What search provider are you running in the UI? Both EPIServer Find and the built in search "FTS" support searching in blocks. You enable them by going to admin -> config -> Search Configuration.
In the assets pane under the Blocks tab there's a search field, how is that supposed to work?
I've created several blocks but whatever I type in the search field the result is always "Content not found". I've tried to search for both block names and also content in blocks with no result.
Why??
