I'm having the same issue with this. Has anyone figured out a workaround or a way to modify this?
You can hide via jQuery, this is what I have coded for now.
jQuery(document).ready(function () {
jQuery.fn.exists = function () { return this.length > 0; };
attachEvents();
// Attach events to DOM
function attachEvents() {
hideTrackerHandler();
// Hide Tracker Handler
function hideTrackerHandler() {
var trackerHandler = jQuery('body img:first');
if (trackerHandler.exists()) {
if (/TrackerHandler.ashx/i.test(trackerHandler.attr('src')))
trackerHandler.hide();
I think it should be possible to solve using pure CSS, something like this:
img[src*="TrackerHandler.ashx"]
width: 0px;
height: 0px;
In my opinion, using a CSS declaration is currently the best workaround.
For my case, I needed to use this in order for it to not show:
display: none;
I did open up a ticket with EPiServer support for either a better workaround or a patch. If I hear anything from them, I'll update this thread.
Live monitor is switched on but causing design layout issue as it is always rendered after body tag.
The JavaScript is not possible to change as it’s in a compiled dll.
<script type="text/javascript">
void(function(){var tUrl = "/TrackerHandler.ashx?pageId=4&languageId=en-GB";tUrl += (tUrl.indexOf("?") > 0 ? "&" : "?") + "r=" + Math.random(); tUrl += "&referrer=" + escape(document.referrer);document.write("<img src='" + tUrl + "' alt='' width='1' height='1'/>"); }());
</script>
This will then render the following example mark-up
<body>
<img width="1" height="1" alt="" src="/TrackerHandler.ashx?pageId=4&languageId=en-GB&r=0.9895143173015609&referrer=http%3A//local.site.co.uk/etc/etc">
I really need a class on the image tag or something else, I could write some custom JavaScript to look for body > image and src attribute with /TrackerHandler but this would be an expensive DOM request.
Does anyone know another solution or away to position elsewhere?
