Continuous integration
Hello,
I am new in the EPiServer world and we need to create our continuous integration server.
I currently use bamboo to do that and everything is fine about the file deployement but I would like to deploy the content via the some EPiServer packages.
How can I deploy those packages via a powershell script or anything? If not possible via powershell how can I do that in code (I will call this code in powershell after)
Regards,
Benjamin V.
#70247
Apr 16, 2013 10:50
Nobody have some continuous integration with episerver????
#71120
May 10, 2013 9:01
There is a cmdLet Add-EPiServerData (that resides in EPiServerInstall.CMS assembly) that imports episerver packages (.episerverdata files) to a site.
#71123
May 10, 2013 10:21
How do you register those snapin?
I have execute this successfully:
c:\windows\Microsoft.NET\Framework\v4.0.30319> .\InstallUtil.exe "c:\Program Files (x86)\EPiServer\Shared\Install\EPi\EPiServerInstall.Common.1.dll"
But after that I doesn't find how to register it I have try:
  • Add-PSSnapin EPiServer.Install.Common.1
  • Add-PSSnapin EPiServer.Install.CMS.7.0.586.1
Without success. I have found that the dll EPiServerInstall.CMS.dll is here on my computer: C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\Install\Tools
REgards,
#71140
May 10, 2013 15:06
If you have installed EPiServerShared.msi and EPiServerCMS.msi (will be installed if you run Setup.exe bootstrap that comes with download) then the snapins should be available.
If the installation of the snapins have been succesful you should see the snapins in registry under
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\PowerShell\1\PowerShellSnapIns
#71141
May 10, 2013 15:27
Correct I see it but if I type
PS C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\Install\Tools> get-help *epi*
I only see 3 commands and I don't see the Add-EPiServerData. Is it normal???
Name Category Synopsis
Write-Progress Cmdlet Displays a progress bar within a Windows PowerShell command window.
about_jobs HelpFile Provides information about how Windows PowerShell background jobs run a
about_preference_variables HelpFile Variables that customize the behavior of Windows PowerShell
#71145
May 10, 2013 16:45
