27647">
                          <OutputList>
                          </OutputList>
                          <ComputeScalar>
                            <DefinedValues>
                              <DefinedValue>
                                </ScalarOperator>
                              </DefinedValue>
                              <DefinedValue>
                                </ScalarOperator>
                              </DefinedValue>
                              <DefinedValue>
                                <ScalarOperator ScalarString="CONVERT_IMPLICIT(nvarchar(255),[Expr1019],0)">
                                  <Convert DataType="nvarchar" Length="510" Style="0" Implicit="true">
                                    <ScalarOperator>
                                      <Identifier>
                                        <ColumnReference Column="Expr1019" />
                                      </Identifier>
                                    </ScalarOperator>
                                  </Convert>
                                </ScalarOperator>
                              </DefinedValue>
                            </DefinedValues>
                            <RelOp AvgRowSize="60" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Left Outer Join" NodeId="5" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="2.27647">
                              <OutputList>
                              </OutputList>
                              <NestedLoops Optimized="false">
                                <OuterReferences>
                                </OuterReferences>
                                <RelOp AvgRowSize="16" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="6" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="2.26989">
                                  <OutputList>
                                  </OutputList>
                                    <TopExpression>
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="16" EstimateCPU="0.000100016" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Distinct Sort" NodeId="8" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="2.26989">
                                      <OutputList>
                                      </OutputList>
                                        <OrderBy>
                                          </OrderByColumn>
                                        </OrderBy>
                                        <RelOp AvgRowSize="16" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="9" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="2.25853">
                                          <OutputList>
                                          </OutputList>
                                          <ComputeScalar>
                                            <DefinedValues>
                                              <DefinedValue>
                                                  <IF>
                                                    <Condition>
                                                      <ScalarOperator>
                                                          <ScalarOperator>
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                          <ScalarOperator>
                                                          </ScalarOperator>
                                                        </Compare>
                                                      </ScalarOperator>
                                                    </Condition>
                                                    <Then>
                                                      <ScalarOperator>
                                                      </ScalarOperator>
                                                    </Then>
                                                    <Else>
                                                      <ScalarOperator>
                                                      </ScalarOperator>
                                                    </Else>
                                                  </IF>
                                                </ScalarOperator>
                                              </DefinedValue>
                                            </DefinedValues>
                                            <RelOp AvgRowSize="31" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="10" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="2.25853">
                                              <OutputList>
                                              </OutputList>
                                                <OuterReferences>
                                                </OuterReferences>
                                                <RelOp AvgRowSize="27" EstimateCPU="0.0324786" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="11" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="2.25524">
                                                  <OutputList>
                                                  </OutputList>
                                                    <OuterReferences>
                                                      <ColumnReference Column="Expr1042" />
                                                    </OuterReferences>
                                                    <RelOp AvgRowSize="23" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="13" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                                                      <OutputList>
                                                      </OutputList>
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                      </IndexScan>
                                                    </RelOp>
                                                    <RelOp AvgRowSize="27" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="7769" EstimateRewinds="0" EstimateRows="1" LogicalOp="Index Seek" NodeId="14" Parallel="false" PhysicalOp="Index Seek" EstimatedTotalSubtreeCost="2.19094" TableCardinality="73882">
                                                      <OutputList>
                                                      </OutputList>
                                                        <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="7770" ActualExecutions="7770" />
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                        <SeekPredicates>
                                                          <SeekPredicateNew>
                                                            <SeekKeys>
        <RangeColumns>
        </RangeColumns>
        <RangeExpressions>
        <ScalarOperator ScalarString="[tempdb].[dbo].[#pages].[PageGUID]">
        <Identifier>
        </Identifier>
        </ScalarOperator>
        </RangeExpressions>
                                                              </Prefix>
                                                            </SeekKeys>
                                                          </SeekPredicateNew>
                                                        </SeekPredicates>
                                                      </IndexScan>
                                                    </RelOp>
                                                  </NestedLoops>
                                                </RelOp>
                                                <RelOp AvgRowSize="11" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="16" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="73882">
                                                  <OutputList>
                                                  </OutputList>
                                                  <IndexScan Lookup="true" Ordered="true" ScanDirection="FORWARD" ForcedIndex="false" ForceSeek="false" NoExpandHint="false">
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[PK_tblWorkContent]" TableReferenceId="-1" IndexKind="Clustered" />
                                                    <SeekPredicates>
                                                      <SeekPredicateNew>
                                                        <SeekKeys>
                                                            <RangeColumns>
                                                            </RangeColumns>
                                                            <RangeExpressions>
                                                              <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[pkID]">
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                            </RangeExpressions>
                                                          </Prefix>
                                                        </SeekKeys>
                                                      </SeekPredicateNew>
                                                    </SeekPredicates>
                                                  </IndexScan>
                                                </RelOp>
                                              </NestedLoops>
                                            </RelOp>
                                          </ComputeScalar>
                                        </RelOp>
                                      </Sort>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                                <RelOp AvgRowSize="55" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="25" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.00657068">
                                  <OutputList>
                                  </OutputList>
                                  <Top RowCount="false" IsPercent="false" WithTies="false">
                                    <TopExpression>
                                      <ScalarOperator ScalarString="(1)">
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="55" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="26" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.00657058">
                                      <OutputList>
                                      </OutputList>
                                      <ComputeScalar>
                                        <DefinedValues>
                                          <DefinedValue>
                                            <ScalarOperator ScalarString="(N'~/link/'+CONVERT(nvarchar(32),replace(CONVERT_IMPLICIT(varchar(40),[PhoenixCMS_RC].[dbo].[tblContent].[ContentGUID],0),'-',''),0))+N'.aspx'">
                                              <Arithmetic Operation="ADD">
                                                <ScalarOperator>
                                                    <ScalarOperator>
                                                      <Const ConstValue="N'~/link/'" />
                                                    </ScalarOperator>
                                                    <ScalarOperator>
                                                      <Convert DataType="nvarchar" Length="64" Style="0" Implicit="false">
                                                        <ScalarOperator>
                                                          <Intrinsic FunctionName="replace">
                                                            <ScalarOperator>
                                                              <Convert DataType="varchar" Length="40" Style="0" Implicit="true">
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
                                                              </Convert>
                                                            </ScalarOperator>
                                                            <ScalarOperator>
                                                              <Const ConstValue="'-'" />
                                                            </ScalarOperator>
                                                            <ScalarOperator>
                                                              <Const ConstValue="''" />
                                                            </ScalarOperator>
                                                          </Intrinsic>
                                                        </ScalarOperator>
                                                      </Convert>
                                                    </ScalarOperator>
                                                  </Arithmetic>
                                                </ScalarOperator>
                                                <ScalarOperator>
                                                  <Const ConstValue="N'.aspx'" />
                                                </ScalarOperator>
                                              </Arithmetic>
                                            </ScalarOperator>
                                          </DefinedValue>
                                        </DefinedValues>
                                        <RelOp AvgRowSize="23" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Left Outer Join" NodeId="27" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.00657048">
                                          <OutputList>
                                          </OutputList>
                                            <RelOp AvgRowSize="9" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="28" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="67414">
                                              <OutputList />
                                                <DefinedValues />
                                                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[PK_tblContent]" TableReferenceId="1" IndexKind="Clustered" />
                                                <SeekPredicates>
                                                  <SeekPredicateNew>
                                                    <SeekKeys>
                                                        <RangeColumns>
                                                        </RangeColumns>
                                                        <RangeExpressions>
                                                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[fkContentID]">
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                        </RangeExpressions>
                                                      </Prefix>
                                                    </SeekKeys>
                                                  </SeekPredicateNew>
                                                </SeekPredicates>
                                              </IndexScan>
                                            </RelOp>
                                            <RelOp AvgRowSize="23" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="29" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.0032832">
                                              <OutputList>
                                              </OutputList>
                                                <TopExpression>
                                                  </ScalarOperator>
                                                </TopExpression>
                                                <RelOp AvgRowSize="23" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="30" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="67414">
                                                  <OutputList>
                                                  </OutputList>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[PK_tblContent]" TableReferenceId="2" IndexKind="Clustered" />
                                                    <SeekPredicates>
                                                      <SeekPredicateNew>
                                                        <SeekKeys>
                                                            <RangeColumns>
                                                            </RangeColumns>
                                                            <RangeExpressions>
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                            </RangeExpressions>
                                                          </Prefix>
                                                        </SeekKeys>
                                                      </SeekPredicateNew>
                                                    </SeekPredicates>
                                                  </IndexScan>
                                                </RelOp>
                                              </Top>
                                            </RelOp>
                                          </NestedLoops>
                                        </RelOp>
                                      </ComputeScalar>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                              </NestedLoops>
                            </RelOp>
                          </ComputeScalar>
                        </RelOp>
                      </ComputeScalar>
                    </RelOp>
                  </ComputeScalar>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="19" StatementEstRows="881557" StatementId="8" StatementOptmLevel="FULL" StatementSubTreeCost="1198.45" StatementText="DELETE FROM
	    tblWorkProperty
	WHERE
	    fkWorkPageID IN ( SELECT pkID FROM tblWorkPage WHERE fkPageID IN ( SELECT pkID FROM #pages ) )
" StatementType="DELETE" QueryHash="0x72C6A0DB1FBFFF35" QueryPlanHash="0xCEBA8180FA2D1197">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="567008" CachedPlanSize="136" CompileTime="85" CompileCPU="82" CompileMemory="1264">
            <RelOp AvgRowSize="9" EstimateCPU="4.40778" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Sequence" NodeId="0" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="1198.45">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="325076" ActualEndOfScans="1" ActualExecutions="1" />
              <Sequence>
                <RelOp AvgRowSize="9" EstimateCPU="0.881557" EstimateIO="11.0311" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Delete" NodeId="1" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="127.406">
                  <OutputList />
                    <RelOp AvgRowSize="15" EstimateCPU="79.9142" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Sort" NodeId="3" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="115.494">
                      <OutputList>
                      </OutputList>
                        <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="325076" ActualEndOfScans="1" ActualExecutions="1" />
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.0637197" EstimateIO="0.00263441" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Eager Spool" NodeId="4" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="35.5683">
                          <OutputList>
                          </OutputList>
                          <RunTimeInformation>
                          </RunTimeInformation>
                          <Spool>
                            <RelOp AvgRowSize="481" EstimateCPU="0.881557" EstimateIO="149.818" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Delete" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="176.876">
                              <OutputList>
                              </OutputList>
                                <RelOp AvgRowSize="11" EstimateCPU="0.0881557" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Top" NodeId="7" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="26.1758">
                                  <OutputList>
                                  </OutputList>
                                    <TopExpression>
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="11" EstimateCPU="2.01268" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="334220" LogicalOp="Gather Streams" NodeId="10" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="26.0877">
                                      <OutputList>
                                      </OutputList>
                                      <Parallelism>
                                        <OrderBy>
                                          </OrderByColumn>
                                        </OrderBy>
                                        <RelOp AvgRowSize="11" EstimateCPU="14.0755" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="334220" LogicalOp="Sort" NodeId="11" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="24.075">
                                          <OutputList>
                                          </OutputList>
                                          <MemoryFractions Input="0.664122" Output="1" />
                                            <RunTimeCountersPerThread Thread="4" ActualRebinds="1" ActualRewinds="0" ActualRows="82256" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="3" ActualRebinds="1" ActualRewinds="0" ActualRows="81377" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="1" ActualRebinds="1" ActualRewinds="0" ActualRows="80843" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="2" ActualRebinds="1" ActualRewinds="0" ActualRows="80600" ActualEndOfScans="1" ActualExecutions="1" />
                                            <OrderBy>
                                              </OrderByColumn>
                                            </OrderBy>
                                            <RelOp AvgRowSize="11" EstimateCPU="4.01849" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="334220" LogicalOp="Inner Join" NodeId="12" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="9.9939">
                                              <OutputList>
                                              </OutputList>
                                              <MemoryFractions Input="0.817337" Output="0.335878" />
                                                <RunTimeCountersPerThread Thread="4" ActualRows="82256" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="1" ActualRows="80843" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="3" ActualRows="81377" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="2" ActualRows="80600" ActualEndOfScans="1" ActualExecutions="1" />
                                              <Hash>
                                                <DefinedValues />
                                                <HashKeysBuild>
                                                </HashKeysBuild>
                                                <HashKeysProbe>
                                                </HashKeysProbe>
                                                <RelOp AvgRowSize="11" EstimateCPU="0.043326" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Bitmap Create" NodeId="13" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.686439">
                                                  <OutputList>
                                                  </OutputList>
                                                    <RunTimeCountersPerThread Thread="4" ActualRows="3414" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="3" ActualRows="3395" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="1" ActualRows="3366" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="2" ActualRows="3375" ActualEndOfScans="1" ActualExecutions="1" />
                                                  <Bitmap>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                        <ColumnReference Column="Bitmap1013" />
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                    <HashKeys>
                                                    </HashKeys>
                                                    <RelOp AvgRowSize="11" EstimateCPU="0.043326" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Repartition Streams" NodeId="14" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.686439">
                                                      <OutputList>
                                                      </OutputList>
                                                        <PartitionColumns>
                                                        </PartitionColumns>
                                                        <RelOp AvgRowSize="11" EstimateCPU="0.234113" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Inner Join" NodeId="15" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="0.643113">
                                                          <OutputList>
                                                          </OutputList>
                                                          <MemoryFractions Input="1" Output="0.182663" />
                                                          <Hash>
                                                            <DefinedValues />
                                                            <HashKeysBuild>
                                                            </HashKeysBuild>
                                                            <HashKeysProbe>
                                                            </HashKeysProbe>
                                                            <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Bitmap Create" NodeId="16" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.0652864">
                                                              <OutputList>
                                                              </OutputList>
                                                              <Bitmap>
        <DefinedValues>
        <DefinedValue>
        <ColumnReference Column="Bitmap1012" />
        </DefinedValue>
        </DefinedValues>
        <HashKeys>
        </HashKeys>
        <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Repartition Streams" NodeId="17" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.0652864">
        <OutputList>
        </OutputList>
        <PartitionColumns>
        </PartitionColumns>
        <RelOp AvgRowSize="11" EstimateCPU="0.004352" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="18" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.027477" TableCardinality="7770">
        <OutputList>
        </OutputList>
        <RunTimeCountersPerThread Thread="3" ActualRows="1953" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="4" ActualRows="1954" ActualEndOfScans="1" ActualExecutions="1" />
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
        </IndexScan>
        </RelOp>
        </Parallelism>
        </RelOp>
                                                              </Bitmap>
                                                            </RelOp>
                                                            <RelOp AvgRowSize="15" EstimateCPU="0.145058" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Repartition Streams" NodeId="19" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.343712">
                                                              <OutputList>
                                                              </OutputList>
        <RunTimeCountersPerThread Thread="4" ActualRows="5221" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="1" ActualRows="5272" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="3" ActualRows="5278" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="2" ActualRows="5223" ActualEndOfScans="1" ActualExecutions="1" />
        <PartitionColumns>
        </PartitionColumns>
        <RelOp AvgRowSize="15" EstimateCPU="0.0407136" EstimateIO="0.15794" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Index Scan" NodeId="20" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.198653" TableCardinality="73882">
        <OutputList>
        </OutputList>
        <RunTimeCountersPerThread Thread="1" ActualRows="2355" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="4" ActualRows="4383" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="3" ActualRows="2625" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="2" ActualRows="11631" ActualEndOfScans="1" ActualExecutions="1" />
        <IndexScan Ordered="false" ForcedIndex="false" ForceSeek="false" NoExpandHint="false">
