Deleting database when deleting the Alloy site
Hi all,
I have a problem that when I was trying to delete the sample site and reintall it, I found that I cannot delete the database that the site was using. The winzard is shown as below:
Web Site
To Delete : Alloy (http://xinpei-pc:17000/)
Delete Actions
Force delete any read-only files in application files folder : True
Force delete any read-only files in external files folder : True
Delete external folders used by this application : True
Restart the Application Pool before deleting files : True
Delete the database login used by this application : True
Delete the IIS Application Pool if not used by other applications : True
Delete the EPiServer application files folder used by this application : True
Delete the database used by this application : False
Database Access
Use Windows Authentication when connecting to the database server : True
Related Web Sites
Index directories to be deleted
E:\EPiServer\VPP\Alloy\Index :
So how can I remove the database manually?
Anyone can provide a thought?
Thanks!
#70206
Apr 15, 2013 3:24
Ok. I figured it out. Those databases can be deleted from SQL Server Management Studio. :D
#70207
Apr 15, 2013 3:45
