Cannot decrypt password error
When trying to use ActiveDirectoryMembershipProvider with Community via:
<add name="EPiServerCommonMembershipProvider" applicationName="EPiServerCommonApplication"
type="EPiServer.Common.Web.Authorization.MembershipProvider, EPiServer.Common.Web.Authorization"
provider="ActiveDirectoryMembershipProvider"
roleToSynchronize1="*" />
I get the error below.  Any ideas on where I should look?
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: Cannot decrypt password
Source Error:
Stack Trace:
[InvalidOperationException: Cannot decrypt password]
   EPiServer.Common.Security.HMACPasswordProvider.DecryptPassword(Byte[] ciphertext) +46
   EPiServer.Common.Security.User.get_Password() +40
   EPiServer.Common.Web.Authorization.MembershipProvider.GetPassword(String username, String answer) +73
   System.Web.Security.MembershipUser.GetPassword() +106
   EPiServer.Common.Web.Authorization.Integrator.SynchronizeUser(MembershipUser membershipUser, String password, Boolean enableCreateNew) +669
   EPiServer.Common.Web.Authorization.IntegrationHttpModule.SynchronizeUser(String userName, Boolean createNew) +74
   EPiServer.Common.Web.Authorization.IntegrationHttpModule.context_AuthenticateRequest(Object sender, EventArgs e) +209
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
#71858
May 30, 2013 15:03
Think I found it.  Needed
EPiServer.Common.Web.Authorization.IntegrationMembershipProvider, EPiServer.Common.Web.Authorization
#71860
May 30, 2013 16:01