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_fkContentID]" IndexKind="NonClustered" />
        <Predicate>
        <ScalarOperator ScalarString="PROBE([Bitmap1012],[PhoenixCMS_RC].[dbo].[tblWorkContent].[fkContentID],N'[IN ROW]')">
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Intrinsic>
        </ScalarOperator>
        </Predicate>
        </IndexScan>
        </RelOp>
                                                              </Parallelism>
                                                            </RelOp>
                                                          </Hash>
                                                        </RelOp>
                                                      </Parallelism>
                                                    </RelOp>
                                                  </Bitmap>
                                                </RelOp>
                                                <RelOp AvgRowSize="15" EstimateCPU="2.56953" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1610670" LogicalOp="Repartition Streams" NodeId="22" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="5.28897">
                                                  <OutputList>
                                                  </OutputList>
                                                    <RunTimeCountersPerThread Thread="4" ActualRows="405100" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="3" ActualRows="402587" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="1" ActualRows="400147" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="2" ActualRows="400633" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <PartitionColumns>
                                                    </PartitionColumns>
                                                    <RelOp AvgRowSize="15" EstimateCPU="0.885946" EstimateIO="1.8335" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1610670" LogicalOp="Index Scan" NodeId="23" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="2.71944" TableCardinality="1610670">
                                                      <OutputList>
                                                      </OutputList>
                                                        <RunTimeCountersPerThread Thread="3" ActualRows="521111" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="1" ActualRows="423803" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="4" ActualRows="323586" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="2" ActualRows="339967" ActualEndOfScans="1" ActualExecutions="1" />
                                                      <IndexScan Ordered="true" ScanDirection="FORWARD" ForcedIndex="false" ForceSeek="false" NoExpandHint="false">
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                        <Predicate>
                                                          <ScalarOperator ScalarString="PROBE([Bitmap1013],[PhoenixCMS_RC].[dbo].[tblWorkContentProperty].[fkWorkContentID],N'[IN ROW]')">
                                                              <ScalarOperator>
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                              <ScalarOperator>
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                              <ScalarOperator>
                                                              </ScalarOperator>
                                                            </Intrinsic>
                                                          </ScalarOperator>
                                                        </Predicate>
                                                      </IndexScan>
                                                    </RelOp>
                                                  </Parallelism>
                                                </RelOp>
                                              </Hash>
                                            </RelOp>
                                          </Sort>
                                        </RelOp>
                                      </Parallelism>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                              </Update>
                            </RelOp>
                          </Spool>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.881557" EstimateIO="8.39061" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Delete" NodeId="28" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="685.836">
                  <OutputList />
                    <RelOp AvgRowSize="465" EstimateCPU="20.5221" EstimateIO="620.473" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Sort" NodeId="30" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="676.563">
                      <OutputList>
                      </OutputList>
                      <MemoryFractions Input="1" Output="1" />
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.0637197" EstimateIO="0.00263441" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Eager Spool" NodeId="31" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="35.5683">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.881557" EstimateIO="11.5118" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Delete" NodeId="32" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="127.887">
                  <OutputList />
                    <RelOp AvgRowSize="15" EstimateCPU="79.9142" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Sort" NodeId="34" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="115.494">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.0637197" EstimateIO="0.00263441" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Eager Spool" NodeId="35" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="35.5683">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.881557" EstimateIO="11.0163" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Delete" NodeId="36" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="127.392">
                  <OutputList />
                    <RelOp AvgRowSize="15" EstimateCPU="79.9142" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Sort" NodeId="38" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="115.494">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.0637197" EstimateIO="0.00263441" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Eager Spool" NodeId="39" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="35.5683">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.881557" EstimateIO="9.14503" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Delete" NodeId="40" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="125.52">
                  <OutputList />
                    <RelOp AvgRowSize="15" EstimateCPU="79.9142" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Sort" NodeId="42" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="115.494">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="481" EstimateCPU="0.0637197" EstimateIO="0.00263441" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="881557" LogicalOp="Eager Spool" NodeId="43" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="35.5683">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="20" StatementEstRows="1" StatementId="9" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.0298598" StatementText="DELETE FROM
	    tblWorkCategory
	WHERE
" StatementType="DELETE" QueryHash="0x7154781C0ECFFF99" QueryPlanHash="0xA3BB992C3D15A79F">
          <StatementSetOptions ANSI_NULLS="true" ANSI_PADDING="true" ANSI_WARNINGS="true" ARITHABORT="true" CONCAT_NULL_YIELDS_NULL="true" NUMERIC_ROUNDABORT="false" QUOTED_IDENTIFIER="true" />
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="32" CompileTime="66" CompileCPU="29" CompileMemory="824">
            <RelOp AvgRowSize="9" EstimateCPU="2E-06" EstimateIO="0.02" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="0.0298598">
              <OutputList />
              <Update DMLRequestSort="false">
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentCategory]" Index="[PK_tblWorkContentCategory]" IndexKind="Clustered" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentCategory]" Index="[IDX_tblWorkContentCategory_fkWorkContentID]" IndexKind="NonClustered" />
                <RelOp AvgRowSize="11" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="1" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.00985776">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentCategory]" Column="pkID" />
                  </OutputList>
                  <Top RowCount="true" IsPercent="false" WithTies="false">
                    <TopExpression>
                      <ScalarOperator ScalarString="(0)">
                        <Const ConstValue="(0)" />
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="11" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="4" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.00985766">
                      <OutputList>
                      </OutputList>
                        <OuterReferences>
                        </OuterReferences>
                        <RelOp AvgRowSize="15" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="5" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.00657038">
                          <OutputList>
                          </OutputList>
                            <OuterReferences>
                              <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentCategory]" Column="fkWorkContentID" />
                            </OuterReferences>
                            <RelOp AvgRowSize="15" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Index Scan" NodeId="6" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                              <OutputList>
                              </OutputList>
                                <DefinedValues>
                                  <DefinedValue>
                                  </DefinedValue>
                                  <DefinedValue>
                                  </DefinedValue>
                                </DefinedValues>
                              </IndexScan>
                            </RelOp>
                            <RelOp AvgRowSize="11" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="7" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="73882">
                              <OutputList>
                              </OutputList>
                                <DefinedValues>
                                  <DefinedValue>
                                  </DefinedValue>
                                </DefinedValues>
                                <SeekPredicates>
                                  <SeekPredicateNew>
                                    <SeekKeys>
                                      <Prefix ScanType="EQ">
                                        <RangeColumns>
                                        </RangeColumns>
                                        <RangeExpressions>
                                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContentCategory].[fkWorkContentID]">
                                            <Identifier>
                                            </Identifier>
                                          </ScalarOperator>
                                        </RangeExpressions>
                                      </Prefix>
                                    </SeekKeys>
                                  </SeekPredicateNew>
                                </SeekPredicates>
                              </IndexScan>
                            </RelOp>
                          </NestedLoops>
                        </RelOp>
                        <RelOp AvgRowSize="9" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="8" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="7770">
                          <OutputList />
                            <DefinedValues />
                            <Object Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Index="[PK__#pages____40A359E36921665A]" IndexKind="Clustered" />
                            <SeekPredicates>
                              <SeekPredicateNew>
                                <SeekKeys>
                                    <RangeColumns>
                                      <ColumnReference Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Column="pkID" />
                                    </RangeColumns>
                                    <RangeExpressions>
                                        <Identifier>
                                        </Identifier>
                                      </ScalarOperator>
                                    </RangeExpressions>
                                  </Prefix>
                                </SeekKeys>
                              </SeekPredicateNew>
                            </SeekPredicates>
                          </IndexScan>
                        </RelOp>
                      </NestedLoops>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="21" StatementEstRows="9021.01" StatementId="10" StatementOptmLevel="FULL" StatementSubTreeCost="12.4317" StatementText="DELETE FROM
	    tblWorkPage
	WHERE
-- PUBLISHED PAGE DATA
" StatementType="DELETE" QueryHash="0x41B12CBD8B51A8AB" QueryPlanHash="0x05FF843ACFE45A0B">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="8736" CachedPlanSize="96" CompileTime="2160" CompileCPU="285" CompileMemory="760">
            <RelOp AvgRowSize="9" EstimateCPU="0.0190444" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="9021.01" LogicalOp="Sequence" NodeId="1" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="12.4317">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="13550" ActualEndOfScans="1" ActualExecutions="1" />
              <Sequence>
                <RelOp AvgRowSize="11" EstimateCPU="0.000551221" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="10023.4" LogicalOp="Eager Spool" NodeId="2" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="5.68355">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="pkID" />
                  </OutputList>
                    <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="13550" ActualEndOfScans="1" ActualExecutions="1" />
                  <Spool>
                    <RelOp AvgRowSize="11" EstimateCPU="0.00882055" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="10023.4" LogicalOp="Assert" NodeId="3" Parallel="false" PhysicalOp="Assert" EstimatedTotalSubtreeCost="11.3649">
                      <OutputList>
                      </OutputList>
                      <Assert StartupExpression="false">
                        <RelOp AvgRowSize="12" EstimateCPU="0.0465529" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="10023.4" LogicalOp="Left Semi Join" NodeId="4" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="11.3561">
                          <OutputList>
                            <ColumnReference Column="Expr1018" />
                          </OutputList>
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                            <OuterReferences>
                              <ColumnReference Column="Expr1023" />
                            </OuterReferences>
                            <ProbeColumn>
                            </ProbeColumn>
                            <RelOp AvgRowSize="12" EstimateCPU="0.017855" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="11137.1" LogicalOp="Left Semi Join" NodeId="6" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="8.96291">
                              <OutputList>
                              </OutputList>
                              <Merge ManyToMany="false">
                                <InnerSideJoinColumns>
                                </InnerSideJoinColumns>
                                <OuterSideJoinColumns>
                                </OuterSideJoinColumns>
                                <Residual>
                                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContentCategory].[fkWorkContentID]=[PhoenixCMS_RC].[dbo].[tblWorkContent].[pkID]">
                                    <Compare CompareOp="EQ">
                                      <ScalarOperator>
                                        <Identifier>
                                        </Identifier>
                                      </ScalarOperator>
                                      <ScalarOperator>
                                        <Identifier>
                                        </Identifier>
                                      </ScalarOperator>
                                    </Compare>
                                  </ScalarOperator>
                                </Residual>
                                <RelOp AvgRowSize="11" EstimateCPU="0.0866215" EstimateIO="7.71706" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.5" LogicalOp="Delete" NodeId="7" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="8.94177">
                                  <OutputList>
                                  </OutputList>
                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[PK_tblWorkContent]" IndexKind="Clustered" />
                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_ChangedByName]" IndexKind="NonClustered" />
                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_StatusFields]" IndexKind="NonClustered" />
                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_ArchiveContentGUID]" IndexKind="NonClustered" />
                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_ContentLinkGUID]" IndexKind="NonClustered" />
                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_fkMasterVersionID]" IndexKind="NonClustered" />
                                    <RelOp AvgRowSize="11" EstimateCPU="0.00123745" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.5" LogicalOp="Top" NodeId="9" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="1.13808">
                                      <OutputList>
                                      </OutputList>
                                        <TopExpression>
                                          </ScalarOperator>
                                        </TopExpression>
                                        <RelOp AvgRowSize="11" EstimateCPU="0.101963" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Gather Streams" NodeId="11" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="1.13684">
                                          <OutputList>
                                          </OutputList>
                                          <Parallelism>
                                            <OrderBy>
                                              <OrderByColumn Ascending="true">
                                              </OrderByColumn>
                                            </OrderBy>
                                            <RelOp AvgRowSize="11" EstimateCPU="0.386136" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Sort" NodeId="12" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="1.03488">
                                              <OutputList>
                                              </OutputList>
                                              <MemoryFractions Input="0.345898" Output="1" />
                                                <RunTimeCountersPerThread Thread="2" ActualRebinds="1" ActualRewinds="0" ActualRows="3366" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="4" ActualRebinds="1" ActualRewinds="0" ActualRows="3371" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="3" ActualRebinds="1" ActualRewinds="0" ActualRows="3423" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="1" ActualRebinds="1" ActualRewinds="0" ActualRows="3390" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="0" ActualRebinds="0" ActualRewinds="0" ActualRows="0" ActualEndOfScans="0" ActualExecutions="0" />
                                              <Sort Distinct="false">
                                                <OrderBy>
                                                  </OrderByColumn>
                                                </OrderBy>
                                                <RelOp AvgRowSize="11" EstimateCPU="0.234113" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="12374.3" LogicalOp="Inner Join" NodeId="13" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="0.643113">
                                                  <OutputList>
                                                  </OutputList>
                                                  <MemoryFractions Input="1" Output="0.654102" />
                                                    <RunTimeCountersPerThread Thread="2" ActualRows="3366" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="4" ActualRows="3371" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="3" ActualRows="3423" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="1" ActualRows="3390" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="0" ActualExecutions="0" />
                                                  <Hash>
                                                    <DefinedValues />
                                                    <HashKeysBuild>
                                                    </HashKeysBuild>
                                                    <HashKeysProbe>
                                                      <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="fkContentID" />
                                                    </HashKeysProbe>
                                                    <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Bitmap Create" NodeId="14" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.0652864">
                                                      <OutputList>
                                                      </OutputList>
                                                        <RunTimeCountersPerThread Thread="2" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="4" ActualRows="1929" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="3" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="1" ActualRows="1941" ActualEndOfScans="1" ActualExecutions="1" />
                                                      <Bitmap>
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                            <ColumnReference Column="Bitmap1021" />
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                        <HashKeys>
                                                        </HashKeys>
                                                        <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Repartition Streams" NodeId="15" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.0652864">
                                                          <OutputList>
                                                          </OutputList>
                                                          <Parallelism PartitioningType="Hash">
                                                            <PartitionColumns>
                                                            </PartitionColumns>
                                                            <RelOp AvgRowSize="11" EstimateCPU="0.004352" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="16" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.027477" TableCardinality="7770">
                                                              <OutputList>
                                                              </OutputList>
        <RunTimeCountersPerThread Thread="2" ActualRows="3026" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="4" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="3" ActualRows="2232" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="1" ActualRows="2512" ActualEndOfScans="1" ActualExecutions="1" />
                                                              <IndexScan Ordered="false" ForcedIndex="false" NoExpandHint="false">
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
                                                              </IndexScan>
                                                            </RelOp>
                                                          </Parallelism>
                                                        </RelOp>
                                                      </Bitmap>
                                                    </RelOp>
                                                    <RelOp AvgRowSize="15" EstimateCPU="0.145058" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Repartition Streams" NodeId="17" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.343712">
                                                      <OutputList>
                                                      </OutputList>
                                                        <RunTimeCountersPerThread Thread="2" ActualRows="3368" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="4" ActualRows="3373" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <PartitionColumns>
                                                        </PartitionColumns>
                                                        <RelOp AvgRowSize="15" EstimateCPU="0.0407136" EstimateIO="0.15794" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Index Scan" NodeId="18" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.198653" TableCardinality="73882">
                                                          <OutputList>
                                                          </OutputList>
                                                            <RunTimeCountersPerThread Thread="4" ActualRows="3159" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="2" ActualRows="3433" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="1" ActualRows="4020" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="3" ActualRows="2954" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <DefinedValues>
                                                              <DefinedValue>
                                                              </DefinedValue>
                                                              <DefinedValue>
                                                              </DefinedValue>
                                                            </DefinedValues>
                                                            <Predicate>
                                                              <ScalarOperator ScalarString="PROBE([Bitmap1021],[PhoenixCMS_RC].[dbo].[tblWorkContent].[fkContentID],N'[IN ROW]')">
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Intrinsic>
                                                              </ScalarOperator>
                                                            </Predicate>
                                                          </IndexScan>
                                                        </RelOp>
                                                      </Parallelism>
                                                    </RelOp>
                                                  </Hash>
                                                </RelOp>
                                              </Sort>
                                            </RelOp>
                                          </Parallelism>
                                        </RelOp>
                                      </Top>
                                    </RelOp>
                                  </Update>
                                </RelOp>
                                <RelOp AvgRowSize="11" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Index Scan" NodeId="22" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                                  <OutputList>
                                  </OutputList>
                                  <IndexScan Ordered="true" ScanDirection="FORWARD" ForcedIndex="true" ForceSeek="false" NoExpandHint="false">
                                    <DefinedValues>
