Error upgrading CMS6 R2 to CMS7
Hello,
I'm trying to upgrade a site from CMS6 R2 to CMS7 using deployment centre and get an error as follows:
At C:\Program Files (x86)\EPiServer\Framework\7.0.859.1\Install\System Scripts\Install Module Package.ps1:157 char:16
+ Add-EPiXmlBlock <<<<  -TargetFilePath $packagesConfigPath -ElementXPath "/packages" -XmlBlock $packageRegistrationXml
System.ArgumentException: The path is not of a legal form.
   at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength)
   at System.IO.Path.GetFullPathInternal(String path)
   at System.IO.DirectoryInfo..ctor(String path)
   at EPiServer.Install.Common.TempPath..ctor(Char hostDrive)
   at EPiServer.Install.Common.FileBackup..ctor(FileInfo file)
   at EPiServer.Install.Xml.Installers.XmlInstallerBase..ctor(InstallationManager installationManager, String targetFilePath, Dictionary`2 namespaces)
   at EPiServer.Install.Xml.Installers.AddXmlBlockInstaller..ctor(InstallationManager installationManager, String targetFilePath, String elementXPath, XmlNodeList xmlNodes, Dictionary`2 namespaces)
   at EPiServer.Install.Xml.XmlInstallationManager.AddXmlBlock(String targetFilePath, String elementXPath, String xmlBlock, Dictionary`2 namespaces)
   at EPiServer.Install.Xml.Cmdlets.AddXmlBlockCmdlet.ProcessRecord(XmlInstallationManager xmlInstallationManager)
   at EPiServer.Install.Xml.Cmdlets.XmlInstallationCmdlet.ProcessRecord()
   at System.Management.Automation.Cmdlet.DoProcessRecord()
   at System.Management.Automation.CommandProcessor.ProcessRecord()
The packages.config file exists but only contains an empty <packages> node. Anyone encountered this and/or know how to fix?
Mark
#69141
Mar 22, 2013 13:06
In case anyone else encountered this, turns out it's a bug with Deployment Center. If your site uses VPPs on a shared drive this error is generated, moving the VPPs to a local drive prevents the error. Apparentley this has been fixed and will be included in a future patch.
#69177
Mar 25, 2013 11:00
