Default Property Values in code?
I have a property set up like so:
[Editable(true)]
[Display(
      Name = "Show Foo",
      Description = "Show or hide page Foo",
      GroupName = SystemTabNames.Settings,
      Order = 2
public virtual bool ShowFoo{ get; set; }
How do I set the default value to true? I know I can do this in Admin Mode, but I'm hoping I can do it in code. There's a box on the Page Type Property Editor regarding default values. There has to be something that sets that right?
#66201
Feb 22, 2013 20:20
 Hi Corbin, try to do like this
            //Set up your defaults here
          this.ShowFoo = true;
I hope it helps you.
#66202
Edited, Feb 22, 2013 20:58
That did it. Thanks.
#66203
Feb 22, 2013 22:45