                                      <DefinedValue>
                                      </DefinedValue>
                                    </DefinedValues>
                                  </IndexScan>
                                </RelOp>
                              </Merge>
                            </RelOp>
                            <RelOp AvgRowSize="9" EstimateCPU="0.000182306" EstimateIO="0.003125" EstimateRebinds="11135.8" EstimateRewinds="0.210669" EstimateRows="2.30057" LogicalOp="Index Seek" NodeId="24" Parallel="false" PhysicalOp="Index Seek" EstimatedTotalSubtreeCost="2.34662" TableCardinality="1285560">
                              <OutputList />
                                <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="13550" ActualExecutions="13550" />
                                <DefinedValues />
                                <SeekPredicates>
                                  <SeekPredicateNew>
                                    <SeekKeys>
                                        <RangeColumns>
                                        </RangeColumns>
                                        <RangeExpressions>
                                            <Identifier>
                                            </Identifier>
                                          </ScalarOperator>
                                        </RangeExpressions>
                                      </Prefix>
                                    </SeekKeys>
                                  </SeekPredicateNew>
                                </SeekPredicates>
                              </IndexScan>
                            </RelOp>
                          </NestedLoops>
                        </RelOp>
                        <Predicate>
                          <ScalarOperator ScalarString="CASE WHEN NOT [Expr1018] IS NULL THEN (0) ELSE CASE WHEN NOT [Expr1019] IS NULL THEN (1) ELSE NULL END END">
                            <IF>
                              <Condition>
                                <ScalarOperator>
                                  <Logical Operation="NOT">
                                    <ScalarOperator>
                                      <Logical Operation="IS NULL">
                                        <ScalarOperator>
                                          <Identifier>
                                          </Identifier>
                                        </ScalarOperator>
                                      </Logical>
                                    </ScalarOperator>
                                  </Logical>
                                </ScalarOperator>
                              </Condition>
                              <Then>
                                <ScalarOperator>
                                </ScalarOperator>
                              </Then>
                              <Else>
                                <ScalarOperator>
                                  <IF>
                                    <Condition>
                                      <ScalarOperator>
                                          <ScalarOperator>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                            </Logical>
                                          </ScalarOperator>
                                        </Logical>
                                      </ScalarOperator>
                                    </Condition>
                                    <Then>
                                      <ScalarOperator>
                                        <Const ConstValue="(1)" />
                                      </ScalarOperator>
                                    </Then>
                                    <Else>
                                      <ScalarOperator>
                                        <Const ConstValue="NULL" />
                                      </ScalarOperator>
                                    </Else>
                                  </IF>
                                </ScalarOperator>
                              </Else>
                            </IF>
                          </ScalarOperator>
                        </Predicate>
                      </Assert>
                    </RelOp>
                  </Spool>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00523219" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="9021.01" LogicalOp="Assert" NodeId="26" Parallel="false" PhysicalOp="Assert" EstimatedTotalSubtreeCost="6.72911">
                  <OutputList />
                    <RelOp AvgRowSize="9" EstimateCPU="0.191724" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="9021.01" LogicalOp="Left Semi Join" NodeId="27" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="6.72387">
                      <OutputList>
                        <ColumnReference Column="Expr1020" />
                      </OutputList>
                          <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="fkMasterVersionID" />
                        <Residual>
                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[fkMasterVersionID]=[PhoenixCMS_RC].[dbo].[tblWorkContent].[pkID]">
                              <ScalarOperator>
                                <Identifier>
                                </Identifier>
                              </ScalarOperator>
                              <ScalarOperator>
                                <Identifier>
                                </Identifier>
                              </ScalarOperator>
                            </Compare>
                          </ScalarOperator>
                        </Residual>
                        <RelOp AvgRowSize="11" EstimateCPU="0.606852" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="10023.4" LogicalOp="Sort" NodeId="28" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="6.30167">
                          <OutputList>
                          </OutputList>
                            <OrderBy>
                              </OrderByColumn>
                            </OrderBy>
                            <RelOp AvgRowSize="11" EstimateCPU="0.000551221" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="10023.4" LogicalOp="Eager Spool" NodeId="29" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="5.68355">
                              <OutputList>
                              </OutputList>
                              <Spool PrimaryNodeId="2" />
                            </RelOp>
                          </Sort>
                        </RelOp>
                        <RelOp AvgRowSize="11" EstimateCPU="0.0814272" EstimateIO="0.149051" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73882" LogicalOp="Index Scan" NodeId="30" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.230478" TableCardinality="73882">
                          <OutputList>
                          </OutputList>
                            <RunTimeCountersPerThread Thread="0" ActualRows="60326" ActualEndOfScans="0" ActualExecutions="1" />
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                          </IndexScan>
                        </RelOp>
                      </Merge>
                    </RelOp>
                    <Predicate>
                      <ScalarOperator ScalarString="CASE WHEN NOT [Expr1020] IS NULL THEN (0) ELSE NULL END">
                        <IF>
                          <Condition>
                            <ScalarOperator>
                                <ScalarOperator>
                                    <ScalarOperator>
                                      <Identifier>
                                      </Identifier>
                                    </ScalarOperator>
                                  </Logical>
                                </ScalarOperator>
                              </Logical>
                            </ScalarOperator>
                          </Condition>
                          <Then>
                            <ScalarOperator>
                            </ScalarOperator>
                          </Then>
                          <Else>
                            <ScalarOperator>
                            </ScalarOperator>
                          </Else>
                        </IF>
                      </ScalarOperator>
                    </Predicate>
                  </Assert>
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="23" StatementEstRows="3698.88" StatementId="11" StatementOptmLevel="FULL" StatementSubTreeCost="3.41819" StatementText="DELETE FROM
		    tblProperty
		WHERE
		    PageLink IN (SELECT pkID FROM #pages)
" StatementType="DELETE" QueryHash="0x3A06E944194F255D" QueryPlanHash="0x9034275F4B535685">
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="4560" CachedPlanSize="104" CompileTime="43" CompileCPU="18" CompileMemory="656">
            <RelOp AvgRowSize="9" EstimateCPU="0.0221933" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Sequence" NodeId="0" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="3.41819">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="13" ActualEndOfScans="1" ActualExecutions="1" />
              <Sequence>
                <RelOp AvgRowSize="9" EstimateCPU="0.00369888" EstimateIO="0.077351" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Delete" NodeId="1" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.557041">
                  <OutputList />
                  <Update WithOrderedPrefetch="true" DMLRequestSort="true">
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IDX_tblContentProperty_fkPropertyDefinitionID]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="15" EstimateCPU="0.068494" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Sort" NodeId="3" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.475991">
                      <OutputList>
                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="pkID" />
                        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="fkPropertyDefinitionID" />
                      </OutputList>
                        <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="13" ActualEndOfScans="1" ActualExecutions="1" />
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.000239018" EstimateIO="0.00219103" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Eager Spool" NodeId="4" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.396236">
                          <OutputList>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="fkContentID" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="fkLanguageBranchID" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="ScopeName" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="guid" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="ContentType" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="ContentLink" />
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="LinkGuid" />
                          </OutputList>
                          <Spool>
                            <RelOp AvgRowSize="518" EstimateCPU="0.00369888" EstimateIO="0.941479" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Delete" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="2.35903">
                              <OutputList>
                              </OutputList>
                              <Update WithUnorderedPrefetch="true" DMLRequestSort="false">
                                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[PK_tblContentProperty]" IndexKind="Clustered" />
                                <RelOp AvgRowSize="11" EstimateCPU="0.000369888" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Top" NodeId="7" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="1.41385">
                                  <OutputList>
                                  </OutputList>
                                    <TopExpression>
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="11" EstimateCPU="0.0324786" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3215.64" LogicalOp="Inner Join" NodeId="9" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="1.41348">
                                      <OutputList>
                                      </OutputList>
                                      <NestedLoops Optimized="false" WithUnorderedPrefetch="true">
                                        <OuterReferences>
                                          <ColumnReference Column="Expr1009" />
                                        </OuterReferences>
                                        <RelOp AvgRowSize="11" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="11" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                                          <OutputList>
                                          </OutputList>
                                            <RunTimeCountersPerThread Thread="0" ActualRows="7770" ActualEndOfScans="1" ActualExecutions="1" />
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                          </IndexScan>
                                        </RelOp>
                                        <RelOp AvgRowSize="11" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="7769" EstimateRewinds="0" EstimateRows="1" LogicalOp="Index Seek" NodeId="12" Parallel="false" PhysicalOp="Index Seek" EstimatedTotalSubtreeCost="1.34917" TableCardinality="1439020">
                                          <OutputList>
                                          </OutputList>
                                            <RunTimeCountersPerThread Thread="0" ActualRows="13" ActualEndOfScans="7770" ActualExecutions="7770" />
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IDX_tblContentProperty_ContentLink]" IndexKind="NonClustered" />
                                            <SeekPredicates>
                                              <SeekPredicateNew>
                                                <SeekKeys>
                                                    <RangeColumns>
                                                    </RangeColumns>
                                                    <RangeExpressions>
                                                      <ScalarOperator ScalarString="[tempdb].[dbo].[#pages].[pkID]">
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                    </RangeExpressions>
                                                  </Prefix>
                                                </SeekKeys>
                                              </SeekPredicateNew>
                                            </SeekPredicates>
                                          </IndexScan>
                                        </RelOp>
                                      </NestedLoops>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                              </Update>
                            </RelOp>
                          </Spool>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00369888" EstimateIO="0.0391422" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Delete" NodeId="15" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.518832">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IDX_tblContentProperty_ScopeName]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="465" EstimateCPU="0.0684945" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Sort" NodeId="17" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.475991">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.000239018" EstimateIO="0.00219103" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Eager Spool" NodeId="18" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.396236">
                          <OutputList>
                          </OutputList>
                          <Spool PrimaryNodeId="4" />
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00369888" EstimateIO="0.152866" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Delete" NodeId="19" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.632555">
                  <OutputList />
                    <RelOp AvgRowSize="31" EstimateCPU="0.0684941" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Sort" NodeId="21" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.475991">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.000239018" EstimateIO="0.00219103" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Eager Spool" NodeId="22" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.396236">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00369888" EstimateIO="0.0530363" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Delete" NodeId="23" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.532726">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IDX_tblContentProperty_ContentTypeID]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="15" EstimateCPU="0.068494" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Sort" NodeId="25" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.475991">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.000239018" EstimateIO="0.00219103" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Eager Spool" NodeId="26" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.396236">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00369888" EstimateIO="0.0724012" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Delete" NodeId="27" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.552091">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IDX_tblContentProperty_fkContentID]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="19" EstimateCPU="0.068494" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Sort" NodeId="29" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.475991">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.000239018" EstimateIO="0.00219103" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Eager Spool" NodeId="30" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.396236">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00369888" EstimateIO="0.123063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Delete" NodeId="31" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="0.602753">
                  <OutputList />
                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IX_tblContentProperty]" IndexKind="NonClustered" />
                    <RelOp AvgRowSize="23" EstimateCPU="0.0684941" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Sort" NodeId="33" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.475991">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.000239018" EstimateIO="0.00219103" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3698.88" LogicalOp="Eager Spool" NodeId="34" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="0.396236">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="28" StatementEstRows="1" StatementId="12" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.0165715" StatementText="DELETE FROM
	    tblPropertyDefault
	WHERE
	    PageLink IN ( SELECT pkID FROM #pages )
" StatementType="DELETE" QueryHash="0x2A7612BB0E844564" QueryPlanHash="0x22A45F1FCD65F89D">
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="24" CompileTime="16" CompileCPU="8" CompileMemory="520">
            <RelOp AvgRowSize="9" EstimateCPU="1E-06" EstimateIO="0.01" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="0.0165715">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblPropertyDefinitionDefault]" Index="[PK_tblPropertyDefinitionDefault]" IndexKind="Clustered" />
                <RelOp AvgRowSize="11" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="1" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.00657048">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblPropertyDefinitionDefault]" Column="pkID" />
                  </OutputList>
                    <TopExpression>
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="11" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="3" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.00657038">
                      <OutputList>
                      </OutputList>
                        <OuterReferences>
                          <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblPropertyDefinitionDefault]" Column="ContentLink" />
                        </OuterReferences>
                        <RelOp AvgRowSize="15" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Scan" NodeId="4" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                          <OutputList>
                          </OutputList>
                          <IndexScan Ordered="true" ForcedIndex="false" NoExpandHint="false">
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                          </IndexScan>
                        </RelOp>
                        <RelOp AvgRowSize="9" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="7770">
                          <OutputList />
                            <DefinedValues />
                            <SeekPredicates>
                              <SeekPredicateNew>
                                <SeekKeys>
                                    <RangeColumns>
                                    </RangeColumns>
                                    <RangeExpressions>
                                      <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblPropertyDefinitionDefault].[ContentLink]">
                                        <Identifier>
                                        </Identifier>
                                      </ScalarOperator>
                                    </RangeExpressions>
                                  </Prefix>
                                </SeekKeys>
                              </SeekPredicateNew>
                            </SeekPredicates>
                          </IndexScan>
                        </RelOp>
                      </NestedLoops>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="29" StatementEstRows="1" StatementId="13" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.843185" StatementText="UPDATE
	    tblPage
	SET
	    ArchivePageGUID = NULL
	WHERE
	    ArchivePageGUID IN ( SELECT PageGUID FROM #pages )
	-- Remove fetch data from any external pages pointing to us
" StatementType="UPDATE" QueryHash="0x29B1FDA4F24922E8" QueryPlanHash="0xAF9C9D4B30ED1EE3">
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="2032" CachedPlanSize="40" CompileTime="31" CompileCPU="31" CompileMemory="496">
            <RelOp AvgRowSize="9" EstimateCPU="2E-06" EstimateIO="0.02" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Update" NodeId="1" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="0.843185">
              <OutputList />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[PK_tblContent]" IndexKind="Clustered" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ArchiveContentGUID]" IndexKind="NonClustered" />
                <SetPredicate>
                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContent].[ArchiveContentGUID] = [Expr1006]">
                    <ScalarExpressionList>
                      <ScalarOperator>
                        <MultipleAssign>
                          <Assign>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="ArchiveContentGUID" />
                            <ScalarOperator>
                              <Identifier>
                                <ColumnReference Column="Expr1006" />
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                        </MultipleAssign>
                      </ScalarOperator>
                    </ScalarExpressionList>
                  </ScalarOperator>
                </SetPredicate>
                <RelOp AvgRowSize="31" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="2" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.823183">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="pkID" />
                    <ColumnReference Column="Expr1013" />
                  </OutputList>
                  <ComputeScalar>
                    <DefinedValues>
                      <DefinedValue>
                        <ScalarOperator ScalarString="[Expr1013]">
                          <Identifier>
                          </Identifier>
                        </ScalarOperator>
                      </DefinedValue>
                    </DefinedValues>
                    <RelOp AvgRowSize="31" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="3" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.823183">
                      <OutputList>
                      </OutputList>
                      <ComputeScalar>
                        <DefinedValues>
                          <DefinedValue>
                            <ScalarOperator ScalarString="CASE WHEN [Expr1010] THEN (0) ELSE (1) END">
                              <IF>
                                <Condition>
                                  <ScalarOperator>
                                    <Identifier>
                                      <ColumnReference Column="Expr1010" />
                                    </Identifier>
                                  </ScalarOperator>
                                </Condition>
                                <Then>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Then>
                                <Else>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Else>
                              </IF>
                            </ScalarOperator>
                          </DefinedValue>
                        </DefinedValues>
                        <RelOp AvgRowSize="28" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="4" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.823183">
                          <OutputList>
                          </OutputList>
                          <ComputeScalar>
                            <DefinedValues>
                              <DefinedValue>
                                <ScalarOperator ScalarString="NULL">
                                </ScalarOperator>
                              </DefinedValue>
                            </DefinedValues>
                            <RelOp AvgRowSize="12" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="5" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.823183">
                              <OutputList>
                              </OutputList>
                                <TopExpression>
                                  </ScalarOperator>
                                </TopExpression>
                                <RelOp AvgRowSize="12" EstimateCPU="0.000100012" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Distinct Sort" NodeId="7" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.823183">
                                  <OutputList>
                                  </OutputList>
                                  <MemoryFractions Input="0.031746" Output="1" />
                                    <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                                  <Sort Distinct="true">
                                    <OrderBy>
                                      </OrderByColumn>
                                    </OrderBy>
                                    <RelOp AvgRowSize="12" EstimateCPU="0.163532" EstimateIO="0.000313" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="8" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="0.811822">
                                      <OutputList>
                                      </OutputList>
                                      <Merge ManyToMany="true">
                                          <ColumnReference Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Column="PageGUID" />
                                        <Residual>
                                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContent].[ArchiveContentGUID]=[tempdb].[dbo].[#pages].[PageGUID]">
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                            </Compare>
                                          </ScalarOperator>
                                        </Residual>
