Hi again,
I'm currently doing stuff where I need to parse posted XForm data by hand. I managed to get it working, the only difficult part was to read input/textarea/select/etc elements Label property which I handled with reflection. So basically my code calls XForm.CreateHtmlFragments(), filters out everything except XFormsFragment and uses .NET Reflection API to get Label property. Then I go through all the posted data by calling GetPostedData() and match every row against XFormsFragments.
Is there any other way to get the labels? I need the labels, not value keys. And if not, I have an suggestion for EpiServer people.
1. Create new simple interface
public interface IXFormsFragmentLabel { string Label { get; set; } }
2. Make all appropriate classes derived from XFormsFragment (InputFragment, SelectFragment, etc.) to implement this interface
public class InputFragment : XFormsFragment : IXFormsFragmentLabel { .. }
This way I wouldn't have to use Reflection API. I could just test if XFormsFragment is of type IXFormsFragmentLabel, cast it and read it's Label-property.
