Inherit contentarea between pages
I need to implement dynamic inheritance of contentareas between pages, which means that I don't want to create a writable clone and then save and republish the page. I need to add the content from another page when the page is loaded when a certain property indicates that the content is to be inherited. The problem is that when using the contentarea "Add" method an exception is thrown stating that the collection is readonly.
Is there another way of doing this?
Appreciate a little help!
#66647
Mar 06, 2013 8:31
Per Nergård (MVP)
If the inheritence is hierarchical ie from a toppage to all subpages maybe you could add the contentarea as a dynamicproperty aswell. If inheritence is chosen on the top page you could programatically set the dynamicproperty. I've done something like that in CMS6 but not tested it with CMS7. And ofcourse contentareas don't exist in CMS6 so it was some standard EPi property type.
/Per
#66653
Mar 06, 2013 10:42