                                        <RelOp AvgRowSize="28" EstimateCPU="0.0067414" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Compute Scalar" NodeId="9" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.283438">
                                          <OutputList>
                                          </OutputList>
                                          <ComputeScalar>
                                            <DefinedValues>
                                              <DefinedValue>
                                                <ScalarOperator ScalarString="CASE WHEN [PhoenixCMS_RC].[dbo].[tblContent].[ArchiveContentGUID] IS NULL THEN (1) ELSE (0) END">
                                                  <IF>
                                                    <Condition>
                                                      <ScalarOperator>
                                                        <Compare CompareOp="BINARY IS">
                                                          <ScalarOperator>
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                          <ScalarOperator>
                                                          </ScalarOperator>
                                                        </Compare>
                                                      </ScalarOperator>
                                                    </Condition>
                                                    <Then>
                                                      <ScalarOperator>
                                                      </ScalarOperator>
                                                    </Then>
                                                    <Else>
                                                      <ScalarOperator>
                                                      </ScalarOperator>
                                                    </Else>
                                                  </IF>
                                                </ScalarOperator>
                                              </DefinedValue>
                                            </DefinedValues>
                                            <RelOp AvgRowSize="27" EstimateCPU="0.0743124" EstimateIO="0.202384" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Index Scan" NodeId="10" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.276697" TableCardinality="67414">
                                              <OutputList>
                                              </OutputList>
                                                <RunTimeCountersPerThread Thread="0" ActualRows="67414" ActualEndOfScans="1" ActualExecutions="1" />
                                                <DefinedValues>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                </DefinedValues>
                                              </IndexScan>
                                            </RelOp>
                                          </ComputeScalar>
                                        </RelOp>
                                        <RelOp AvgRowSize="23" EstimateCPU="0.321446" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Sort" NodeId="14" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.364536">
                                          <OutputList>
                                          </OutputList>
                                          <MemoryFractions Input="0.968254" Output="0.968254" />
                                            <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="1" ActualEndOfScans="0" ActualExecutions="1" />
                                            <OrderBy>
                                              </OrderByColumn>
                                            </OrderBy>
                                            <RelOp AvgRowSize="23" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="15" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                                              <OutputList>
                                              </OutputList>
                                                <DefinedValues>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                </DefinedValues>
                                              </IndexScan>
                                            </RelOp>
                                          </Sort>
                                        </RelOp>
                                      </Merge>
                                    </RelOp>
                                  </Sort>
                                </RelOp>
                              </Top>
                            </RelOp>
                          </ComputeScalar>
                        </RelOp>
                      </ComputeScalar>
                    </RelOp>
                  </ComputeScalar>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="30" StatementEstRows="1" StatementId="14" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.880131" StatementText="UPDATE
	    tblPageLanguage
	SET
	    PageLinkGUID = NULL,
	    FetchData=0,
	    LinkURL=
			SELECT TOP 1
		      '~/link/' + CONVERT(NVARCHAR(32),REPLACE((select top 1 PageGUID FROM tblPage where tblPage.pkID = tblPageLanguage.fkPageID),'-','')) + '.aspx'
			FROM
			    tblPageType
			WHERE
			    tblPageType.pkID=(SELECT tblPage.fkPageTypeID FROM tblPage WHERE tblPage.pkID=tblPageLanguage.fkPageID)
	 WHERE
	    PageLinkGUID IN ( SELECT PageGUID FROM #pages )
	-- Remove ALC, categories and the properties
" StatementType="UPDATE" QueryHash="0x7D8F740CCD689C05" QueryPlanHash="0x6B18CE992CFAB578">
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="2032" CachedPlanSize="64" CompileTime="84" CompileCPU="53" CompileMemory="1288">
            <RelOp AvgRowSize="9" EstimateCPU="2E-06" EstimateIO="0.02" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Update" NodeId="1" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="0.880131">
              <OutputList />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Index="[PK_tblContentLanguage]" IndexKind="Clustered" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Index="[IDX_tblContentLanguage_ContentLinkGUID]" IndexKind="NonClustered" />
                <SetPredicate>
                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentLanguage].[ContentLinkGUID] = [Expr1006],[PhoenixCMS_RC].[dbo].[tblContentLanguage].[FetchData] = [Expr1007],[PhoenixCMS_RC].[dbo].[tblContentLanguage].[LinkURL] = [Expr1020]">
                      <ScalarOperator>
                        <MultipleAssign>
                          <Assign>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Column="ContentLinkGUID" />
                            <ScalarOperator>
                              <Identifier>
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                          <Assign>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Column="FetchData" />
                            <ScalarOperator>
                              <Identifier>
                                <ColumnReference Column="Expr1007" />
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                          <Assign>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Column="LinkURL" />
                            <ScalarOperator>
                              <Identifier>
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                        </MultipleAssign>
                      </ScalarOperator>
                  </ScalarOperator>
                </SetPredicate>
                <RelOp AvgRowSize="295" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="2" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.860129">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Column="fkContentID" />
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Column="fkLanguageBranchID" />
                    <ColumnReference Column="Expr1036" />
                  </OutputList>
                  <ComputeScalar>
                    <DefinedValues>
                      <DefinedValue>
                        <ScalarOperator ScalarString="[Expr1036]">
                          <Identifier>
                          </Identifier>
                        </ScalarOperator>
                      </DefinedValue>
                    </DefinedValues>
                    <RelOp AvgRowSize="295" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="3" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.860129">
                      <OutputList>
                      </OutputList>
                      <ComputeScalar>
                        <DefinedValues>
                          <DefinedValue>
                            <ScalarOperator ScalarString="CASE WHEN [Expr1024] THEN (0) ELSE (1) END">
                              <IF>
                                <Condition>
                                  <ScalarOperator>
                                    <Identifier>
                                      <ColumnReference Column="Expr1024" />
                                    </Identifier>
                                  </ScalarOperator>
                                </Condition>
                                <Then>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Then>
                                <Else>
                                  <ScalarOperator>
                                  </ScalarOperator>
                                </Else>
                              </IF>
                            </ScalarOperator>
                          </DefinedValue>
                        </DefinedValues>
                        <RelOp AvgRowSize="291" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="4" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.860129">
                          <OutputList>
                          </OutputList>
                          <ComputeScalar>
                            <DefinedValues>
                              <DefinedValue>
                                </ScalarOperator>
                              </DefinedValue>
                              <DefinedValue>
                                </ScalarOperator>
                              </DefinedValue>
                              <DefinedValue>
                                <ScalarOperator ScalarString="CONVERT_IMPLICIT(nvarchar(255),[Expr1019],0)">
                                  <Convert DataType="nvarchar" Length="510" Style="0" Implicit="true">
                                    <ScalarOperator>
                                      <Identifier>
                                        <ColumnReference Column="Expr1019" />
                                      </Identifier>
                                    </ScalarOperator>
                                  </Convert>
                                </ScalarOperator>
                              </DefinedValue>
                            </DefinedValues>
                            <RelOp AvgRowSize="64" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Left Outer Join" NodeId="5" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.860128">
                              <OutputList>
                              </OutputList>
                              <NestedLoops Optimized="false">
                                <OuterReferences>
                                </OuterReferences>
                                <RelOp AvgRowSize="16" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="6" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.853554">
                                  <OutputList>
                                  </OutputList>
                                    <TopExpression>
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="16" EstimateCPU="0.000100016" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Distinct Sort" NodeId="8" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.853554">
                                      <OutputList>
                                      </OutputList>
                                        <OrderBy>
                                          </OrderByColumn>
                                          </OrderByColumn>
                                        </OrderBy>
                                        <RelOp AvgRowSize="16" EstimateCPU="0.163532" EstimateIO="0.000313" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="9" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="0.842192">
                                          <OutputList>
                                          </OutputList>
                                          <RunTimeInformation>
                                          </RunTimeInformation>
                                            <Residual>
                                              <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentLanguage].[ContentLinkGUID]=[tempdb].[dbo].[#pages].[PageGUID]">
                                                  <ScalarOperator>
                                                    <Identifier>
                                                    </Identifier>
                                                  </ScalarOperator>
                                                  <ScalarOperator>
                                                    <Identifier>
                                                    </Identifier>
                                                  </ScalarOperator>
                                                </Compare>
                                              </ScalarOperator>
                                            </Residual>
                                            <RelOp AvgRowSize="32" EstimateCPU="0.0067414" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Compute Scalar" NodeId="10" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.313808">
                                              <OutputList>
                                              </OutputList>
                                              <ComputeScalar>
                                                <DefinedValues>
                                                  <DefinedValue>
                                                    <ScalarOperator ScalarString="CASE WHEN [PhoenixCMS_RC].[dbo].[tblContentLanguage].[ContentLinkGUID] IS NULL THEN (1) ELSE (0) END">
                                                      <IF>
                                                        <Condition>
                                                          <ScalarOperator>
                                                              <ScalarOperator>
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                              <ScalarOperator>
                                                              </ScalarOperator>
                                                            </Compare>
                                                          </ScalarOperator>
                                                        </Condition>
                                                        <Then>
                                                          <ScalarOperator>
                                                          </ScalarOperator>
                                                        </Then>
                                                        <Else>
                                                          <ScalarOperator>
                                                          </ScalarOperator>
                                                        </Else>
                                                      </IF>
                                                    </ScalarOperator>
                                                  </DefinedValue>
                                                </DefinedValues>
                                                <RelOp AvgRowSize="31" EstimateCPU="0.0743124" EstimateIO="0.232755" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Index Scan" NodeId="11" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.307067" TableCardinality="67414">
                                                  <OutputList>
                                                  </OutputList>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                  </IndexScan>
                                                </RelOp>
                                              </ComputeScalar>
                                            </RelOp>
                                            <RelOp AvgRowSize="23" EstimateCPU="0.321446" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Sort" NodeId="15" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.364536">
                                              <OutputList>
                                              </OutputList>
                                                <OrderBy>
                                                  </OrderByColumn>
                                                </OrderBy>
                                                <RelOp AvgRowSize="23" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="16" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                                                  <OutputList>
                                                  </OutputList>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                  </IndexScan>
                                                </RelOp>
                                              </Sort>
                                            </RelOp>
                                          </Merge>
                                        </RelOp>
                                      </Sort>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                                <RelOp AvgRowSize="55" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="20" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.00657068">
                                  <OutputList>
                                  </OutputList>
                                  <Top RowCount="false" IsPercent="false" WithTies="false">
                                    <TopExpression>
                                      <ScalarOperator ScalarString="(1)">
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="55" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="21" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.00657058">
                                      <OutputList>
                                      </OutputList>
                                      <ComputeScalar>
                                        <DefinedValues>
                                          <DefinedValue>
                                            <ScalarOperator ScalarString="(N'~/link/'+CONVERT(nvarchar(32),replace(CONVERT_IMPLICIT(varchar(40),[PhoenixCMS_RC].[dbo].[tblContent].[ContentGUID],0),'-',''),0))+N'.aspx'">
                                              <Arithmetic Operation="ADD">
                                                <ScalarOperator>
                                                    <ScalarOperator>
                                                      <Const ConstValue="N'~/link/'" />
                                                    </ScalarOperator>
                                                    <ScalarOperator>
                                                      <Convert DataType="nvarchar" Length="64" Style="0" Implicit="false">
                                                        <ScalarOperator>
                                                          <Intrinsic FunctionName="replace">
                                                            <ScalarOperator>
                                                              <Convert DataType="varchar" Length="40" Style="0" Implicit="true">
        <ScalarOperator>
        <Identifier>
        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="ContentGUID" />
        </Identifier>
        </ScalarOperator>
                                                              </Convert>
                                                            </ScalarOperator>
                                                            <ScalarOperator>
                                                              <Const ConstValue="'-'" />
                                                            </ScalarOperator>
                                                            <ScalarOperator>
                                                              <Const ConstValue="''" />
                                                            </ScalarOperator>
                                                          </Intrinsic>
                                                        </ScalarOperator>
                                                      </Convert>
                                                    </ScalarOperator>
                                                  </Arithmetic>
                                                </ScalarOperator>
                                                <ScalarOperator>
                                                  <Const ConstValue="N'.aspx'" />
                                                </ScalarOperator>
                                              </Arithmetic>
                                            </ScalarOperator>
                                          </DefinedValue>
                                        </DefinedValues>
                                        <RelOp AvgRowSize="23" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Left Outer Join" NodeId="22" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.00657048">
                                          <OutputList>
                                          </OutputList>
                                            <RelOp AvgRowSize="9" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="23" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="67414">
                                              <OutputList />
                                                <DefinedValues />
                                                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[PK_tblContent]" TableReferenceId="1" IndexKind="Clustered" />
                                                <SeekPredicates>
                                                  <SeekPredicateNew>
                                                    <SeekKeys>
                                                        <RangeColumns>
                                                        </RangeColumns>
                                                        <RangeExpressions>
                                                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentLanguage].[fkContentID]">
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                        </RangeExpressions>
                                                      </Prefix>
                                                    </SeekKeys>
                                                  </SeekPredicateNew>
                                                </SeekPredicates>
                                              </IndexScan>
                                            </RelOp>
                                            <RelOp AvgRowSize="23" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="24" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.0032832">
                                              <OutputList>
                                              </OutputList>
                                                <TopExpression>
                                                  </ScalarOperator>
                                                </TopExpression>
                                                <RelOp AvgRowSize="23" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="25" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="67414">
                                                  <OutputList>
                                                  </OutputList>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[PK_tblContent]" TableReferenceId="2" IndexKind="Clustered" />
                                                    <SeekPredicates>
                                                      <SeekPredicateNew>
                                                        <SeekKeys>
                                                            <RangeColumns>
                                                            </RangeColumns>
                                                            <RangeExpressions>
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                            </RangeExpressions>
                                                          </Prefix>
                                                        </SeekKeys>
                                                      </SeekPredicateNew>
                                                    </SeekPredicates>
                                                  </IndexScan>
                                                </RelOp>
                                              </Top>
                                            </RelOp>
                                          </NestedLoops>
                                        </RelOp>
                                      </ComputeScalar>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                              </NestedLoops>
                            </RelOp>
                          </ComputeScalar>
                        </RelOp>
                      </ComputeScalar>
                    </RelOp>
                  </ComputeScalar>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="31" StatementEstRows="1" StatementId="15" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.0265725" StatementText="DELETE FROM
	    tblCategoryPage
	WHERE
	    fkPageID IN ( SELECT pkID FROM #pages )
" StatementType="DELETE" QueryHash="0x20DA5B9EBE7E597C" QueryPlanHash="0x060B7F43B46BBD8D">
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="24" CompileTime="8" CompileCPU="8" CompileMemory="512">
            <RelOp AvgRowSize="9" EstimateCPU="2E-06" EstimateIO="0.02" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="0.0265725">
              <OutputList />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentCategory]" Index="[PK_tblContentCategory]" IndexKind="Clustered" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentCategory]" Index="[IDX_tblContentCategory_fkContentID]" IndexKind="NonClustered" />
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentCategory]" Column="pkID" />
                  </OutputList>
                    <TopExpression>
                      </ScalarOperator>
                    </TopExpression>
                      <OutputList>
                      </OutputList>
                        <OuterReferences>
                          <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentCategory]" Column="fkContentID" />
                        </OuterReferences>
                        <RelOp AvgRowSize="15" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Index Scan" NodeId="4" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                          <OutputList>
                          </OutputList>
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                          </IndexScan>
                        </RelOp>
                          <OutputList />
                            <DefinedValues />
                            <SeekPredicates>
                              <SeekPredicateNew>
                                <SeekKeys>
                                    <RangeColumns>
                                    </RangeColumns>
                                    <RangeExpressions>
                                      <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentCategory].[fkContentID]">
                                        <Identifier>
                                        </Identifier>
                                      </ScalarOperator>
                                    </RangeExpressions>
