Check if user is in edit mode inside a custom property
Is it possible to check if a user is in edit mode inside a custom property? EPiServer.Editor.PageEditing.PageIsInEditMode is always false
/Tore
#69143
Mar 22, 2013 15:11
That property should work. Is this a EPiServer 6 style custom property appearing in the new edit view?
#69145
Mar 22, 2013 15:53
Hi Ben,
Yes, this is a EPiServer 6 style custom property. Is it possible to use any other property in EPiServer to determine if we are in edit mode or not?
#69146
Mar 22, 2013 16:03
I've just investigated the legacy properties dialog and it seems there is a bug. The URL to load the custom property doesn't contain epieditmode=true in the query string.
This means that PageIsInEditMode will always return false since that property will only ever be true if the URL contains epieditmode=true in the query string.
I'll log a bug for this.
I'm not sure how you could work around this. My first suggestion would be to try convert the property to an EPiServer 7 style custom property.
#69148
Mar 22, 2013 16:20
Do you mean inside a CMS 6 property control? I don't think we should or need to use the PageIsInEditMode property since legacy editor dialog is not actually new edit mode :).
By the way, checking the control's RenderType property can help in this case.
#69152
Edited, Mar 22, 2013 16:50
Inside a MVC view I use
@if(PageEditing.PageIsInEditMode)
which is from EPiServer.Editor namespace
You also need to be on EPiServer 7 - patch 1
#69153
Edited, Mar 22, 2013 17:02
Hi Ben,
thanks for finding that out! Could you also check why the PageLink is Null here?
@Duong Nguyen: I am inside the PropertyData class and not the PropertyDataControl.
@EPiDev: I am inside the PropertyData class, so this won`t help me much....
#69155
Mar 22, 2013 19:12
Hi Ben,
Is this bug still there in EPiServer 7 Patch 4? Another thing, PageLink is also null here. Is this also a bug?
#79570
Dec 20, 2013 9:29