                                  </Prefix>
                                </SeekKeys>
                              </SeekPredicateNew>
                            </SeekPredicates>
                          </IndexScan>
                        </RelOp>
                      </NestedLoops>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="32" StatementEstRows="118679" StatementId="16" StatementOptmLevel="FULL" StatementSubTreeCost="117.874" StatementText="DELETE FROM
	    tblProperty
	WHERE
" StatementType="DELETE" QueryHash="0x5B392E8D9F869763" QueryPlanHash="0x879D3F82A37DB362">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="85984" CachedPlanSize="128" CompileTime="48" CompileCPU="47" CompileMemory="808">
            <RelOp AvgRowSize="9" EstimateCPU="0.712073" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sequence" NodeId="0" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="117.874">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="166225" ActualEndOfScans="1" ActualExecutions="1" />
              <Sequence>
                <RelOp AvgRowSize="9" EstimateCPU="0.118679" EstimateIO="2.381" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Delete" NodeId="1" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="19.2395">
                  <OutputList />
                    <RelOp AvgRowSize="15" EstimateCPU="9.18254" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sort" NodeId="3" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="16.7398">
                      <OutputList>
                      </OutputList>
                        <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="166225" ActualEndOfScans="1" ActualExecutions="1" />
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.00715438" EstimateIO="0.0021927" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Eager Spool" NodeId="4" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="7.54604">
                          <OutputList>
                          </OutputList>
                          <Spool>
                            <RelOp AvgRowSize="518" EstimateCPU="0.118679" EstimateIO="30.1066" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Delete" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="45.113">
                              <OutputList>
                              </OutputList>
                                <RelOp AvgRowSize="11" EstimateCPU="0.0118679" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Top" NodeId="7" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="14.8877">
                                  <OutputList>
                                  </OutputList>
                                    <TopExpression>
                                      </ScalarOperator>
                                    </TopExpression>
                                    <RelOp AvgRowSize="11" EstimateCPU="0.733066" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Gather Streams" NodeId="9" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="14.8758">
                                      <OutputList>
                                      </OutputList>
                                      <Parallelism>
                                        <OrderBy>
                                          </OrderByColumn>
                                        </OrderBy>
                                        <RelOp AvgRowSize="11" EstimateCPU="4.59127" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sort" NodeId="10" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="14.1428">
                                          <OutputList>
                                          </OutputList>
                                          <MemoryFractions Input="0.506281" Output="1" />
                                            <RunTimeCountersPerThread Thread="1" ActualRebinds="1" ActualRewinds="0" ActualRows="41272" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="4" ActualRebinds="1" ActualRewinds="0" ActualRows="41138" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="2" ActualRebinds="1" ActualRewinds="0" ActualRows="41685" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="3" ActualRebinds="1" ActualRewinds="0" ActualRows="42130" ActualEndOfScans="1" ActualExecutions="1" />
                                            <OrderBy>
                                              </OrderByColumn>
                                            </OrderBy>
                                            <RelOp AvgRowSize="11" EstimateCPU="3.4383" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Inner Join" NodeId="11" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="9.54588">
                                              <OutputList>
                                              </OutputList>
                                              <MemoryFractions Input="1" Output="0.493719" />
                                                <RunTimeCountersPerThread Thread="1" ActualRows="41272" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="4" ActualRows="41138" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="2" ActualRows="41685" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="3" ActualRows="42130" ActualEndOfScans="1" ActualExecutions="1" />
                                              <Hash>
                                                <DefinedValues />
                                                <HashKeysBuild>
                                                </HashKeysBuild>
                                                <HashKeysProbe>
                                                </HashKeysProbe>
                                                <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Bitmap Create" NodeId="12" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.0652864">
                                                  <OutputList>
                                                  </OutputList>
                                                  <Bitmap>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                        <ColumnReference Column="Bitmap1009" />
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                    <HashKeys>
                                                    </HashKeys>
                                                    <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Repartition Streams" NodeId="13" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.0652864">
                                                      <OutputList>
                                                      </OutputList>
                                                        <PartitionColumns>
                                                        </PartitionColumns>
                                                        <RelOp AvgRowSize="11" EstimateCPU="0.004352" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="14" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.027477" TableCardinality="7770">
                                                          <OutputList>
                                                          </OutputList>
                                                            <RunTimeCountersPerThread Thread="4" ActualRows="1116" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="1" ActualRows="3305" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="2" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <RunTimeCountersPerThread Thread="3" ActualRows="3349" ActualEndOfScans="1" ActualExecutions="1" />
                                                            <DefinedValues>
                                                              <DefinedValue>
                                                              </DefinedValue>
                                                            </DefinedValues>
                                                          </IndexScan>
                                                        </RelOp>
                                                      </Parallelism>
                                                    </RelOp>
                                                  </Bitmap>
                                                </RelOp>
                                                <RelOp AvgRowSize="15" EstimateCPU="2.29874" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1439020" LogicalOp="Repartition Streams" NodeId="15" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="6.04229">
                                                  <OutputList>
                                                  </OutputList>
                                                    <RunTimeCountersPerThread Thread="1" ActualRows="360251" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="4" ActualRows="358554" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="2" ActualRows="361563" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="3" ActualRows="358321" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <PartitionColumns>
                                                    </PartitionColumns>
                                                    <RelOp AvgRowSize="15" EstimateCPU="0.79154" EstimateIO="2.95201" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1439020" LogicalOp="Index Scan" NodeId="16" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="3.74355" TableCardinality="1439020">
                                                      <OutputList>
                                                      </OutputList>
                                                        <RunTimeCountersPerThread Thread="4" ActualRows="383416" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="1" ActualRows="262683" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="2" ActualRows="341703" ActualEndOfScans="1" ActualExecutions="1" />
                                                        <RunTimeCountersPerThread Thread="3" ActualRows="450887" ActualEndOfScans="1" ActualExecutions="1" />
                                                      <IndexScan Ordered="true" ScanDirection="FORWARD" ForcedIndex="false" ForceSeek="false" NoExpandHint="false">
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                        <Predicate>
                                                          <ScalarOperator ScalarString="PROBE([Bitmap1009],[PhoenixCMS_RC].[dbo].[tblContentProperty].[fkContentID],N'[IN ROW]')">
                                                            <Intrinsic FunctionName="PROBE">
                                                              <ScalarOperator>
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                              <ScalarOperator>
        <Identifier>
        </Identifier>
                                                              </ScalarOperator>
                                                              <ScalarOperator>
        <Const ConstValue="N'[IN ROW]'" />
                                                              </ScalarOperator>
                                                            </Intrinsic>
                                                          </ScalarOperator>
                                                        </Predicate>
                                                      </IndexScan>
                                                    </RelOp>
                                                  </Parallelism>
                                                </RelOp>
                                              </Hash>
                                            </RelOp>
                                          </Sort>
                                        </RelOp>
                                      </Parallelism>
                                    </RelOp>
                                  </Top>
                                </RelOp>
                              </Update>
                            </RelOp>
                          </Spool>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.118679" EstimateIO="1.15506" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Delete" NodeId="20" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="18.0136">
                  <OutputList />
                    <RelOp AvgRowSize="465" EstimateCPU="9.18255" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sort" NodeId="22" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="16.7398">
                      <OutputList>
                      </OutputList>
                      <MemoryFractions Input="1" Output="1" />
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.00715438" EstimateIO="0.0021927" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Eager Spool" NodeId="23" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="7.54604">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.118679" EstimateIO="4.80389" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Delete" NodeId="24" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="21.6624">
                  <OutputList />
                    <RelOp AvgRowSize="31" EstimateCPU="9.18254" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sort" NodeId="26" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="16.7398">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.00715438" EstimateIO="0.0021927" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Eager Spool" NodeId="27" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="7.54604">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.118679" EstimateIO="1.60086" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Delete" NodeId="28" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="18.4594">
                  <OutputList />
                    <RelOp AvgRowSize="15" EstimateCPU="9.18254" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sort" NodeId="30" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="16.7398">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.00715438" EstimateIO="0.0021927" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Eager Spool" NodeId="31" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="7.54604">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.118679" EstimateIO="2.22218" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Delete" NodeId="32" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="19.0807">
                  <OutputList />
                    <RelOp AvgRowSize="19" EstimateCPU="9.18254" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sort" NodeId="34" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="16.7398">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.00715438" EstimateIO="0.0021927" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Eager Spool" NodeId="35" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="7.54604">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.118679" EstimateIO="3.84766" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Delete" NodeId="36" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="20.7062">
                  <OutputList />
                    <RelOp AvgRowSize="23" EstimateCPU="9.18254" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Sort" NodeId="38" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="16.7398">
                      <OutputList>
                      </OutputList>
                        <OrderBy>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="518" EstimateCPU="0.00715438" EstimateIO="0.0021927" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="118679" LogicalOp="Eager Spool" NodeId="39" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="7.54604">
                          <OutputList>
                          </OutputList>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Update>
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="33" StatementEstRows="26274.4" StatementId="17" StatementOptmLevel="FULL" StatementSubTreeCost="4.75776" StatementText="DELETE FROM
	    tblContentAccess
	WHERE
	    fkContentID IN ( SELECT pkID FROM #pages )
-- KEYWORDS AND INDEXING
" StatementType="DELETE" QueryHash="0xBCFB950A0C6813B4" QueryPlanHash="0x8647F3184F92F6F5">
          <StatementSetOptions ANSI_NULLS="true" ANSI_PADDING="true" ANSI_WARNINGS="true" ARITHABORT="true" CONCAT_NULL_YIELDS_NULL="true" NUMERIC_ROUNDABORT="false" QUOTED_IDENTIFIER="true" />
          <QueryPlan DegreeOfParallelism="1" MemoryGrant="4480" CachedPlanSize="24" CompileTime="19" CompileCPU="19" CompileMemory="592">
            <RelOp AvgRowSize="9" EstimateCPU="0.0262744" EstimateIO="1.24067" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="26274.4" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="4.75776">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="31199" ActualEndOfScans="1" ActualExecutions="1" />
              <Update DMLRequestSort="true">
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentAccess]" Index="[PK_tblContentAccess]" IndexKind="Clustered" />
                <RelOp AvgRowSize="37" EstimateCPU="0.00262744" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="26274.4" LogicalOp="Top" NodeId="1" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="3.49081">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentAccess]" Column="fkContentID" />
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentAccess]" Column="Name" />
                  </OutputList>
                  <Top RowCount="true" IsPercent="false" WithTies="false">
                    <TopExpression>
                      <ScalarOperator ScalarString="(0)">
                        <Const ConstValue="(0)" />
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="37" EstimateCPU="1.77064" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="26274" LogicalOp="Sort" NodeId="3" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="3.48818">
                      <OutputList>
                      </OutputList>
                        <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="31199" ActualEndOfScans="1" ActualExecutions="1" />
                      <Sort Distinct="false">
                        <OrderBy>
                          <OrderByColumn Ascending="true">
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="37" EstimateCPU="0.4382" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="26274" LogicalOp="Inner Join" NodeId="4" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="1.70629">
                          <OutputList>
                          </OutputList>
                          <Merge ManyToMany="false">
                            <InnerSideJoinColumns>
                            </InnerSideJoinColumns>
                            <OuterSideJoinColumns>
                              <ColumnReference Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Column="pkID" />
                            </OuterSideJoinColumns>
                            <Residual>
                              <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentAccess].[fkContentID]=[tempdb].[dbo].[#pages].[pkID]">
                                <Compare CompareOp="EQ">
                                  <ScalarOperator>
                                    <Identifier>
                                    </Identifier>
                                  </ScalarOperator>
                                  <ScalarOperator>
                                    <Identifier>
                                    </Identifier>
                                  </ScalarOperator>
                                </Compare>
                              </ScalarOperator>
                            </Residual>
                            <RelOp AvgRowSize="11" EstimateCPU="0.008704" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.031829" TableCardinality="7770">
                              <OutputList>
                              </OutputList>
                                <DefinedValues>
                                  <DefinedValue>
                                  </DefinedValue>
                                </DefinedValues>
                                <Object Database="[tempdb]" Schema="[dbo]" Table="[#pages]" Index="[PK__#pages____40A359E36921665A]" IndexKind="Clustered" />
                              </IndexScan>
                            </RelOp>
                            <RelOp AvgRowSize="37" EstimateCPU="0.216834" EstimateIO="1.01942" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="196979" LogicalOp="Clustered Index Scan" NodeId="6" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="1.23626" TableCardinality="196979">
                              <OutputList>
                              </OutputList>
                                <RunTimeCountersPerThread Thread="0" ActualRows="196377" ActualEndOfScans="0" ActualExecutions="1" />
                                <DefinedValues>
                                  <DefinedValue>
                                  </DefinedValue>
                                  <DefinedValue>
                                  </DefinedValue>
                                </DefinedValues>
                              </IndexScan>
                            </RelOp>
                          </Merge>
                        </RelOp>
                      </Sort>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="34" StatementEstRows="16393.8" StatementId="18" StatementOptmLevel="FULL" StatementSubTreeCost="5.23118" StatementText="DELETE FROM
	    tblContentSoftlink
	WHERE
	    fkOwnerContentID IN ( SELECT pkID FROM #pages )
-- PAGETYPES
" StatementType="DELETE" QueryHash="0x9D4D878DBF0BB77E" QueryPlanHash="0xF8FC59B2DC079642">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="9376" CachedPlanSize="56" CompileTime="39" CompileCPU="39" CompileMemory="656">
            <RelOp AvgRowSize="9" EstimateCPU="0.0491814" EstimateIO="3.78608" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="16393.8" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="5.23118">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="17921" ActualEndOfScans="1" ActualExecutions="1" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentSoftlink]" Index="[PK_tblContentSoftlink]" IndexKind="Clustered" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentSoftlink]" Index="[IDX_tblContentSoftlink_fkContentID]" IndexKind="NonClustered" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentSoftlink]" Index="[IDX_tblContentSoftlink_fkReferencedContentGUID]" IndexKind="NonClustered" />
                <RelOp AvgRowSize="11" EstimateCPU="0.00163938" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="16393.8" LogicalOp="Top" NodeId="2" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="1.39592">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentSoftlink]" Column="pkID" />
                  </OutputList>
                    <TopExpression>
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="11" EstimateCPU="0.125818" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="16392.4" LogicalOp="Gather Streams" NodeId="4" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="1.39428">
                      <OutputList>
                      </OutputList>
                      <Parallelism>
                        <OrderBy>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="11" EstimateCPU="0.526767" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="16392.4" LogicalOp="Sort" NodeId="5" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="1.26846">
                          <OutputList>
                          </OutputList>
                          <MemoryFractions Input="0.392453" Output="1" />
                            <RunTimeCountersPerThread Thread="4" ActualRebinds="1" ActualRewinds="0" ActualRows="4636" ActualEndOfScans="1" ActualExecutions="1" />
                            <RunTimeCountersPerThread Thread="2" ActualRebinds="1" ActualRewinds="0" ActualRows="4490" ActualEndOfScans="1" ActualExecutions="1" />
                            <RunTimeCountersPerThread Thread="3" ActualRebinds="1" ActualRewinds="0" ActualRows="4550" ActualEndOfScans="1" ActualExecutions="1" />
                            <RunTimeCountersPerThread Thread="1" ActualRebinds="1" ActualRewinds="0" ActualRows="4245" ActualEndOfScans="1" ActualExecutions="1" />
                            <RunTimeCountersPerThread Thread="0" ActualRebinds="0" ActualRewinds="0" ActualRows="0" ActualEndOfScans="0" ActualExecutions="0" />
                            <OrderBy>
                              </OrderByColumn>
                            </OrderBy>
                            <RelOp AvgRowSize="11" EstimateCPU="0.276895" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="16392.4" LogicalOp="Inner Join" NodeId="6" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="0.736063">
                              <OutputList>
                              </OutputList>
                              <MemoryFractions Input="1" Output="0.607547" />
                                <RunTimeCountersPerThread Thread="4" ActualRows="4636" ActualEndOfScans="1" ActualExecutions="1" />
                                <RunTimeCountersPerThread Thread="2" ActualRows="4490" ActualEndOfScans="1" ActualExecutions="1" />
                                <RunTimeCountersPerThread Thread="3" ActualRows="4550" ActualEndOfScans="1" ActualExecutions="1" />
                                <RunTimeCountersPerThread Thread="1" ActualRows="4245" ActualEndOfScans="1" ActualExecutions="1" />
                                <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="0" ActualExecutions="0" />
                              <Hash>
                                <DefinedValues />
                                <HashKeysBuild>
                                </HashKeysBuild>
                                <HashKeysProbe>
                                  <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentSoftlink]" Column="fkOwnerContentID" />
                                </HashKeysProbe>
                                <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Bitmap Create" NodeId="7" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.0652864">
                                  <OutputList>
                                  </OutputList>
                                    <RunTimeCountersPerThread Thread="4" ActualRows="1929" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="2" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="3" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="1" ActualRows="1941" ActualEndOfScans="1" ActualExecutions="1" />
                                  <Bitmap>
                                    <DefinedValues>
                                      <DefinedValue>
                                      </DefinedValue>
                                    </DefinedValues>
                                    <HashKeys>
                                    </HashKeys>
                                    <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Repartition Streams" NodeId="8" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.0652864">
                                      <OutputList>
                                      </OutputList>
                                      <Parallelism PartitioningType="Hash">
                                        <PartitionColumns>
                                        </PartitionColumns>
                                        <RelOp AvgRowSize="11" EstimateCPU="0.004352" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="9" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.027477" TableCardinality="7770">
                                          <OutputList>
                                          </OutputList>
                                            <RunTimeCountersPerThread Thread="4" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="2" ActualRows="1910" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="1" ActualRows="3069" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="3" ActualRows="2791" ActualEndOfScans="1" ActualExecutions="1" />
                                          <IndexScan Ordered="false" ForcedIndex="false" NoExpandHint="false">
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                          </IndexScan>
                                        </RelOp>
                                      </Parallelism>
                                    </RelOp>
                                  </Bitmap>
                                </RelOp>
                                <RelOp AvgRowSize="15" EstimateCPU="0.17237" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="91194" LogicalOp="Repartition Streams" NodeId="10" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.393878">
                                  <OutputList>
                                  </OutputList>
                                    <RunTimeCountersPerThread Thread="4" ActualRows="13842" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="2" ActualRows="13284" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="3" ActualRows="13128" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="1" ActualRows="13856" ActualEndOfScans="1" ActualExecutions="1" />
                                    <PartitionColumns>
                                    </PartitionColumns>
                                    <RelOp AvgRowSize="15" EstimateCPU="0.0502352" EstimateIO="0.171273" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="91194" LogicalOp="Index Scan" NodeId="11" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.221508" TableCardinality="91194">
                                      <OutputList>
                                      </OutputList>
                                        <RunTimeCountersPerThread Thread="4" ActualRows="2177" ActualEndOfScans="1" ActualExecutions="1" />
                                        <RunTimeCountersPerThread Thread="2" ActualRows="2723" ActualEndOfScans="1" ActualExecutions="1" />
                                        <RunTimeCountersPerThread Thread="3" ActualRows="25065" ActualEndOfScans="1" ActualExecutions="1" />
                                        <RunTimeCountersPerThread Thread="1" ActualRows="24145" ActualEndOfScans="1" ActualExecutions="1" />
                                        <DefinedValues>
                                          <DefinedValue>
                                          </DefinedValue>
                                          <DefinedValue>
                                          </DefinedValue>
                                        </DefinedValues>
                                        <Predicate>
                                          <ScalarOperator ScalarString="PROBE([Bitmap1009],[PhoenixCMS_RC].[dbo].[tblContentSoftlink].[fkOwnerContentID],N'[IN ROW]')">
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Intrinsic>
                                          </ScalarOperator>
                                        </Predicate>
                                      </IndexScan>
                                    </RelOp>
                                  </Parallelism>
                                </RelOp>
                              </Hash>
                            </RelOp>
                          </Sort>
                        </RelOp>
                      </Parallelism>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="35" StatementEstRows="1" StatementId="19" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.0165716" StatementText="UPDATE
	    tblPageTypeDefault
	SET
	    fkArchivePageID=NULL
	WHERE fkArchivePageID IN (SELECT pkID FROM #pages)
-- PAGE/TREE
" StatementType="UPDATE" QueryHash="0xE7F61518194491AC" QueryPlanHash="0x54FDC1D2A0A63E15">
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="24" CompileTime="10" CompileCPU="10" CompileMemory="608">
            <RelOp AvgRowSize="9" EstimateCPU="1E-06" EstimateIO="0.01" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Update" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Update" EstimatedTotalSubtreeCost="0.0165716">
              <OutputList />
              <Update DMLRequestSort="false">
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentTypeDefault]" Index="[PK_tblContentTypeDefault]" IndexKind="Clustered" />
                <SetPredicate>
                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentTypeDefault].[fkArchiveContentID] = [Expr1006]">
                      <ScalarOperator>
                        <MultipleAssign>
                          <Assign>
                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentTypeDefault]" Column="fkArchiveContentID" />
                            <ScalarOperator>
                              <Identifier>
                              </Identifier>
                            </ScalarOperator>
                          </Assign>
                        </MultipleAssign>
                      </ScalarOperator>
                  </ScalarOperator>
                </SetPredicate>
                <RelOp AvgRowSize="15" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Compute Scalar" NodeId="1" Parallel="false" PhysicalOp="Compute Scalar" EstimatedTotalSubtreeCost="0.00657058">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentTypeDefault]" Column="pkID" />
                  </OutputList>
                  <ComputeScalar>
                    <DefinedValues>
                      <DefinedValue>
                          <Const ConstValue="NULL" />
                        </ScalarOperator>
                      </DefinedValue>
                    </DefinedValues>
                    <RelOp AvgRowSize="11" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="2" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.00657048">
                      <OutputList>
                      </OutputList>
                        <TopExpression>
                          </ScalarOperator>
                        </TopExpression>
                        <RelOp AvgRowSize="11" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="4" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.00657038">
                          <OutputList>
                          </OutputList>
                            <OuterReferences>
                            </OuterReferences>
                            <RelOp AvgRowSize="15" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Scan" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                              <OutputList>
                              </OutputList>
                                <DefinedValues>
                                  <DefinedValue>
                                  </DefinedValue>
                                  <DefinedValue>
                                  </DefinedValue>
                                </DefinedValues>
                              </IndexScan>
                            </RelOp>
                            <RelOp AvgRowSize="9" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="6" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="7770">
                              <OutputList />
                                <DefinedValues />
                                <SeekPredicates>
                                  <SeekPredicateNew>
                                    <SeekKeys>
                                      <Prefix ScanType="EQ">
                                        <RangeColumns>
                                        </RangeColumns>
                                        <RangeExpressions>
                                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentTypeDefault].[fkArchiveContentID]">
                                            <Identifier>
                                            </Identifier>
                                          </ScalarOperator>
                                        </RangeExpressions>
                                      </Prefix>
                                    </SeekKeys>
                                  </SeekPredicateNew>
                                </SeekPredicates>
                              </IndexScan>
                            </RelOp>
                          </NestedLoops>
                        </RelOp>
                      </Top>
                    </RelOp>
                  </ComputeScalar>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="36" StatementEstRows="34481.9" StatementId="20" StatementOptmLevel="FULL" StatementSubTreeCost="5.92022" StatementText="DELETE FROM
	    tblTree
	WHERE
	    fkChildID IN ( SELECT pkID FROM #pages )
" StatementType="DELETE" QueryHash="0x21C0D9B221C97BB5" QueryPlanHash="0xD624C13CCB1C19A4">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="13856" CachedPlanSize="48" CompileTime="41" CompileCPU="41" CompileMemory="624">
            <RelOp AvgRowSize="9" EstimateCPU="0.0689637" EstimateIO="1.29656" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="34481.9" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="5.92022">
              <OutputList />
                <RunTimeCountersPerThread Thread="0" ActualRows="49880" ActualEndOfScans="1" ActualExecutions="1" />
              <Update WithOrderedPrefetch="true" DMLRequestSort="true">
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblTree]" Index="[PK_tblTree]" IndexKind="Clustered" />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblTree]" Index="[IDX_tblTree_fkChildID]" IndexKind="NonClustered" />
                <RelOp AvgRowSize="15" EstimateCPU="0.00344819" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="34481.9" LogicalOp="Top" NodeId="2" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="4.5547">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblTree]" Column="fkParentID" />
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblTree]" Column="fkChildID" />
                  </OutputList>
                    <TopExpression>
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="15" EstimateCPU="0.246296" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="34481.9" LogicalOp="Gather Streams" NodeId="3" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="4.55125">
                      <OutputList>
                      </OutputList>
                      <Parallelism>
                        <OrderBy>
                          </OrderByColumn>
                          </OrderByColumn>
                        </OrderBy>
                        <RelOp AvgRowSize="15" EstimateCPU="1.19291" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="34481.9" LogicalOp="Sort" NodeId="4" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="4.30496">
                          <OutputList>
                          </OutputList>
                          <MemoryFractions Input="0.429752" Output="1" />
                            <RunTimeCountersPerThread Thread="1" ActualRebinds="1" ActualRewinds="0" ActualRows="12448" ActualEndOfScans="1" ActualExecutions="1" />
                            <RunTimeCountersPerThread Thread="3" ActualRebinds="1" ActualRewinds="0" ActualRows="12526" ActualEndOfScans="1" ActualExecutions="1" />
                            <RunTimeCountersPerThread Thread="2" ActualRebinds="1" ActualRewinds="0" ActualRows="12528" ActualEndOfScans="1" ActualExecutions="1" />
                            <RunTimeCountersPerThread Thread="4" ActualRebinds="1" ActualRewinds="0" ActualRows="12378" ActualEndOfScans="1" ActualExecutions="1" />
                            <OrderBy>
                              </OrderByColumn>
                              </OrderByColumn>
                            </OrderBy>
                            <RelOp AvgRowSize="15" EstimateCPU="1.23836" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="34481.9" LogicalOp="Inner Join" NodeId="6" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="3.10642">
                              <OutputList>
                              </OutputList>
                              <MemoryFractions Input="1" Output="0.570248" />
                                <RunTimeCountersPerThread Thread="3" ActualRows="12526" ActualEndOfScans="1" ActualExecutions="1" />
                                <RunTimeCountersPerThread Thread="1" ActualRows="12448" ActualEndOfScans="1" ActualExecutions="1" />
                                <RunTimeCountersPerThread Thread="2" ActualRows="12528" ActualEndOfScans="1" ActualExecutions="1" />
                                <RunTimeCountersPerThread Thread="4" ActualRows="12378" ActualEndOfScans="1" ActualExecutions="1" />
                              <Hash>
                                <DefinedValues />
                                <HashKeysBuild>
                                </HashKeysBuild>
                                <HashKeysProbe>
                                </HashKeysProbe>
                                  <OutputList>
                                  </OutputList>
                                  <Bitmap>
                                    <DefinedValues>
                                      <DefinedValue>
                                      </DefinedValue>
                                    </DefinedValues>
                                    <HashKeys>
                                    </HashKeys>
                                      <OutputList>
                                      </OutputList>
                                        <PartitionColumns>
                                        </PartitionColumns>
                                          <OutputList>
                                          </OutputList>
                                            <RunTimeCountersPerThread Thread="3" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="4" ActualRows="5023" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="1" ActualRows="2747" ActualEndOfScans="1" ActualExecutions="1" />
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                          </IndexScan>
                                        </RelOp>
                                      </Parallelism>
                                    </RelOp>
                                  </Bitmap>
                                </RelOp>
                                <RelOp AvgRowSize="15" EstimateCPU="0.825983" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="505496" LogicalOp="Repartition Streams" NodeId="10" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="1.80276">
                                  <OutputList>
                                  </OutputList>
                                    <RunTimeCountersPerThread Thread="3" ActualRows="31229" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="1" ActualRows="31207" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="2" ActualRows="31206" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="4" ActualRows="31091" ActualEndOfScans="1" ActualExecutions="1" />
                                    <PartitionColumns>
                                    </PartitionColumns>
                                    <RelOp AvgRowSize="15" EstimateCPU="0.278101" EstimateIO="0.698681" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="505496" LogicalOp="Index Scan" NodeId="11" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.976782" TableCardinality="505496">
                                      <OutputList>
                                      </OutputList>
                                        <RunTimeCountersPerThread Thread="3" ActualRows="27873" ActualEndOfScans="1" ActualExecutions="1" />
                                        <RunTimeCountersPerThread Thread="2" ActualRows="48289" ActualEndOfScans="1" ActualExecutions="1" />
                                        <RunTimeCountersPerThread Thread="4" ActualRows="38124" ActualEndOfScans="1" ActualExecutions="1" />
                                        <RunTimeCountersPerThread Thread="1" ActualRows="10447" ActualEndOfScans="1" ActualExecutions="1" />
                                        <DefinedValues>
                                          <DefinedValue>
                                          </DefinedValue>
                                          <DefinedValue>
                                          </DefinedValue>
                                        </DefinedValues>
                                        <Predicate>
                                          <ScalarOperator ScalarString="PROBE([Bitmap1009],[PhoenixCMS_RC].[dbo].[tblTree].[fkChildID],N'[IN ROW]')">
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                              <ScalarOperator>
                                              </ScalarOperator>
                                            </Intrinsic>
                                          </ScalarOperator>
                                        </Predicate>
                                      </IndexScan>
                                    </RelOp>
                                  </Parallelism>
                                </RelOp>
                              </Hash>
                            </RelOp>
                          </Sort>
                        </RelOp>
                      </Parallelism>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="37" StatementEstRows="43824.6" StatementId="21" StatementOptmLevel="FULL" StatementSubTreeCost="6.79206" StatementText="DELETE FROM
	    tblTree
	WHERE
	    fkParentID IN ( SELECT pkID FROM #pages )
" StatementType="DELETE" QueryHash="0x9D098B1EDA128246" QueryPlanHash="0x01C765721658E748">
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="24" CompileTime="49" CompileCPU="49" CompileMemory="656">
            <RelOp AvgRowSize="9" EstimateCPU="0.0876493" EstimateIO="1.6461" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="43824.6" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="6.79206">
              <OutputList />
                <RelOp AvgRowSize="15" EstimateCPU="0.00438246" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="43824.6" LogicalOp="Top" NodeId="1" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="5.05831">
                  <OutputList>
                  </OutputList>
                    <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="1" ActualExecutions="1" />
                    <TopExpression>
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="15" EstimateCPU="0.183181" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="43823.3" LogicalOp="Inner Join" NodeId="3" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="5.05392">
                      <OutputList>
                      </OutputList>
                      <NestedLoops Optimized="false" WithOrderedPrefetch="true">
                        <OuterReferences>
                          <ColumnReference Column="Expr1009" />
                        </OuterReferences>
                          <OutputList>
                          </OutputList>
                            <RunTimeCountersPerThread Thread="0" ActualRows="7770" ActualEndOfScans="1" ActualExecutions="1" />
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                          </IndexScan>
                        </RelOp>
                        <RelOp AvgRowSize="15" EstimateCPU="0.000163204" EstimateIO="0.003125" EstimateRebinds="7769" EstimateRewinds="0" EstimateRows="5.64006" LogicalOp="Clustered Index Seek" NodeId="6" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="4.83891" TableCardinality="505496">
                          <OutputList>
                          </OutputList>
                            <RunTimeCountersPerThread Thread="0" ActualRows="0" ActualEndOfScans="7770" ActualExecutions="7770" />
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                            <SeekPredicates>
                              <SeekPredicateNew>
                                <SeekKeys>
                                    <RangeColumns>
                                    </RangeColumns>
                                    <RangeExpressions>
                                      <ScalarOperator ScalarString="[tempdb].[dbo].[#pages].[pkID]">
                                        <Identifier>
                                        </Identifier>
                                      </ScalarOperator>
                                    </RangeExpressions>
                                  </Prefix>
                                </SeekKeys>
                              </SeekPredicateNew>
                            </SeekPredicates>
                          </IndexScan>
                        </RelOp>
                      </NestedLoops>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="38" StatementEstRows="6755.58" StatementId="22" StatementOptmLevel="FULL" StatementSubTreeCost="5.91238" StatementText="DELETE FROM
	    tblPageLanguage
	WHERE
" StatementType="DELETE" QueryHash="0x6AB50C55313117D8" QueryPlanHash="0x9887642455DA3F05">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="10048" CachedPlanSize="72" CompileTime="35" CompileCPU="35" CompileMemory="696">
            <RelOp AvgRowSize="9" EstimateCPU="0.00675558" EstimateIO="0.945085" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6755.58" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Index Delete" EstimatedTotalSubtreeCost="5.91238">
              <OutputList />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Index="[IDX_tblContentLanguage_Name]" IndexKind="NonClustered" />
                <RelOp AvgRowSize="274" EstimateCPU="0.222728" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6755.58" LogicalOp="Sort" NodeId="2" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="4.96054">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Column="Name" />
                  </OutputList>
                  <MemoryFractions Input="0.846906" Output="1" />
                    <RunTimeCountersPerThread Thread="0" ActualRebinds="1" ActualRewinds="0" ActualRows="7770" ActualEndOfScans="1" ActualExecutions="1" />
                    <OrderBy>
                      </OrderByColumn>
                      </OrderByColumn>
                      </OrderByColumn>
                    </OrderBy>
                    <RelOp AvgRowSize="274" EstimateCPU="0.0270223" EstimateIO="3.93675" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6755.58" LogicalOp="Delete" NodeId="3" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="4.72655">
                      <OutputList>
                      </OutputList>
                        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Index="[IDX_tblContentLanguage_ContentGUID]" IndexKind="NonClustered" />
                        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Index="[IDX_tblContentLanguage_ExternalURL]" IndexKind="NonClustered" />
                        <RelOp AvgRowSize="15" EstimateCPU="0.000675558" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6755.58" LogicalOp="Top" NodeId="5" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.76278">
                          <OutputList>
                          </OutputList>
                            <TopExpression>
                              </ScalarOperator>
                            </TopExpression>
                            <RelOp AvgRowSize="15" EstimateCPU="0.0711679" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6755.26" LogicalOp="Gather Streams" NodeId="7" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.762104">
                              <OutputList>
                              </OutputList>
                              <Parallelism>
                                <OrderBy>
                                  </OrderByColumn>
                                  </OrderByColumn>
                                </OrderBy>
                                <RelOp AvgRowSize="15" EstimateCPU="0.11135" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6755.26" LogicalOp="Sort" NodeId="8" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.690937">
                                  <OutputList>
                                  </OutputList>
                                  <MemoryFractions Input="0.248677" Output="0.153094" />
                                    <RunTimeCountersPerThread Thread="4" ActualRebinds="1" ActualRewinds="0" ActualRows="1929" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="2" ActualRebinds="1" ActualRewinds="0" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="3" ActualRebinds="1" ActualRewinds="0" ActualRows="1950" ActualEndOfScans="1" ActualExecutions="1" />
                                    <RunTimeCountersPerThread Thread="1" ActualRebinds="1" ActualRewinds="0" ActualRows="1941" ActualEndOfScans="1" ActualExecutions="1" />
                                    <OrderBy>
                                      </OrderByColumn>
                                      </OrderByColumn>
                                    </OrderBy>
                                    <RelOp AvgRowSize="15" EstimateCPU="0.215013" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6755.26" LogicalOp="Inner Join" NodeId="9" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="0.573956">
                                      <OutputList>
                                      </OutputList>
                                      <MemoryFractions Input="1" Output="0.751323" />
                                      <Hash>
                                        <DefinedValues />
                                        <HashKeysBuild>
                                        </HashKeysBuild>
                                        <HashKeysProbe>
                                        </HashKeysProbe>
                                        <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Bitmap Create" NodeId="10" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.0652864">
                                          <OutputList>
                                          </OutputList>
                                          <Bitmap>
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                            <HashKeys>
                                            </HashKeys>
                                            <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Repartition Streams" NodeId="11" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.0652864">
                                              <OutputList>
                                              </OutputList>
                                                <PartitionColumns>
                                                </PartitionColumns>
                                                <RelOp AvgRowSize="11" EstimateCPU="0.004352" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="12" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.027477" TableCardinality="7770">
                                                  <OutputList>
                                                  </OutputList>
                                                    <RunTimeCountersPerThread Thread="2" ActualRows="1674" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <RunTimeCountersPerThread Thread="3" ActualRows="3027" ActualEndOfScans="1" ActualExecutions="1" />
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                  </IndexScan>
                                                </RelOp>
                                              </Parallelism>
                                            </RelOp>
                                          </Bitmap>
                                        </RelOp>
                                        <RelOp AvgRowSize="15" EstimateCPU="0.134854" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Repartition Streams" NodeId="13" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.293654">
                                          <OutputList>
                                          </OutputList>
                                            <RunTimeCountersPerThread Thread="4" ActualRows="1932" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="2" ActualRows="1952" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="3" ActualRows="1955" ActualEndOfScans="1" ActualExecutions="1" />
                                            <RunTimeCountersPerThread Thread="1" ActualRows="1948" ActualEndOfScans="1" ActualExecutions="1" />
                                            <PartitionColumns>
                                            </PartitionColumns>
                                            <RelOp AvgRowSize="15" EstimateCPU="0.0371562" EstimateIO="0.121644" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Index Scan" NodeId="14" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.1588" TableCardinality="67414">
                                              <OutputList>
                                              </OutputList>
                                                <RunTimeCountersPerThread Thread="2" ActualRows="1455" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="4" ActualRows="1016" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="1" ActualRows="2444" ActualEndOfScans="1" ActualExecutions="1" />
                                                <RunTimeCountersPerThread Thread="3" ActualRows="2872" ActualEndOfScans="1" ActualExecutions="1" />
                                                <DefinedValues>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                </DefinedValues>
                                                <Predicate>
                                                  <ScalarOperator ScalarString="PROBE([Bitmap1009],[PhoenixCMS_RC].[dbo].[tblContentLanguage].[fkContentID],N'[IN ROW]')">
                                                      <ScalarOperator>
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                      <ScalarOperator>
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                      <ScalarOperator>
                                                      </ScalarOperator>
                                                    </Intrinsic>
                                                  </ScalarOperator>
                                                </Predicate>
                                              </IndexScan>
                                            </RelOp>
                                          </Parallelism>
                                        </RelOp>
                                      </Hash>
                                    </RelOp>
                                  </Sort>
                                </RelOp>
                              </Parallelism>
                            </RelOp>
                          </Top>
                        </RelOp>
                      </Update>
                    </RelOp>
                  </Sort>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="39" StatementEstRows="1" StatementId="23" StatementOptmLevel="FULL" StatementOptmEarlyAbortReason="GoodEnoughPlanFound" StatementSubTreeCost="0.0165715" StatementText="DELETE FROM
	    tblPageLanguageSetting
	WHERE
" StatementType="DELETE" QueryHash="0x2994ADE75EDD4538" QueryPlanHash="0x78BCC48BAB73579D">
          <QueryPlan DegreeOfParallelism="1" CachedPlanSize="24" CompileTime="8" CompileCPU="8" CompileMemory="504">
            <RelOp AvgRowSize="9" EstimateCPU="1E-06" EstimateIO="0.01" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Delete" NodeId="0" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="0.0165715">
              <OutputList />
                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguageSetting]" Index="[PK_tblContentLanguageSetting]" IndexKind="Clustered" />
                <RelOp AvgRowSize="15" EstimateCPU="1E-07" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Top" NodeId="1" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.00657048">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguageSetting]" Column="fkContentID" />
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguageSetting]" Column="fkLanguageBranchID" />
                  </OutputList>
                    <TopExpression>
                      </ScalarOperator>
                    </TopExpression>
                    <RelOp AvgRowSize="15" EstimateCPU="4.18E-06" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Inner Join" NodeId="3" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="0.00657038">
                      <OutputList>
                      </OutputList>
                        <OuterReferences>
                        </OuterReferences>
                        <RelOp AvgRowSize="15" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Scan" NodeId="4" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                          <OutputList>
                          </OutputList>
                          <IndexScan Ordered="true" ForcedIndex="false" NoExpandHint="false">
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                          </IndexScan>
                        </RelOp>
                        <RelOp AvgRowSize="9" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Seek" NodeId="5" Parallel="false" PhysicalOp="Clustered Index Seek" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="7770">
                          <OutputList />
                            <DefinedValues />
                            <SeekPredicates>
                              <SeekPredicateNew>
                                <SeekKeys>
                                    <RangeColumns>
                                    </RangeColumns>
                                    <RangeExpressions>
                                      <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentLanguageSetting].[fkContentID]">
                                        <Identifier>
                                        </Identifier>
                                      </ScalarOperator>
                                    </RangeExpressions>
                                  </Prefix>
                                </SeekKeys>
                              </SeekPredicateNew>
                            </SeekPredicates>
                          </IndexScan>
                        </RelOp>
                      </NestedLoops>
                    </RelOp>
                  </Top>
                </RelOp>
              </Update>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
    <Batch>
      <Statements>
        <StmtSimple StatementCompId="40" StatementEstRows="2769.47" StatementId="24" StatementOptmLevel="FULL" StatementSubTreeCost="14.2981" StatementText="DELETE FROM
	    tblPage
	WHERE
	    pkID IN ( SELECT pkID FROM #pages )" StatementType="DELETE" QueryHash="0x40BC27F37DDF64BE" QueryPlanHash="0x7B97181314D9BD1D">
          <QueryPlan DegreeOfParallelism="4" MemoryGrant="10560" CachedPlanSize="144" CompileTime="1939" CompileCPU="1051" CompileMemory="1176">
            <RelOp AvgRowSize="9" EstimateCPU="0.00584666" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="2769.47" LogicalOp="Sequence" NodeId="1" Parallel="false" PhysicalOp="Sequence" EstimatedTotalSubtreeCost="14.2981">
              <OutputList />
              <Sequence>
                <RelOp AvgRowSize="11" EstimateCPU="0.000203866" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3077.19" LogicalOp="Eager Spool" NodeId="2" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="6.9159">
                  <OutputList>
                    <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="pkID" />
                  </OutputList>
                  <Spool>
                    <RelOp AvgRowSize="11" EstimateCPU="0.00917003" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3077.19" LogicalOp="Assert" NodeId="3" Parallel="false" PhysicalOp="Assert" EstimatedTotalSubtreeCost="13.831">
                      <OutputList>
                      </OutputList>
                      <Assert StartupExpression="false">
                        <RelOp AvgRowSize="14" EstimateCPU="0.0142918" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3077.19" LogicalOp="Left Semi Join" NodeId="4" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="13.8218">
                          <OutputList>
                            <ColumnReference Column="Expr1039" />
                            <ColumnReference Column="Expr1040" />
                            <ColumnReference Column="Expr1041" />
                            <ColumnReference Column="Expr1042" />
                            <ColumnReference Column="Expr1043" />
                            <ColumnReference Column="Expr1044" />
                            <ColumnReference Column="Expr1045" />
                            <ColumnReference Column="Expr1046" />
                            <ColumnReference Column="Expr1047" />
                          </OutputList>
                          <NestedLoops Optimized="true" WithUnorderedPrefetch="true">
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                            <OuterReferences>
                              <ColumnReference Column="Expr1053" />
                            </OuterReferences>
                            <ProbeColumn>
                            </ProbeColumn>
                            <RelOp AvgRowSize="13" EstimateCPU="0.0158798" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3419.1" LogicalOp="Left Semi Join" NodeId="7" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="12.5908">
                              <OutputList>
                              </OutputList>
                              <NestedLoops Optimized="false" WithUnorderedPrefetch="true">
                                <DefinedValues>
                                  <DefinedValue>
                                  </DefinedValue>
                                </DefinedValues>
                                <OuterReferences>
                                  <ColumnReference Column="Expr1052" />
                                </OuterReferences>
                                <ProbeColumn>
                                </ProbeColumn>
                                <RelOp AvgRowSize="12" EstimateCPU="0.172517" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3799" LogicalOp="Left Semi Join" NodeId="9" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="11.3929">
                                  <OutputList>
                                  </OutputList>
                                    <Residual>
                                      <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentSoftlink].[fkOwnerContentID]=[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
                                          <ScalarOperator>
                                            <Identifier>
                                            </Identifier>
                                          </ScalarOperator>
                                          <ScalarOperator>
                                            <Identifier>
                                            </Identifier>
                                          </ScalarOperator>
                                        </Compare>
                                      </ScalarOperator>
                                    </Residual>
                                    <RelOp AvgRowSize="12" EstimateCPU="0.0102474" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="4221.11" LogicalOp="Left Semi Join" NodeId="10" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="11.0143">
                                      <OutputList>
                                      </OutputList>
                                      <RunTimeInformation>
                                      </RunTimeInformation>
                                        <Residual>
                                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentCategory].[fkContentID]=[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                            </Compare>
                                          </ScalarOperator>
                                        </Residual>
                                        <RelOp AvgRowSize="12" EstimateCPU="0.369841" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="4690.12" LogicalOp="Left Semi Join" NodeId="11" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="11.0008">
                                          <OutputList>
                                          </OutputList>
                                            <Residual>
                                              <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentAccess].[fkContentID]=[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
                                                  <ScalarOperator>
                                                    <Identifier>
                                                    </Identifier>
                                                  </ScalarOperator>
                                                  <ScalarOperator>
                                                    <Identifier>
                                                    </Identifier>
                                                  </ScalarOperator>
                                                </Compare>
                                              </ScalarOperator>
                                            </Residual>
                                            <RelOp AvgRowSize="12" EstimateCPU="0.0113366" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="5211.25" LogicalOp="Left Semi Join" NodeId="12" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="9.669">
                                              <OutputList>
                                              </OutputList>
                                                <Residual>
                                                  <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentLanguageSetting].[fkContentID]=[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
                                                      <ScalarOperator>
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                      <ScalarOperator>
                                                        <Identifier>
                                                        </Identifier>
                                                      </ScalarOperator>
                                                    </Compare>
                                                  </ScalarOperator>
                                                </Residual>
                                                <RelOp AvgRowSize="12" EstimateCPU="0.150732" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="5790.28" LogicalOp="Left Semi Join" NodeId="13" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="9.65437">
                                                  <OutputList>
                                                  </OutputList>
                                                      <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Column="fkContentID" />
                                                    <Residual>
                                                      <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContentLanguage].[fkContentID]=[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
                                                          <ScalarOperator>
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                          <ScalarOperator>
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                        </Compare>
                                                      </ScalarOperator>
                                                    </Residual>
                                                    <RelOp AvgRowSize="12" EstimateCPU="0.0298807" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="6433.64" LogicalOp="Left Semi Join" NodeId="14" Parallel="false" PhysicalOp="Nested Loops" EstimatedTotalSubtreeCost="5.99549">
                                                      <OutputList>
                                                      </OutputList>
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                        <OuterReferences>
                                                          <ColumnReference Column="Expr1051" />
                                                        </OuterReferences>
                                                        <ProbeColumn>
                                                        </ProbeColumn>
                                                        <RelOp AvgRowSize="12" EstimateCPU="0.15684" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7148.49" LogicalOp="Left Semi Join" NodeId="16" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="4.12837">
                                                          <OutputList>
                                                          </OutputList>
                                                              <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Column="fkContentID" />
                                                            <Residual>
                                                              <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblWorkContent].[fkContentID]=[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        </Compare>
                                                              </ScalarOperator>
                                                            </Residual>
                                                            <RelOp AvgRowSize="11" EstimateCPU="0.0635421" EstimateIO="2.94519" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7942.77" LogicalOp="Delete" NodeId="17" Parallel="false" PhysicalOp="Clustered Index Delete" EstimatedTotalSubtreeCost="3.7767">
                                                              <OutputList>
                                                              </OutputList>
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[PK_tblContent]" IndexKind="Clustered" />
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_fkParentID]" IndexKind="NonClustered" />
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ContentGUID]" IndexKind="NonClustered" />
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ContentType]" IndexKind="NonClustered" />
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ArchiveContentGUID]" IndexKind="NonClustered" />
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ContentPath]" IndexKind="NonClustered" />
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_fkContentTypeID]" IndexKind="NonClustered" />
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Index="[IDX_tblContent_ExternalFolderID]" IndexKind="NonClustered" />
        <RelOp AvgRowSize="11" EstimateCPU="0.000794277" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7942.77" LogicalOp="Top" NodeId="19" Parallel="false" PhysicalOp="Top" EstimatedTotalSubtreeCost="0.767963">
        <OutputList>
        </OutputList>
        <TopExpression>
        </ScalarOperator>
        </TopExpression>
        <RelOp AvgRowSize="11" EstimateCPU="0.0746285" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Gather Streams" NodeId="21" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.767169">
        <OutputList>
        </OutputList>
        <Parallelism>
        <OrderBy>
        </OrderByColumn>
        </OrderBy>
        <RelOp AvgRowSize="11" EstimateCPU="0.160723" EstimateIO="0.00563063" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Sort" NodeId="22" Parallel="true" PhysicalOp="Sort" EstimatedTotalSubtreeCost="0.69254">
        <OutputList>
        </OutputList>
        <MemoryFractions Input="0.26455" Output="0.891509" />
        <OrderBy>
        </OrderByColumn>
        </OrderBy>
        <RelOp AvgRowSize="11" EstimateCPU="0.21579" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Inner Join" NodeId="23" Parallel="true" PhysicalOp="Hash Match" EstimatedTotalSubtreeCost="0.526187">
        <OutputList>
        </OutputList>
        <MemoryFractions Input="1" Output="0.73545" />
        <Hash>
        <DefinedValues />
        <HashKeysBuild>
        </HashKeysBuild>
        <HashKeysProbe>
        </HashKeysProbe>
        <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Bitmap Create" NodeId="24" Parallel="true" PhysicalOp="Bitmap" EstimatedTotalSubtreeCost="0.0652864">
        <OutputList>
        </OutputList>
        <Bitmap>
        <DefinedValues>
        <DefinedValue>
        <ColumnReference Column="Bitmap1049" />
        </DefinedValue>
        </DefinedValues>
        <HashKeys>
        </HashKeys>
        <RelOp AvgRowSize="11" EstimateCPU="0.0378094" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Repartition Streams" NodeId="25" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.0652864">
        <OutputList>
        </OutputList>
        <PartitionColumns>
        </PartitionColumns>
        <RelOp AvgRowSize="11" EstimateCPU="0.004352" EstimateIO="0.023125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="7770" LogicalOp="Clustered Index Scan" NodeId="26" Parallel="true" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.027477" TableCardinality="7770">
        <OutputList>
        </OutputList>
        <RunTimeCountersPerThread Thread="3" ActualRows="1674" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="4" ActualRows="2233" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="1" ActualRows="2189" ActualEndOfScans="1" ActualExecutions="1" />
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
        </IndexScan>
        </RelOp>
        </Parallelism>
        </RelOp>
        </Bitmap>
        </RelOp>
        <RelOp AvgRowSize="11" EstimateCPU="0.10927" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Repartition Streams" NodeId="27" Parallel="true" PhysicalOp="Parallelism" EstimatedTotalSubtreeCost="0.245107">
        <OutputList>
        </OutputList>
        <RunTimeCountersPerThread Thread="4" ActualRows="1931" ActualEndOfScans="1" ActualExecutions="1" />
        <PartitionColumns>
        </PartitionColumns>
        <RelOp AvgRowSize="11" EstimateCPU="0.0371562" EstimateIO="0.0986806" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Index Scan" NodeId="28" Parallel="true" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.135837" TableCardinality="67414">
        <OutputList>
        </OutputList>
        <RunTimeCountersPerThread Thread="1" ActualRows="3057" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="2" ActualRows="1307" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="3" ActualRows="2071" ActualEndOfScans="1" ActualExecutions="1" />
        <RunTimeCountersPerThread Thread="4" ActualRows="1351" ActualEndOfScans="1" ActualExecutions="1" />
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
        <Predicate>
        <ScalarOperator ScalarString="PROBE([Bitmap1049],[PhoenixCMS_RC].[dbo].[tblContent].[pkID],N'[IN ROW]')">
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        <ScalarOperator>
        </ScalarOperator>
        </Intrinsic>
        </ScalarOperator>
        </Predicate>
        </IndexScan>
        </RelOp>
        </Parallelism>
        </RelOp>
        </Hash>
        </RelOp>
        </Sort>
        </RelOp>
        </Parallelism>
        </RelOp>
        </Top>
        </RelOp>
                                                              </Update>
                                                            </RelOp>
                                                            <RelOp AvgRowSize="11" EstimateCPU="0.0665222" EstimateIO="0.12831" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="60332" LogicalOp="Index Scan" NodeId="32" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.194832" TableCardinality="60332">
                                                              <OutputList>
                                                              </OutputList>
        <RunTimeCountersPerThread Thread="0" ActualRows="60060" ActualEndOfScans="0" ActualExecutions="1" />
                                                              <IndexScan Ordered="true" ScanDirection="FORWARD" ForcedIndex="true" ForceSeek="false" NoExpandHint="false">
        <DefinedValues>
        <DefinedValue>
        </DefinedValue>
        </DefinedValues>
        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContent]" Index="[IDX_tblWorkContent_fkContentID]" IndexKind="NonClustered" />
                                                              </IndexScan>
                                                            </RelOp>
                                                          </Merge>
                                                        </RelOp>
                                                        <RelOp AvgRowSize="9" EstimateCPU="0.000259475" EstimateIO="0.003125" EstimateRebinds="5011.6" EstimateRewinds="2135.89" EstimateRows="9.31588" LogicalOp="Index Seek" NodeId="34" Parallel="false" PhysicalOp="Index Seek" EstimatedTotalSubtreeCost="1.83723" TableCardinality="1285560">
                                                          <OutputList />
                                                            <DefinedValues />
                                                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Index="[IDX_tblWorkContentProperty_ContentLink]" IndexKind="NonClustered" />
                                                            <SeekPredicates>
                                                              <SeekPredicateNew>
        <SeekKeys>
        <RangeColumns>
        <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblWorkContentProperty]" Column="ContentLink" />
        </RangeColumns>
        <RangeExpressions>
        <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
        <Identifier>
        </Identifier>
        </ScalarOperator>
        </RangeExpressions>
        </Prefix>
        </SeekKeys>
                                                              </SeekPredicateNew>
                                                            </SeekPredicates>
                                                          </IndexScan>
                                                        </RelOp>
                                                      </NestedLoops>
                                                    </RelOp>
                                                    <RelOp AvgRowSize="11" EstimateCPU="0.0657654" EstimateIO="3.44238" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="59644" LogicalOp="Clustered Index Scan" NodeId="35" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="3.50815" TableCardinality="59644">
                                                      <OutputList>
                                                      </OutputList>
                                                        <RunTimeCountersPerThread Thread="0" ActualRows="59429" ActualEndOfScans="0" ActualExecutions="1" />
                                                        <DefinedValues>
                                                          <DefinedValue>
                                                          </DefinedValue>
                                                        </DefinedValues>
                                                        <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentLanguage]" Index="[PK_tblContentLanguage]" IndexKind="Clustered" />
                                                      </IndexScan>
                                                    </RelOp>
                                                  </Merge>
                                                </RelOp>
                                                <RelOp AvgRowSize="11" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Clustered Index Scan" NodeId="37" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                                                  <OutputList>
                                                  </OutputList>
                                                    <DefinedValues>
                                                      <DefinedValue>
                                                      </DefinedValue>
                                                    </DefinedValues>
                                                  </IndexScan>
                                                </RelOp>
                                              </Merge>
                                            </RelOp>
                                            <RelOp AvgRowSize="11" EstimateCPU="0.182515" EstimateIO="0.779421" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="165780" LogicalOp="Clustered Index Scan" NodeId="39" Parallel="false" PhysicalOp="Clustered Index Scan" EstimatedTotalSubtreeCost="0.961936" TableCardinality="165780">
                                              <OutputList>
                                              </OutputList>
                                                <RunTimeCountersPerThread Thread="0" ActualRows="165178" ActualEndOfScans="0" ActualExecutions="1" />
                                                <DefinedValues>
                                                  <DefinedValue>
                                                  </DefinedValue>
                                                </DefinedValues>
                                              </IndexScan>
                                            </RelOp>
                                          </Merge>
                                        </RelOp>
                                        <RelOp AvgRowSize="11" EstimateCPU="0.0001581" EstimateIO="0.003125" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="1" LogicalOp="Index Scan" NodeId="41" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.0032831" TableCardinality="0">
                                          <OutputList>
                                            <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentCategory]" Column="fkContentID" />
                                          </OutputList>
                                            <DefinedValues>
                                              <DefinedValue>
                                              </DefinedValue>
                                            </DefinedValues>
                                            <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentCategory]" Index="[IDX_tblContentCategory_fkContentID]" IndexKind="NonClustered" />
                                          </IndexScan>
                                        </RelOp>
                                      </Merge>
                                    </RelOp>
                                    <RelOp AvgRowSize="11" EstimateCPU="0.0807573" EstimateIO="0.125347" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="73273" LogicalOp="Index Scan" NodeId="43" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.206105" TableCardinality="73273">
                                      <OutputList>
                                      </OutputList>
                                        <RunTimeCountersPerThread Thread="0" ActualRows="73117" ActualEndOfScans="0" ActualExecutions="1" />
                                        <DefinedValues>
                                          <DefinedValue>
                                          </DefinedValue>
                                        </DefinedValues>
                                      </IndexScan>
                                    </RelOp>
                                  </Merge>
                                </RelOp>
                                <RelOp AvgRowSize="9" EstimateCPU="0.000190444" EstimateIO="0.003125" EstimateRebinds="3797.53" EstimateRewinds="0.475204" EstimateRows="3.04035" LogicalOp="Index Seek" NodeId="45" Parallel="false" PhysicalOp="Index Seek" EstimatedTotalSubtreeCost="1.18198" TableCardinality="1272780">
                                  <OutputList />
                                    <DefinedValues />
                                    <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IDX_tblContentProperty_fkContentID]" IndexKind="NonClustered" />
                                    <SeekPredicates>
                                      <SeekPredicateNew>
                                        <SeekKeys>
                                            <RangeColumns>
                                              <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="fkContentID" />
                                            </RangeColumns>
                                            <RangeExpressions>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                            </RangeExpressions>
                                          </Prefix>
                                        </SeekKeys>
                                      </SeekPredicateNew>
                                    </SeekPredicates>
                                  </IndexScan>
                                </RelOp>
                              </NestedLoops>
                            </RelOp>
                            <RelOp AvgRowSize="9" EstimateCPU="0.000263421" EstimateIO="0.003125" EstimateRebinds="3417.63" EstimateRewinds="0.475204" EstimateRows="9.67461" LogicalOp="Index Seek" NodeId="46" Parallel="false" PhysicalOp="Index Seek" EstimatedTotalSubtreeCost="1.21672" TableCardinality="1272780">
                              <OutputList />
                                <DefinedValues />
                                <Object Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Index="[IDX_tblContentProperty_ContentLink]" IndexKind="NonClustered" />
                                <SeekPredicates>
                                  <SeekPredicateNew>
                                    <SeekKeys>
                                        <RangeColumns>
                                          <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContentProperty]" Column="ContentLink" />
                                        </RangeColumns>
                                        <RangeExpressions>
                                            <Identifier>
                                            </Identifier>
                                          </ScalarOperator>
                                        </RangeExpressions>
                                      </Prefix>
                                    </SeekKeys>
                                  </SeekPredicateNew>
                                </SeekPredicates>
                              </IndexScan>
                            </RelOp>
                          </NestedLoops>
                        </RelOp>
                        <Predicate>
                          <ScalarOperator ScalarString="CASE WHEN NOT [Expr1039] IS NULL THEN (0) ELSE CASE WHEN NOT [Expr1040] IS NULL THEN (1) ELSE CASE WHEN NOT [Expr1041] IS NULL THEN (2) ELSE CASE WHEN NOT [Expr1042] IS NULL THEN (3) ELSE CASE WHEN NOT [Expr1043] IS NULL THEN (4) ELSE CASE WHEN NOT [Expr1044] IS NULL THEN (5) ELSE CASE WHEN NOT [Expr1045] IS NULL THEN (6) ELSE CASE WHEN NOT [Expr1046] IS NULL THEN (7) ELSE CASE WHEN NOT [Expr1047] IS NULL THEN (8) ELSE NULL END END END END END END END END END">
                            <IF>
                              <Condition>
                                <ScalarOperator>
                                  <Logical Operation="NOT">
                                    <ScalarOperator>
                                      <Logical Operation="IS NULL">
                                        <ScalarOperator>
                                          <Identifier>
                                          </Identifier>
                                        </ScalarOperator>
                                      </Logical>
                                    </ScalarOperator>
                                  </Logical>
                                </ScalarOperator>
                              </Condition>
                              <Then>
                                <ScalarOperator>
                                </ScalarOperator>
                              </Then>
                              <Else>
                                <ScalarOperator>
                                  <IF>
                                    <Condition>
                                      <ScalarOperator>
                                          <ScalarOperator>
                                              <ScalarOperator>
                                                <Identifier>
                                                </Identifier>
                                              </ScalarOperator>
                                            </Logical>
                                          </ScalarOperator>
                                        </Logical>
                                      </ScalarOperator>
                                    </Condition>
                                    <Then>
                                      <ScalarOperator>
                                        <Const ConstValue="(1)" />
                                      </ScalarOperator>
                                    </Then>
                                    <Else>
                                      <ScalarOperator>
                                        <IF>
                                          <Condition>
                                            <ScalarOperator>
                                                <ScalarOperator>
                                                    <ScalarOperator>
                                                      <Identifier>
                                                      </Identifier>
                                                    </ScalarOperator>
                                                  </Logical>
                                                </ScalarOperator>
                                              </Logical>
                                            </ScalarOperator>
                                          </Condition>
                                          <Then>
                                            <ScalarOperator>
                                              <Const ConstValue="(2)" />
                                            </ScalarOperator>
                                          </Then>
                                          <Else>
                                            <ScalarOperator>
                                              <IF>
                                                <Condition>
                                                  <ScalarOperator>
                                                      <ScalarOperator>
                                                          <ScalarOperator>
                                                            <Identifier>
                                                            </Identifier>
                                                          </ScalarOperator>
                                                        </Logical>
                                                      </ScalarOperator>
                                                    </Logical>
                                                  </ScalarOperator>
                                                </Condition>
                                                <Then>
                                                  <ScalarOperator>
                                                    <Const ConstValue="(3)" />
                                                  </ScalarOperator>
                                                </Then>
                                                <Else>
                                                  <ScalarOperator>
                                                    <IF>
                                                      <Condition>
                                                        <ScalarOperator>
                                                            <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
                                                              </Logical>
                                                            </ScalarOperator>
                                                          </Logical>
                                                        </ScalarOperator>
                                                      </Condition>
                                                      <Then>
                                                        <ScalarOperator>
                                                          <Const ConstValue="(4)" />
                                                        </ScalarOperator>
                                                      </Then>
                                                      <Else>
                                                        <ScalarOperator>
                                                          <IF>
                                                            <Condition>
                                                              <ScalarOperator>
        <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        </Logical>
        </ScalarOperator>
        </Logical>
                                                              </ScalarOperator>
                                                            </Condition>
                                                            <Then>
                                                              <ScalarOperator>
        <Const ConstValue="(5)" />
                                                              </ScalarOperator>
                                                            </Then>
                                                            <Else>
                                                              <ScalarOperator>
        <IF>
        <Condition>
        <ScalarOperator>
        <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        </Logical>
        </ScalarOperator>
        </Logical>
        </ScalarOperator>
        </Condition>
        <Then>
        <ScalarOperator>
        <Const ConstValue="(6)" />
        </ScalarOperator>
        </Then>
        <Else>
        <ScalarOperator>
        <IF>
        <Condition>
        <ScalarOperator>
        <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        </Logical>
        </ScalarOperator>
        </Logical>
        </ScalarOperator>
        </Condition>
        <Then>
        <ScalarOperator>
        <Const ConstValue="(7)" />
        </ScalarOperator>
        </Then>
        <Else>
        <ScalarOperator>
        <IF>
        <Condition>
        <ScalarOperator>
        <ScalarOperator>
        <ScalarOperator>
        <Identifier>
        </Identifier>
        </ScalarOperator>
        </Logical>
        </ScalarOperator>
        </Logical>
        </ScalarOperator>
        </Condition>
        <Then>
        <ScalarOperator>
        <Const ConstValue="(8)" />
        </ScalarOperator>
        </Then>
        <Else>
        <ScalarOperator>
        </ScalarOperator>
        </Else>
        </IF>
        </ScalarOperator>
        </Else>
        </IF>
        </ScalarOperator>
        </Else>
        </IF>
                                                              </ScalarOperator>
                                                            </Else>
                                                          </IF>
                                                        </ScalarOperator>
                                                      </Else>
                                                    </IF>
                                                  </ScalarOperator>
                                                </Else>
                                              </IF>
                                            </ScalarOperator>
                                          </Else>
                                        </IF>
                                      </ScalarOperator>
                                    </Else>
                                  </IF>
                                </ScalarOperator>
                              </Else>
                            </IF>
                          </ScalarOperator>
                        </Predicate>
                      </Assert>
                    </RelOp>
                  </Spool>
                </RelOp>
                <RelOp AvgRowSize="9" EstimateCPU="0.00160629" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="2769.47" LogicalOp="Assert" NodeId="48" Parallel="false" PhysicalOp="Assert" EstimatedTotalSubtreeCost="7.37639">
                  <OutputList />
                    <RelOp AvgRowSize="9" EstimateCPU="0.156678" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="2769.47" LogicalOp="Left Semi Join" NodeId="49" Parallel="false" PhysicalOp="Merge Join" EstimatedTotalSubtreeCost="7.37478">
                      <OutputList>
                        <ColumnReference Column="Expr1048" />
                      </OutputList>
                          <ColumnReference Database="[PhoenixCMS_RC]" Schema="[dbo]" Table="[tblContent]" Column="fkParentID" />
                        <Residual>
                          <ScalarOperator ScalarString="[PhoenixCMS_RC].[dbo].[tblContent].[fkParentID]=[PhoenixCMS_RC].[dbo].[tblContent].[pkID]">
                              <ScalarOperator>
                                <Identifier>
                                </Identifier>
                              </ScalarOperator>
                              <ScalarOperator>
                                <Identifier>
                                </Identifier>
                              </ScalarOperator>
                            </Compare>
                          </ScalarOperator>
                        </Residual>
                        <RelOp AvgRowSize="11" EstimateCPU="0.0557244" EstimateIO="0.0112613" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3077.19" LogicalOp="Sort" NodeId="50" Parallel="false" PhysicalOp="Sort" EstimatedTotalSubtreeCost="6.98289">
                          <OutputList>
                          </OutputList>
                          <MemoryFractions Input="1" Output="1" />
                            <OrderBy>
                              </OrderByColumn>
                            </OrderBy>
                            <RelOp AvgRowSize="11" EstimateCPU="0.000203866" EstimateIO="0" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="3077.19" LogicalOp="Eager Spool" NodeId="51" Parallel="false" PhysicalOp="Table Spool" EstimatedTotalSubtreeCost="6.9159">
                              <OutputList>
                              </OutputList>
                              <Spool PrimaryNodeId="2" />
                            </RelOp>
                          </Sort>
                        </RelOp>
                        <RelOp AvgRowSize="11" EstimateCPU="0.0743124" EstimateIO="0.160903" EstimateRebinds="0" EstimateRewinds="0" EstimateRows="67414" LogicalOp="Index Scan" NodeId="52" Parallel="false" PhysicalOp="Index Scan" EstimatedTotalSubtreeCost="0.235215" TableCardinality="67414">
                          <OutputList>
                          </OutputList>
                            <RunTimeCountersPerThread Thread="0" ActualRows="59550" ActualEndOfScans="0" ActualExecutions="1" />
                            <DefinedValues>
                              <DefinedValue>
                              </DefinedValue>
                            </DefinedValues>
                          </IndexScan>
                        </RelOp>
                      </Merge>
                    </RelOp>
                    <Predicate>
                      <ScalarOperator ScalarString="CASE WHEN NOT [Expr1048] IS NULL THEN (0) ELSE NULL END">
                        <IF>
                          <Condition>
                            <ScalarOperator>
                                <ScalarOperator>
                                    <ScalarOperator>
                                      <Identifier>
                                      </Identifier>
                                    </ScalarOperator>
                                  </Logical>
                                </ScalarOperator>
                              </Logical>
                            </ScalarOperator>
                          </Condition>
                          <Then>
                            <ScalarOperator>
                            </ScalarOperator>
                          </Then>
                          <Else>
                            <ScalarOperator>
                            </ScalarOperator>
                          </Else>
                        </IF>
                      </ScalarOperator>
                    </Predicate>
                  </Assert>
                </RelOp>
              </Sequence>
            </RelOp>
          </QueryPlan>
        </StmtSimple>
      </Statements>
    </Batch>
  </BatchSequence>
</ShowPlanXML>
#72533
Jun 19, 2013 17:09
I did this test again on a large amount of content, 6000+ pages, and from the API, it either times out, gives me a zombie error, or takes around 4-6 hrs, while when i run the exec editDeleteChilds from the db, it takes a total of 8 min.  Also I did notice after doing the delete from the database, i'm getting some weird dojo errors (they aren't affecting me running the site, the cms/framework still work fine oddly enough) - but here they are below, not sure if they are related to the cache, or me running the delete from the db or what (i reset IIS to see if it was a cache issue, no go).
ErrorCtor {stack: "Error↵    at Error (<anonymous>)↵    at new ErrorC…Pi/Cms/component/SharedBlocksViewModel.js:190:18)", message: undefined, log: false, dojoType: "cancel", name: "CancelError"…}
 "Error
    at new ErrorCtor (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8554:21)
    at promise.cancel.cancel [as cancel] (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8159:15)
    at null.<anonymous> (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SiteTreeModel.js:142:33)
    at http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:3135:55
    at Function.when (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8957:12)
    at declare.getCurrentSite (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SiteTreeModel.js:115:26)
    at declare.getAllLanguagesForCurrentSite (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SiteTreeModel.js:176:22)
    at declare._allowMultilingual (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/_MultilingualMixin.js:77:38)
    at declare.constructor (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SharedBlocksViewModel.js:190:18)
    rejected at signalDeferred (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8286:15)
    at signalListener (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8260:4)
    at Promise.then.promise.then (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8460:5)
    at when (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8968:26)
    at declare._allowMultilingual (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/_MultilingualMixin.js:77:13)
    at new <anonymous> (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:4337:8)
    at declare.postMixInProperties (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SharedBlocks.js:134:53)
    at declare.create (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dijit/_WidgetBase.js:341:8)
    at declare.postscript (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dijit/_WidgetBase.js:300:8)
Error
    at Promise.then.promise.then (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8454:24)
    at new <anonymous> (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:4343:7)
    at constructorExecutor (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/EPi/shell/widget/WidgetFactory.js:377:30)" dojo.js:8739
ErrorCtor {stack: "Error↵    at Error (<anonymous>)↵    at new ErrorC…ntResources/EPi/Cms/component/PageTree.js:213:18)", message: undefined, log: false, dojoType: "cancel", name: "CancelError"…}
 "Error
    at declare.startup (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/PageTree.js:213:18)
    at http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dijit/_WidgetsInTemplateMixin.js:59:8
    at Object.array.forEach (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:3612:6)
    at declare.startup (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dijit/_WidgetsInTemplateMixin.js:57:10)
    at http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dijit/_WidgetBase.js:516:9
Error
    at declare.startup (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dijit/_WidgetBase.js:514:9)" dojo.js:8739
ErrorCtor {stack: "Error↵    at Error (<anonymous>)↵    at new ErrorC…86/ClientResources/dtk/dijit/_WidgetBase.js:516:9", message: undefined, log: false, dojoType: "cancel", name: "CancelError"…}
 "Error
    at declare._setTreePath (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SiteTree.js:96:43)
    at declare.startup (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SiteTree.js:92:18)
    at Function.when (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:8968:26)
    at declare._setTreePath (http://phoenixdweb.bbb.org/episerver/CMS/2.0.79/ClientResources/EPi/Cms/component/SiteTree.js:96:22)
    at inherited__debug [as inherited] (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:4156:19)
Error
    at declare.startup (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dijit/layout/_LayoutWidget.js:55:9)
    at inherited__debug [as inherited] (http://phoenixdweb.bbb.org/episerver/Shell/2.0.86/ClientResources/dtk/dojo/dojo.js:4156:19)"
#72539
Jun 20, 2013 4:46
A theory:
When you empty recycle bin from UI it runs on the request thread and i belive you get request timeout or DB Connection timeout and in this case DB connection be disposed and and the DB handler try to do rollback becuase the connection is disposed then you get the Zombie error. ( i think we have fixed it in the next version).
If the theory is correct you can do a a workaround by increase the timeout  values OR you can use the async version of deletechildren like this pseudo code
AsyncDataFactory asyncDF = new AsyncDataFactory(DataFactory.Instance);
asyncDF.DeleteChildrenCompleted +=
delegate(object sender, System.ComponentModel.AsyncCompletedEventArgs args)
//Insert code when the operation is completed
asyncDF.DeleteChildrenAsync(PageReference.WasteBasket, null);
#72543
Jun 20, 2013 9:02
I'm experiencing this issue using the EPiServer UI on 7.1.2 trying to empty the trash when it contains several thousand pages.  When I click the 'Empty Trash' button a POST is sent to
/EPiServer/cms/Stores/wastebasket/2.  After spinning for about 90 seconds I get a json response back from the call:
{}&&{"isSuccess":false,"isPartialSuccess":false,"message":"This SqlTransaction has completed; it is no longer usable.","extraInformation":null}
and a message is displayed on the UI saying "You do not have access rights to permanently delete content in trash".
I have followed up on Shahram Shahinzadeh theory and set the Connection Timeout to 0 and am still getting the error.  Does anyone have any advice on this?
If the sql transaction is indeed timing out and EPi can't delete a large number of pages from the Trash, this sounds like a bug to me.
UPDATE:  If I 'restore' the majority of the items and then try to empty the trash when there are only a few (~30) pages in the trash it works.  But this is extremely frustrating if I can only delete small groups of pages at a time.
#77596
Edited, Nov 21, 2013 11:39
try to set the commandTimeout also, you can set it by databaseQueryTimeout on episerver.dataStore -> dataSettings.
#77601
Nov 21, 2013 13:09
HI Shahram, thanks for the reply.  I did some more tinkering and I think the issue might have been that one of the many pages I was trying to delete (page A) was 'used' on a page that I wasn't trying to delete (page B).  When I initially moved the pages I wanted to delete to the trash, EPi gave me a warning that page B had referenced page A, but the dialog said I could delete page A anyway.
When I deleted page B I was able to move forward with all of my other deletes.  I tried again deleting several thousand pages that were not referenced by anything else and I didn't get the error.
#77602
Nov 21, 2013 13:29
mmm. if you get warning from EPi about refrences it is only notification that syas to user you are going to get broken link.
Do you have any special event handing on deleting event on Pages?
#77603
Nov 21, 2013 13:39
